Old 09-11-2017, 11:45 PM   #15
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Originally Posted by Turdinator View Post
I have their flywheel but use an exedy clutch. My understanding is that the Toda clutch and flywheel are both separately interchangeable with the stock items so the stock throw out will work just fine. I don't know if buying the clutch and flywheel together comes with a throw out bearing tho.
Coincidentally the clutch and pressure plates in the Toda clutch kit are made by Exedy!
I reckon they are parts from the Stage 1 kit?
Brzerker is offline   Reply With Quote
Old 09-12-2017, 03:06 AM   #16
nav
Drives: Toyota 86
You should consider using a different image host - pictures can't be seen!
nav is offline   Reply With Quote
Old 01-24-2018, 05:04 PM   #17
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I'm thinking to order the complete kit of flywheel and clutch. Toda's clutch cover and disk are indeed re-market Exedy parts. They sell it together with the flywheel, because they are balanced by a dynamic balancer. If you can do the balancing in a local shop, then yes you can buy it separate.
The Following User Says Thank You to nikitopo For This Useful Post:
Turdinator (02-05-2018)
Old 02-22-2018, 07:33 AM   #18
teppei
Drives: 86 GTS
Can anyone confirm Toda clutch and flywheel kit is just like the Exedy Stage 1 Kit?
And does either of these flywheels make chattering noise? I know Os Giken one does.
teppei is offline   Reply With Quote
Old 02-22-2018, 01:12 PM   #19
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There are two Toda clutches. One is using the Exedy stage 1 kit and the other is using the stage 2 with thick discs. Both are quite streetable. I am not sure about chattering noise. You might have when you are idle. I'm still waiting to install mine.
TODA Racing 20valvewynn83 Engine, Exhaust, Transmission 15 09-07-2016 09:15 PM
Toda flywheel diss7 Engine, Exhaust, Transmission 1 08-04-2013 05:54 AM
Toda Racing Big Single Throttle ANREX Engine, Exhaust, Transmission 27 06-14-2013 01:14 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
