#15 | |
formerly Dixie Normous
Drives: The ladies wild!
hmmmm i guess i never really thought about how wide a boxer is. good point
#16 |
Drives: Toyota Corolla SR5
don't matter what coilover or non coilover ill change it to a better spring rate and better strut rebound, I'm thinking 14kg front/ 12kg rear
#17 |
Site Moderator
Drives: ichi 86 Project
So pretty much same as me then.
#18 |
#19 |
Site Moderator
Lucky you, I envy ya. Send some on my way too lol
#20 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
While at work, the rear suspension on an '06 RAV4 struck me in the eye, and it's mechanical workins seemed to jive with the pic of the FT, minus some expected differences. ![]() You can see the two main structural lateral arms, one really fat under the coil and one smaller and slightly curved attaching at the top of the knuckle. The big pressed steel longitudinal link would be equivalent to the tubular arm visible in the bottom right of the FT picture, and the small toe link at the bottom/front of the knuckle is the only thing I can't find in the FT pic. An eccentric at the end of the lower arm might be doing that job. Last edited by RZNT4R; 04-24-2010 at 09:22 AM. |
#21 |
Drives: 2002 M3 6MT
Subarus are tight in the nose because the engine is mounted ahead of and over the front axle, the FT-86 won't have that problem. But since the platform already uses MacPherson you are probably right that they will keep it.
#22 | |
Yeah subarus are tight in the nose, but that's with the engine slightly forwards of the front axle. I was under an impreza before leaving work, and they even kink the subframe inwards behind the engine to fit control arm that's a bit longer. The FT however, had the engine sitting right between the wheels, taking up space from the suspension, as evidenced by this pic from geneva. http://s10.directupload.net/images/100313/vr5678pj.jpg You can see the oil pan amongst the exhaust bends, right between the wheels. |
#23 |
#24 |
Well, it was easy in the S2000's case to push the firewall back and fit a whole I4 behind the front axle since it's a 2 seater, but the FT needs a bit more space since it's a 4 seater.
The engine should already be very far back in the engine bay, the open hood shot in the original GT5 reveal trailer hinted that unlike the traditional subaru rear throttle/airbox layout, they had to put the throttle on the front of the manifold and plumb the intake tube between the AC compressor and alternator (now on either side of the engine), so I don't think they could have pushed the engine any farther back. But given that a boxer is only 2 cylinders long, even if it's right over the front axle, there's next to no weight protruding forwards, so I don't think you have to worry, it's not any less front midship than the S2000. |
#25 | |
hashiryu
Drives: Mk4 Supra
#26 | |
Drives: 2002 M3 6MT
Btw, I was working on my 2.5RS coupe yesterday and saw what you said about the subframe. All that weight pushed up forward makes me want to experiment with a carbon fiber hood... Someone on NASIOC had a theory that the engine is not based on the EJ 2.5L family but on the EZ H6 3.0L family with 2 cylinders removed but keeping some of the other components making it even more compact longitudinally. I'll try to find the exact post. |
#27 |
Drives: Subaru Legacy
The last FR flat 4 engined Sports coupe had this double wish bone set up up front in 1950.
Its in front of the axle but the motor is pretty light. And still handle very well
#28 |
Drives: 2013 BRZ / 2015 WRX
Just for a reference, though.. that kind of design wouldn't work today. The car had ZERO space or a modern bumper or crumple zone, andeven a small front-end collision would mean totalling the car.
Just look how little room is in front of the front axle!
| Stock suspension adjustability? | #87 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-02-2010 04:36 PM |
| GM Lets Another Die | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 11 | 12-20-2009 09:51 PM |
| new talk from Australia Subaru director | Axel | BRZ First-Gen (2012+) — General Topics | 5 | 11-08-2009 05:30 PM |
