#15 |
Guy on internet
Drives: Slowly
It's cool, I'm Asian.
Oh as long as you don't butcher the wiring and fry the wiring harness you'll be ok. |
#16 | |
Drives: 2005 Toyota Camry
Just because a part is removed does NOT void the warranty coverage of that part. Even if you swap exhaust systems out, and put on an aftermarket system, that does not void your warranty on your stock exhaust. If you put an aftermarket exhaust on day 1 of ownership, run it for 15000 miles, sell the exhaust, put stock exhaust on, and after 2 years and 35000 miles find the stock exhaust is rusting on one of the ends of the muffler, this does not void your warranty because you took the stock exhaust system off. It's all very careful wording, but what it comes down to is this: if you are UNSURE about mods or are afraid of being denied warranty coverage, ALWAYS consult a qualified mechanic or have the install documented. Many times a car shop or a mechanic exists as a way to guarantee proper labor work being done, and could end up being cheaper in the long run if you have no prior experience wrenching on a car. That said, if you are unable to afford $1-2k worth of mechanical work done on your car over the next 2-3 years, you should NOT be modifying your car to begin with. That just reeks of a larger underlying financial issue that seems to permeate these forums... -alex |
#17 | |
Drives: Raven M/T FR-S
#18 | ||
Just because you removed a factory part does not mean you are losing warranty on that factory part. This is important for everyone to understand, especially anyone wanting to mod their car. -alex |
#19 |
Very well, thank you for correcting me. I will correct the post. You dont lose the warranty on the original part (that nobody cares about because they removed it..), but if your aftermarket part fails and causes more failure to the rest of the engine/car, warranty wont cover the rest of the car that broke because of your aftermarket parts.
#20 |
Drives: 2013 Whiteout FRS
Does this law apply in North America or usa specifically? Canadians like to mod as well
![]() Sent from my SGH-I337M using Tapatalk |
#21 | |
Buying and maintaining a car is very much like buying and maintaining a house... some things you can easily do on your own, others should be the responsibility of a qualified 3rd party worker, either for technical or liability reasons. -alex |
#22 |
Drives: 2013 Red Subaru Brz
This is an old topic but will replacing the header on our car void the warranty? Or is it only when it's tuned that it would void
#23 | |
Just replace whatever part was discussed earlier with the word "header" and you have your answer. -alex |
| Tags |
| mods, warranty |
| Scion Boost/Warranty Issues with Mods? | Marusich | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 10-17-2013 12:26 AM |
| relatively non-intrusive mods to preserve warranty? | rainmonkey | Issues | Warranty | Recalls / TSB | 40 | 10-07-2013 10:30 AM |
| Anyone w/ mods have warranty service done at Steve Moyer or Becker Subaru? | ng4330 | NY / NJ / CT / PA | 2 | 04-17-2013 02:32 PM |
| FI warranty | Celica00 | Forced Induction | 21 | 11-04-2012 04:13 AM |
| Aftermarket Mods / Will this void my warranty? | |-Goku-| | Engine, Exhaust, Transmission | 1 | 07-03-2012 07:55 PM |
