Old 11-18-2013, 08:15 PM   #15
1086
1086's Avatar
Drives: UM86 - 6MT
That was my assumption when Crawford described their (vague) test results with their brz. EJ runs at its cr because that is where it is optimal - likewise with the FA - it has a high cr because that is where it is arguably optimal.
1086 is offline   Reply With Quote
The Following User Says Thank You to 1086 For This Useful Post:
SmsAlSuwaidi (11-18-2013)
Old 11-18-2013, 08:16 PM   #16
TeamZleep
Drives: 2013 FRS/2011 TDI
More torque and no direct injection... Sounds like a winner to me.
TeamZleep is offline   Reply With Quote
Old 11-18-2013, 11:03 PM   #17
xwd
So first of all the JDM STi doesn't use a 2.5L engine, it still uses the EJ207 2.0L engine it always has.
Second if you ran the EJ257 at 12.5:1 CR on anything but E85 or low boost it would detonate itself to death in about 15 minutes. It has a hard time not detonating at 8.5:1. DI goes a long way...
The FA20 is superior to the EJ257 in pretty much every way. The only reason those guys used the engine is because they were known setups which were in previous cars. There is no way I would put one in my car. You don't think Subaru has made any advancements in engines since they came out with the EJ257 in 2003?
The Following 5 Users Say Thank You to xwd For This Useful Post:
armythug (12-10-2014), FRSToyota86 (11-19-2013), G_Ride (11-19-2013), ImAwesome (11-20-2013), SirBrass (11-19-2013)
Old 11-18-2013, 11:04 PM   #18
xwd
Originally Posted by lickitysplit View Post
I'm no expert, but I'm certain that the 12.5:1 compression ratio compared to the 8.5:1 in the EJ is to blame for the extra bump in power. Find an EJ25 at 12.5:1 and im sure you'll see more power in that engine than the FA20
No, you won't.
Old 11-19-2013, 02:58 AM   #19
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
Originally Posted by SmsAlSuwaidi View Post
Oh so his putting an ej25 and going na with it ?
This isnt some small block vs big block debate, but with alot of import motors displacement isn't everything.
There's no replacement for displacement. Except Forced Induction. N/A vs. N/A? Never a replacement.
C'mon man! Reads whats I's wrotes!
boxer 2.5 is offline   Reply With Quote
Old 11-19-2013, 09:14 AM   #20
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I did and hence I said it's not a small block vs big block debate.
Sent from my IBrick
Old 11-19-2013, 10:10 AM   #21
xwd
Couldn't be more wrong.
Old 11-19-2013, 12:45 PM   #22
boxer 2.5
Explain =) Compression and or tuning may play a small role. But consider:
Honda:
3.2L v-6 ~ J32A1 225hp
3.5L v-6 ~ J35Z2 272hp
Basically the same drivetrain, just a higher displacement. Even the compression ratio's are close.
Old 11-19-2013, 12:49 PM   #23
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
Honda:
lol
lickitysplit is offline   Reply With Quote
Old 11-19-2013, 12:54 PM   #24
Dephective
Drives: '13 Whiteout FRS
Honda:
You can literally take the same EXACT motor, change the runner length on the header and make more power.
Same thing could be said of changing exhaust port sizing for torque, etc.
It is NEVER just displacement.
Have you ever heard of variable valve timing? What about cams? what about piston speeds? What about number of cylinders with same displacement?
You clearly hadn't thought this through.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 11-19-2013, 12:59 PM   #25
Dephective
Also, for those that want to get rid of DI..
There's a reason Audi, BMW, Merc and now virtually every other car manufacturer are going that route. Consider for the last decade that they have had pretty much flat torque curves (and gobs of it too) on shitty pump gas on tiny 4 cyl turbo applications. That doesn't happen without DI. DI does not only atomize the fuel better, it cools piston heads and the combustion chamber immensely. There's no way Subaru would have even considered running a 12.5 CR on shitty pump gas if it weren't for DI. Just because you guys can't figure it out, doesn't make it bad.
Edit: OP, if you want to throw boost at your car, change the pistons to a slightly lower CR like 10:1. Stock rods should be plenty enough for you unless you are going to be beating on her like she owed you money. Our rods are the same that go into the FA20DIT that will be in the new WRX as well as already in the Forester. If they are good enough for 295/295 factory, I'm sure they will be just fine for a little more than that.
Previous:
'01 Accord-daily
Old 11-20-2013, 01:56 AM   #26
boxer 2.5
Engine Swap Whiteoutjames Engine Swaps 21 02-25-2013 09:54 AM
4-AGE engine swap on FR-S bacon_cheese_beer Scion FR-S / Toyota 86 GT86 General Forum 31 12-16-2012 02:23 PM
4-aGE engine swap on FR-S bacon_cheese_beer Engine Swaps 13 12-15-2012 03:29 PM
Engine Swap cf6mech Engine Swaps 21 11-16-2012 02:52 AM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
