Old 12-04-2013, 04:09 AM   #15
Osiris
Osiris's Avatar
Drives: Asphalt FR-S
Originally Posted by Diode Dynamics View Post
The fog kit he purchased from us was working just fine, it sounds like the yellow bulbs simply went out, which we did not provide. Most yellow halogen bulbs are very low quality, so failure after a week is not surprising.
OP has contacted us, we recommended he reinstall the bulbs that came with the kit to determine whether the issue is the bulbs or not, that was the last we heard... - we're of course very happy to help determine any issue with the wiring if the regular bulbs also don't work, but our kit is just wires and fog housings... not a lot could really fail, no moving parts. It's probably that the signal wire was accidentally unplugged. Like I said, didn't hear back from OP yet via email.
As others have said, the main battery fuse was probably blown and just needs to be replaced. Gotta watch that wrench, yikes!
Thanks,
Paul
I meant absolutely no disrespect to you or your company. All of your products have been above and beyond expectations. I got everything sorted out! The bulbs weren't burnt out. It was most likely something I did in installation. The dealership mentioned that the ground was screwed down to a painted surface, they moved it to another bolt and everything is in working order! Thank you so much for your help, I'll make sure to pick up my HID kit through you guys to make up for any disturbances I caused! haha
Slow as fvck
Osiris is offline   Reply With Quote
The Following User Says Thank You to Osiris For This Useful Post:
Diode Dynamics (12-04-2013)
