Old 01-02-2014, 12:38 AM   #15
diss7
Drives: AE86, 2x GT86, TE27
I like what I have read about the Grimm Speed bar.
However, IMO, a proper stiff bar should need one of the shocks lowered to install. If it doesn't require this, it means the holes are slotted, therefore have slop once in place.
But I can understand their reasoning behind slotting the holes, because the majority of customers would get the shits having to drop a shock; even though it only requires removing three more nuts and jacking the car up slowly.
This is why some bars have adjustment. You install, and then tighten the adjustment to remove the slop from the slotted holes; a concept that's missed on most.
But I'd still rather a solid bar like the GS one, just with direct (non slotted) holes.
diss7 is offline   Reply With Quote
Old 01-02-2014, 12:48 AM   #16
diss7
Originally Posted by wparsons View Post
Give me a bar to test and I'll gladly do it. Until then, I'll spend my money on things I know will make a bigger difference.
I usually agree you with you on most topics, you actually have a brain.
But, in this instance, we have different opinions about a front strut bar's functionality.
I'm not talked about the shiney ricey crap. I'm talking about a proper stuff bar. You will notice a difference, specifically inital turn in. It is obviously true that it also increasing front stiffness, so will increase understeer. But the car understeers at the limit stock anyway, and requires a stiffer rear sway bar anyway. Having this strut bar may mean the difference in two different settings on the rear sway (assuming its adjustable) But IMO the increase in understeer is minimal and I would doubt there is any need for further adjustment.
Old 01-02-2014, 03:57 AM   #17
mfbmike
Drives: 2013 FRS, 2008 R32
That's the post. Thanks.
lol. The GS bar is rather inexpensive considering. I got mine used for less than 100 bucks.
Super happy.
Essentially why I went with the GS bar over the TRD bar (I'm a huge OEM+ guy). Quantitative data (granted, provided by GS) showed advantages in their bar.
It's not the prettiest but def functional.
Their master cylinder brace is probably even more noticeable after install.
mfbmike is offline   Reply With Quote
Old 01-02-2014, 07:10 AM   #18
wparsons
wparsons's Avatar
Don't confuse chassis stiffness with roll stiffness... the point of a strut bar is to reduce chassis flex, not increase roll stiffness like a sway bar does.
The only way that a strut bar would increase understeer is by stopping strut tower deflection from adding any camber to the front tires, but there's no way anyone is getting enough tower deflection to get any useful camber gain.
Don't get me wrong, I'm sure on some cars this bar does great things. My whole point is that if you're on stock bushings and upper mounts they will give way more deflection than the strut towers do, so until you have all those squishy bits replaced with harder bushings (or bearings) you haven't addressed the weakest links. On stock tires it's even less important since the grip levels are lower.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
diss7 (01-02-2014)
Old 01-02-2014, 11:07 AM   #19
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
It is great.
I am out.
Old 01-02-2014, 02:31 PM   #20
wparsons
wparsons's Avatar
Originally Posted by normancw View Post
Not sure if this video is to be believed (made by Cusco).
Too bad they show vertical deflection, which a strut bar won't help... a strut bar will just prevent the towers from deflecting toward (or away) from each other.
They also showed that on an almost 20 year old chassis. Try the same test on this car and see how much you can measure under the same situation.
flickr
Old 01-20-2014, 03:51 PM   #21
BlackyRose
Drives: 2013 Raven FR-S
the responses kinda got all over the place......anyone in the last few weeks put this stru bar on their stock car and notice a driving feel difference?
BlackyRose is offline   Reply With Quote
Old 01-22-2014, 12:06 PM   #22
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
opinions on grimspeed strut tower w stock tires/suspension
Yes I feel a difference after installing the Whiteline strut bar. And now I don't want to ride without. Next step to install soon rack and pinion bushing.
o= FR-S =o
Mikepage is offline   Reply With Quote
"Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE Jason@DSG Groupbuys 14 12-31-2013 09:06 AM
WTB: Grimspeed strut tower bar in red husker741 Brakes, Suspension, Chassis 0 10-25-2013 01:40 PM
Grimspeed strut bar Fizz AUSTRALIA 13 09-23-2013 12:06 PM
GT Spec Strut Tower Bars / Front - Rear - 3 Mount / Available in Stock @ Import DPS!! rickspecd Brakes, Suspension, Chassis 3 07-12-2013 11:49 AM
Rear Strut Tower? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-25-2012 11:14 PM
