Old 04-25-2012, 02:06 PM   #15
Tainen
Drives: First SWP BRZ-L
I want to mention something I am seeing here.
In the insideline review posted, read this:
"In our testing the FR-S generated 0.88g on the skid pad and turned out a 67.3-mph slalom performance; results that trail those produced by the BRZ we tested. The reason is balance — the FR-S's slightly more tail-happy character makes the numbers less big. "
And if that's true, the BRZ actually would be better in the corners on a track. not worse.
another qoute that shows that it's more about launching ability and driver ability:
Sixty miles per hour is reached in 6.6 seconds (6.3 seconds with one foot of rollout like on a drag strip), and the quarter-mile in 14.8 seconds at 93.8 mph. Yes, this result is notably quicker and faster than the BRZ, which did those deeds in 7.3, 7.0, and 15.3 seconds at 92.1, respectively. What's going on?
The data reveals that the BRZ actually accelerated quicker initially, but at 19 mph the Subaru laid over a bit and the Scion powered ahead and never looked back. The explanation is equal parts launch technique and gearchange speed. The Scion's tire-spinning launch allowed it power through the 4000-rpm torque hole we observed in our dyno testing where the Subaru bogged down briefly. Plus, our BRZ tester was plagued with a finicky 1-2 gearchange which ate up precious time en route to 60 mph. "
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 04-25-2012, 02:13 PM   #16
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Just to compile what I found in those reviews so far, comparing the FRS to BRZ:
Motor Authority:
"But turn it all off, and the FR-S reveals its true ability--a level of ability that may even surpass its Subaru twin.
The FR-S isn't identical to the BRZ. It has stiffer rear springs and rear bushings. That makes it a bit more willing to rotate, both on power and off, and yields a balance that feels both natural and easily controlled. It's a conscious decision taken by the Scion crew to make their version just a bit more fun, a bit better-suited to those with as much taste for a well-carved apex and corner-entry tossability as for outright speed. And that, in a nutshell, is the Scion FR-S."
Motor Trend:
"During our testing, we recorded a 25.9-second figure-eight run at a 0.67 g average -- a full second quicker than the Fiat 500 Abarth we recently tested, a half-second quicker than the Honda Civic Si coupe, and even three-tenths of a second quicker than the Subaru BRZ."
Automobile Mag:
"As a result, the cars were essentially neck-and-neck in acceleration runs, with the Scion’s 6.2-second run to 60 mph edging out the Subaru’s 6.4-second 0-60 sprint....
The Scion FR-S, on the other hand, is more playful -- and has a temper. Think of an RX-8 with some MX-5 Miata thrown into the mix. Stiffer rear springs and bushings help make the Scion more neutral at the limit. A tiny amount of initial understeer can be nixed by your right foot with no hesitation. Lift slightly in a corner and the FR-S’s rear tires come unstuck. Get on the throttle too hard, and without delay the rear end begins to rotate. Its actions are quick, so your reactions on the steering wheel need to be fast, too -- but there’s more than enough steering feel coming through the electrically assisted rack that you’ll feel the back end coming around right away.
A beginner driver might have an easier time controlling the Subaru at the limit -- more experienced drivers might prefer the Scion. As the near-identical performance numbers show, neither has a clear performance advantage -- it’s all about the feel. The Scion offers the best balance of any sports car within three times its price. Well, except the Subaru, which trails right behind."
Inside Line:
"Sixty miles per hour is reached in 6.6 seconds (6.3 seconds with one foot of rollout like on a drag strip), and the quarter-mile in 14.8 seconds at 93.8 mph. Yes, this result is notably quicker and faster than the BRZ, which did those deeds in 7.3, 7.0, and 15.3 seconds at 92.1, respectively. What's going on? The data reveals that the BRZ actually accelerated quicker initially, but at 19 mph the Subaru laid over a bit and the Scion powered ahead and never looked back. The explanation is equal parts launch technique and gearchange speed. The Scion's tire-spinning launch allowed it power through the 4000-rpm torque hole we observed in our dyno testing where the Subaru bogged down briefly. Plus, our BRZ tester was plagued with a finicky 1-2 gearchange which ate up precious time en route to 60 mph."
Seems to be some truth underlying all this.
Phaedrus29 is offline   Reply With Quote
The Following User Says Thank You to Phaedrus29 For This Useful Post:
csaba (04-26-2012)
Old 04-25-2012, 02:31 PM   #17
feedbag
Seasoned Spirit
Drives: 2013 DGM BRZ Premium
They are literally the exact same car with slightly different suspensions. Any observations that the FR-S is somehow faster are purely anecdotal, unreliable, and probably misguided. Maybe if Toyota used a different air intake or tuned it differently it could be the case, but it's not.
feedbag is offline   Reply With Quote
The Following User Says Thank You to feedbag For This Useful Post:
MmmHamSandwich (04-25-2012)
Old 04-25-2012, 02:34 PM   #18
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Motor Authority:
Motor Trend:
Automobile Mag:
Inside Line:
of course there's some truth to it. and the truth is this, the scion has a slight edge when it comes to certain things, but the edge is VERY VERY SLIGHT. so slight that like everyone else said, i would choose the car based on features you want and price rather than these reviews. such a slight edge would easily disappear with upgraded parts, or most importantly, DRIVER UPGRADE.
also, don't ignore the personal preference aspect as well. some people might prefer the more forgiving nature of the BRZ at the limits. others might want the balance of the scion more. test drive them both and decide which you like better, although you may not even be able to perceive the difference on regular roads at normal speeds.
cyde01 is offline   Reply With Quote
Old 04-25-2012, 02:34 PM   #19
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
The FR-S is faster enough said....still sucks that I can't get HIDs and push button start...
tripjammer is offline   Reply With Quote
Old 04-25-2012, 02:36 PM   #20
feedbag
Seasoned Spirit
Hey a lot of those car magazines said that we'd be driving these cars on April 20th, am I missing something?
Old 04-25-2012, 02:42 PM   #21
KevinDuMa
Drives: 2004 Honda S2000
There's really not much debate and you can't lose either way. You like the Fr-s get the Fr-s, like the BRZ get the BRZ.
KevinDuMa is offline   Reply With Quote
Old 04-25-2012, 02:42 PM   #22
tripjammer
tripjammer's Avatar
+1
I still think the BRZ premium is the better deal!
Old 04-25-2012, 02:46 PM   #23
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Yeah, we're all missing our cars!
Subaru STI :
Old 04-25-2012, 03:04 PM   #24
dsgerbc
Drives: BRZ(sold), STI
There's zero reason to pick one or the other based on reviews. No article tested both at the same time in the same condition.
dsgerbc is offline   Reply With Quote
Old 04-25-2012, 03:49 PM   #25
stateless
Double Dragon
stateless's Avatar
Drives: 2013 6MT BRZ Limited
If anyone is worried about the suspension differences, I'm sure enough FR-S owners will swap out their suspension that BRZ owners can get some like-new parts for cheap. The main differences between the BRZ and FR-S are the easiest parts to change...
stateless is offline   Reply With Quote
Old 04-25-2012, 03:54 PM   #26
brillo
Drives: 2013 Firestorm FR-S
From what I recall alot of the initial BRZ reviews didn't post 0-60 times. In addition, both cars would need to be tested back to back in the same conditions to make a comparison. Given that the cars are identical in every meaningful way that matters for straight line performance, you choice comes down to which ever exterior and interior suits you.
Both the FR-S / BR-Z are mid 6 sec 0-60 cars. Period.
brillo is offline   Reply With Quote
Old 04-25-2012, 06:18 PM   #27
KeepGuessing
Drives: e30 150 deville etc etc
HID's give off so much light it actually slows the car down..
There's your solution..
problem solved
KeepGuessing is offline   Reply With Quote
The Following 2 Users Say Thank You to KeepGuessing For This Useful Post:
dsgerbc (04-25-2012), Sport-Tech (05-12-2012)
Old 04-25-2012, 06:19 PM   #28
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I gonna be honest. When I buy this car it's come down to this
MT = FR-S
AT = BRZ
Why? If I buy MT, which means I gonna use this car for track/autox more than DD, so I don't need all the accessoies. AT, I kinda want extra luxury stuff, which BRZ offers, so I'm going for BRZ.
Other than that, BRZ & FR-S, they're all same to me. Just happen to be FR-S got better time than BRZ. Road condition was different along with weather & temp. Again, just take all the info and review as grain of salt
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
