View Poll Results: Can you get 30+MPG doing 70-75mph on the highway?
Yes 143 83.63%
No 28 16.37%
Voters: 171. You may not vote on this poll
Old 01-22-2014, 11:21 AM   #15
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by nalc View Post
127mpg in the twins
ah I got cars confused, my 370 went 99.9 and the FR-S does 127.
Old 01-22-2014, 11:22 AM   #16
nalc
Drives: 13 BRZ Limited 6MT GBS
That's because the FA20 is 27% more efficient than the VQ37VHR
nalc is offline   Reply With Quote
Old 01-22-2014, 11:26 AM   #17
Synack
Boosted
Synack's Avatar
Drives: Sideways
27.0270270270270270270270270270% if you wanna get technical
Old 01-22-2014, 11:51 AM   #18
strat61caster
strat61caster's Avatar
Yes, easy. I regularly do a 100+ mile trip that's 90% freeway, cruise control between 70-75 as traffic allows. When I was calculating by hand 30-32 mpg was normal (it isn't a flat trip, several hills), I've been lazy so I just check the computer which says 32-34, pretty much the same given it's optimistic nature.
Check your tire pressures and look up if Texas has a 'winter blend' of gas, that might be the trick.
ineedyourdiddly
Old 01-22-2014, 12:01 PM   #19
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by brillo View Post
Just curious who can get 30+ MPG legitimately (manual calculation - not the trip computer) doing 70-75 MPH on the highway in a M/T FR-S or BRZ.
I was able to do it early on but for some reason lately I seem to have trouble getting to the 30mpg number. Given the size of the engine and light weight nature of the car, I would think this would be rather easily achievable.
I averaged 30-35MPG on a 1800-mile roadtrip to/from Jackson WY last September. Averaged 70-85 (UT speed limit is 80!)
A few things to keep in mind:
- Check tire pressure. If you're down to 30 or lower, you could lose upwards of 10%
- Winter blend gas: since you're in Houston, your smog problems are just as bad as in LA. The winter blend here has put a noticeable dent in my fuel consumption.
-alex
Old 01-22-2014, 12:24 PM   #20
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
On my trips between NJ and VA every few months (500) miles one way), I routinely get between 35-40mpg. I just set it to cruise. When I used to travel between PA and VA (a little over 400 miles), I was able to make it on one tank, and still had 1.5 to 2 gallons to spare
I've gotten the same numbers with 225 hankook rs-3s (extreme summer tires), the stock tires, another set of all seasons, and 215 snow tires.
Propaganda is offline   Reply With Quote
Old 01-22-2014, 01:40 PM   #21
frs10
Drives: tezla
got around 320 miles with about 1/8 of a tank left
frs10 is offline   Reply With Quote
Old 01-22-2014, 02:00 PM   #22
Tromatic
I have yet to see 26 MPG anywhere.
Tromatic is offline   Reply With Quote
Old 01-22-2014, 02:06 PM   #23
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
With those with 18s or wide wheels have you noticed a large drop in MPG?
calmtigers is offline   Reply With Quote
Old 01-22-2014, 02:08 PM   #24
mav1178
mav1178's Avatar
Depends on the tires... my 245/255 Toyo T1 Sport made my overall gas mileage take a 5-10% hit.
http://www.fuelly.com/driver/mav1178/brz/fuelchart
(Wheels were put on the car in late November)
-alex
Old 01-22-2014, 02:11 PM   #25
1086
1086's Avatar
Drives: UM86 - 6MT
I am not sure if you would count this but on a recent trip I had - taking I-5 from L.A to San Jose. I averaged about 80/85 mph and was able to achieve 85-90 miles per quarter tank - I was using 91 octane and I-5 is mostly flat for the most part - hopefully that puts things in perspective?
Also note that the entire tank is 13.2 gallons - I am not sure if the reserve tank is 3 gallons or 2, but from what I have experienced it must be about 3 gallons, which means that the tank size before the 'E' light turns on would be roughly 10.2 gallons.
1086 is offline   Reply With Quote
Old 01-22-2014, 02:11 PM   #26
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'm lucky to get 300 miles on 11.5-12 gallons. Most of the time the light comes on at ~275 miles.
The absolutely best I get was 32mpg - once, and that was when the car was new.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 01-22-2014, 05:15 PM   #27
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
It's possible, i can get it to around 30-35 going 75mph at around 3.3k rpm. But this is usually due to the highway either being perfectly flat or a bit downhill. When it's a bit tilted upward I'll be looking at 26-28 to try to stay at 75. I usually just let it drop to 65 or so to keep my mpg up.
Vincenttam is offline   Reply With Quote
Old 01-22-2014, 08:44 PM   #28
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I don't know what it is about this car but the MPG hit I take when changing from 70 to 75mph is like 4mpg. At 70mph without cruise on I can get 34mpg. At 75 I get 30 or 31.
PRO86 | WTCC | STL
