Old 12-01-2013, 11:24 AM   #15
z3ro
Is that something every shop would have?
z3ro is offline   Reply With Quote
Old 12-01-2013, 02:30 PM   #16
Bad Habits
Bad Habits's Avatar
Drives: br zed
Originally Posted by Snowblind View Post
Never take advice from someone who works at tire kingdom.
My sis is a probation/parole officer and TK's around here are one of the largest hires of crackheads, meth junkies, thieves, etc. They are like walmart, jiffy lube, etc in that they will hire anyone with a pulse.
Bad Habits is offline   Reply With Quote
Old 12-01-2013, 02:38 PM   #17
humfrz
Well, I don't know ..... you could call around.
If they were my rotors, I would get a second opinion from a brake shop.
If they confirm it's just "crazing", I'd go with:
"The picture above shows a normal cast iron brake disc that exhibits what we call crazing. These are tiny hairline cracks that are extremely small and not of real concern."
However, something has heated up the rotors, so you may wish to take a peak at them from time to time.
humfrz
Old 12-02-2013, 06:02 PM   #18
@z3ro: post a picture, and I will tell you if its normal or not.
Old 12-03-2013, 10:39 AM   #19
andrew20195
Drives: 2013 Subaru BRZ
Pro-Cut is a brand of on car brake lathe (required equipment for Subaru dealers). It's more idiot proof than other brake lathes, but really any decent tech should be able to resurface your rotors with any brand of on-car lathe.
I'd avoid shops that use off-car lathes, as they tend to be less idiot proof, and they won't match the rotor to the runout of your wheel hubs.
andrew20195 is offline   Reply With Quote
Old 12-03-2013, 11:01 AM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Sounds like your stability control is working overtime. You're not "drifting" if you're in "sport" mode. Try it with everything off.
This is my guess. The OP has been drifting more than he thinks and the stability control system has been activating the rear brakes and overheating them. I know it is a common issue for guys who track Porsches to go through the rear pads much quicker than the front pads due to leaving the traction control system on.
will wrx rotors fit the brz? NYCsubaruBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-24-2013 07:58 PM
FS: GTS rotors yomchi1989 Australia Classifieds 0 01-05-2013 12:33 AM
GTS OEM rotors and pads yomchi1989 AUSTRALIA 1 12-30-2012 04:47 PM
GTS OEM rotors and pads yomchi1989 Australia Classifieds 0 12-28-2012 06:28 PM
RDA rotors? yomchi1989 AUSTRALIA 2 12-14-2012 02:02 AM
