Old 01-27-2014, 11:13 AM   #15
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
Catted midpipe? You mean front pipe?
Thanks guys, I'm pretty sure I'm going to just go the route of buying the Perrin Cat-back.
flashburn is offline   Reply With Quote
Old 01-27-2014, 11:32 AM   #16
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Err yeah, I meant front/over combo pipe. Make sure to get the resonated version of the exhaust. I think you'll be real happy with the sound.
industrial is offline   Reply With Quote
Old 01-27-2014, 11:41 AM   #17
FR-S Matt
Originally Posted by industrial View Post
10 pound weight difference and I liked the idea of a v-band for more adjustability.
The nameless setup was funny in that it actually got a little quieter once you installed the resonated & catted midpipe. The resonator really did a good job on that system killing the drone.
I may try the Nameless catted downpipe with helmholtz if the drone gets too bad with the N1. I think the loudness is where I want it, but I may need to kill the drone a bit.
Old 01-27-2014, 11:50 AM   #18
ramiram1984
Drives: 2016 STi DGM
I had rasp with the RW uel and unresonated catless Perrin 2.5"
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 01-27-2014, 12:02 PM   #19
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by FR-S Matt View Post
I tried this setup on 3", no helmholtz with a JDL UEL catless header and it was raspy. Only solution is to get more "muffle" in the system, specifically the axleback section. A new catback should take care of it.
The Q300 is ultra quiet.... I'm going to try an N1 to see if it meets my loudness needs without rasp. If not, I'll stay with the Q300 and call it a day. Sounds real nice but is real tame.
I have to agree the Q300 I just put on with my setup (fa20club long tube, nameless catted helmholtz) is almost as quiet as my single exit varex setup (on the closed position). It's acutally a little quieter in the cabin and a little louder out the back than the varex when closed. I almost wish i had gone for the resonated perrin 2.5 for just a little more volume. However, i currently have two cats, once i go to the nameless header i think the Q300 will be perfect for a daily driver setup.
Old 01-27-2014, 03:47 PM   #20
flashburn
Okay, here's something odd I noticed when I went to switch back to the stock axelback.
It looks like when the midpipe is attached to the axelback the pipe rests against one of the mufflers. I wonder if this could be what's causing such horrible rasp for me?
I think I might stuff a rag in between it for a few revs, just to see if it helps at all.
Old 01-27-2014, 04:07 PM   #21
flashburn
Meh, I adjusted it so it wasn't touching, but it's still raspy, so it looks like that wasn't an issue at all.
edit: Actually, I took it out for a drive and it does seem a little bit better (or it's a placebo). I think tomorrow I'm going to stop by the Subaru dealer and pick up a few extra gaskets to space out those pipes a little bit more. I might hook up my Go-Pro and angle it towards that area and see if it's still rattling against it.
Old 01-28-2014, 05:39 PM   #22
flashburn
Okay, tried adding another gasket, to space out those pipes, and it did add room, but nothing changed about the exhaust note. So it was a red herring.
I'm going to order the Perrin 2.5" Resonated tonight. If this doesn't get rid of the rasp, I'm going to go nuts.
Old 01-28-2014, 10:53 PM   #23
wrussi
wrussi's Avatar
Drives: 2013 frs
stock cat back with the revworks headers and aftermarket catted front pipe will sound raspy as well. thats what i have now. i ordered the q300. i will let you guys know if it gets better.
wrussi is offline   Reply With Quote
Old 01-29-2014, 07:18 AM   #24
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
If that's the case, the rasp might be coming from the headers themselves, as in, through the metal of the header pipes. Might be worth adding some heat wrap. My header is a different make and coated so there was no strange resonances from the pipes themselves. My car sounded silent with the stock catback on.
Old 01-29-2014, 07:55 AM   #25
FR-S Matt
That's how my car is with the coated JDL UEL, JDL overpipe, Invidia catted fp, and the Q300. You can hear it pretty well though when I step on it. Pretty tame otherwise, 0 rasp, 0 drone.
Old 01-29-2014, 08:28 AM   #26
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yeah, I'm definitely not looking for something "quiet". I'm pretty happy with the volume of my current setup, although a bit quieter at least at highway speeds would be nice.
@industrial How does the Perrin compare to the Nameless in sound volume?
Im pretty sure in Orlando or Tampa, there are guys in the group with different exhaust setups and jsut by going to a meet you would be able to listen the differences.
The exhaust rasp does not have to do with metal touching metal, that would be a rattle. Rasp is only induced by having too little muffling/resonators in the exhaust.
Old 01-29-2014, 04:30 PM   #27
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Does the rasp not get picked up very well in audio clips??
I've heard several videos of headers and nameless axleback exhaust and only one seemed to sound like ass or 'raspy'
No i can't go listen since more people go to the Texas and cali meets than live in my state lol.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 01-30-2014, 10:56 AM   #28
wrussi
wrussi's Avatar
Drives: 2013 frs
ok Guys i am happy to announce that the rasp on my car is completely gone!
my current setup is: revworks header/plm overpipe/nameless catted front pipe/invidia Q300 cat back
the car sounds amazing! cold starts are a bit loud but not a bit of rasp and now no matter what rpm you press the gas there are no more annoying old car farts. this exhaust is very deep and quiet which was exactly what i was looking for. the car sounds the way it should have come from the factory. nice deep subie rumble with no drone at cruising speeds.
so definately the weak part was the oem catback. it seems its not able to handle the extra flow/different pulsations from the uncatted UEL.
FS: Nameless 3" Axelback Exhaust stmount Engine, Exhaust, Bolt-Ons 6 01-21-2014 09:42 PM
AR+TN For Sale P&L EL Headers+cat and Nameless downPipe+overpipe+hembolt resonator Xdragonxb0i Engine, Exhaust, Bolt-Ons 4 01-09-2014 12:05 PM
No muffler Nameless Axelback? t00n3wb Engine, Exhaust, Transmission 4 12-25-2013 01:54 PM
Anyone running the Nameless catback or axelback? liewyel Northern California 2 11-16-2013 10:49 PM
FS - Nameless Axelback exhaust Atom12 Engine, Exhaust, Bolt-Ons 10 10-15-2013 04:02 PM
