CANADA Canada
Old 06-04-2014, 08:30 PM   #15
wparsons
wparsons's Avatar
Originally Posted by vignesh View Post
Does Scott have Experience working on the frs/brz platform. I am looking at getting my tarmac II installed. I am also wondering if i should get the car aligned right away or wait for the coil overs to settle and then get it aligned. And is it worth corner balancing the car as well?
Yep, Scott knows what he is doing. Most of the record setting time attack cars in the area were aligned/balanced by him.
I would let the springs settle for a couple days then get it done. Just a heads up, he's probably booking into July now. Last time I talked to him (May 24th at a lapping day) his next appointment was around June 20th.
If you're going to spend the money on TII's, spend the last little bit to have the car corner balanced. Also make sure you have all the parts needed for alignment. You'll need something for the rear (UCA, LCA, offset bushings), and the slots in the front might not give you as much camber as you want, so you might need camber plates still.
flickr
anyone know a good audio install shop NYCsubaruBRZ NY / NJ / CT / PA 6 01-16-2014 10:22 AM
Coilover and Springs Install at Performance Shop F-T Mechanical Maintenance and Tools 22 12-12-2013 01:12 PM
HELP kw coilover top hat install problem autoCAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-18-2013 10:55 PM
HKS Coilover install gtauto AUSTRALIA 16 04-21-2013 07:37 AM
Good coilover brand for DD ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-26-2012 03:59 AM
