Old 12-15-2013, 10:18 PM   #15
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by Brody602 View Post
Can you give more details about this shroud?
Here is the drawing of our shroud. It's design to helps pull the heat from the whole radiator surface.
FullBlown is offline   Reply With Quote
Old 12-15-2013, 10:23 PM   #16
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
Originally Posted by mike the snake View Post
I thought about the same thing, but I think the problem lies with not being able to get the engine bay air OUT.
I found this crash bar that looks like it will still offer front protection but also let a lot more air in.
http://www.enjukuracing.com/products...Scion-FRS.html
Thats almost exactly what I was thinking for a replacement front bumper. I can get one made like this as well and make supports to hold the FMIC.
has anyone tried different thermostats and have they had any improvement with that?
toekneehair is offline   Reply With Quote
Old 12-15-2013, 10:26 PM   #17
mike the snake
For $150 it is very tempting. To have someone fab it up would cost as much or more I would think.
Fullblown, is your shroud available?
Old 12-15-2013, 10:35 PM   #18
toekneehair
True... unless you have friends who weld and bend tubing. Then it might not cost so much haha. I just have to work on drawing up the dimensions myself.
my friend has been looking for additional weld work to do.
Old 12-15-2013, 10:38 PM   #19
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We should have it ready next week.
Old 12-15-2013, 10:38 PM   #20
mike the snake
Eventually, to make my car look different, I plan to install that crash bar, and then carefully cut the "mouthpiece" off the front of my BRZ, and install a different screen grill.
This will open the front grill hole up substantially, and, if done correctly, will look killer.
Old 12-15-2013, 10:48 PM   #21
toekneehair
I thought about cutting out the black part of the grill too but I am not to great with cutting that stuff. let me know how yours goes.. I would love to see photos. I may still do that out of necessity but I fear it won't look as clean.
Old 12-15-2013, 11:02 PM   #22
mike the snake
I don't think it'll be too hard. Proper tools is key. Cut the edges wide with a dremel or disc grinder, and then fine tune with sandpaper and block.
It would be difficult to try to cut the edges precicely, but cutting wide and sanding/grinding the edges will do the trick. I've done similar things many times.
Old 12-16-2013, 12:02 AM   #23
jamesm
my rev works kit uses one aftermarket fan and one stock fan. i don't have any issues in traffic, and the a/c always stays cold. i live in central florida, so it's usually pretty hot. i'm pretty sure having the one stock fan still there is what does it.
Old 12-16-2013, 12:09 AM   #24
diss7
Drives: AE86, 2x GT86, TE27
Get a turbo kit with a sensible turbo location, rather than putting band aids on poor turbo placement.
P tuning for example.
diss7 is offline   Reply With Quote
Old 12-16-2013, 12:26 AM   #25
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
While I can see your point, and it is probably valid to a certain extent, heat rises.. The PTuning kit would probably have less heat though due to airflow going through the front grill. But with a top mounted turbo, and a vented hood, I would think there would be less heat then a lower mount turbo since the heat would be escaping almost instantly from the turbo near the vents. Yes I'm aware that the turbo isn't the only part that generates heat, but it's one of the major contributors.. Just my 2¢
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 12-16-2013, 12:46 AM   #26
Gen
Drives: Scion FR-S
Originally Posted by mrk1 View Post
Does anyone have a picture of how close the down pipe is to the fans?
My radiator had to be moved back slightly to accommodate the oil cooler, so mine is closer than it would be if you kept the stock radiator with no oil cooler. So on my car? Pretty damn close. The fan gapped itself via melting. I don't really expect it to last long, but it has held up until I have time for a proper solution.
@Brody602 I've been looking at vented hoods...but they're all so...fast and furious. If only there was something along the lines of the M3 hood. Something discreet but functional.
Gen is offline   Reply With Quote
Old 12-16-2013, 12:58 AM   #27
Brody602
Drift King
Brody602's Avatar
@Gen Seibon TS seems to be the best combination of Function/Subtle.
Old 12-16-2013, 12:58 AM   #28
pmccut
Drives: Blue Subarus
I was overheating in 80F stop and go traffic after 10 minutes on the stock radiator. Haven't had any issues under normal street conditions with the FBM radiator + FBM oil cooler. Took the car to the track for the first time yesterday and....heat was the primary issue. I'm surely going to get whatever shroud @FullBlown comes up with, but I'd jump on a painted vented hood if it didn't look rice. The heat you feel opening the engine bay after a good thrashing is intense.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
