#15 |
Food for thought. Aftermarket does not mean better:
http://www.ft86club.com/forums/showp...&postcount=378
2013 Subaru BRZ
#16 | |
Drives: 2013 SWP BRZ
For example, Jon Miller, a pro driver, running NASA TTD set the TTD record at Sebring on some BC coilovers; I know he wouldn't have bothered wasting valuable TT points on some cheap BC coilovers if he'd get more out of the stock suspension than that and use the TT points elsewhere. (video below) If you know how to setup and tune suspension, and work with what you have, it makes all the difference in the world. I've seen guys loose time after dumping 4k in the suspension, simply because they have no idea how to tune the settings on their high dollar suspension. [ame="https://www.youtube.com/watch?v=1u-5J6_nkAk"]Jon Miller: NASA TTD Lap Record, Sebring International Raceway - YouTube[/ame] |
#17 |
You're totally right that setting up the suspension properly is key, and the most important factor.
2013 Subaru BRZ
#18 |
Drives: 2013 FRS, 2008 R32
#19 |
Several things come to mind. Yeah a properly damped car is important, but also going with a vendor who help you set the car up BEYOND the initial single item you buy, and who understands the car and YOUR needs with your build etc. Also being able to reach them on weekends when you are AT the track and are not too sure of which way to go with an issue etc.
I used to tell people, " not sure who to buy from? call them on a sat or sunday afternoon with a question.. who ever answers or hell, even calls back...buy from them..". Support of the product is almost as important as the product itself. Myles Williams Racecomp Engineering LLC Since 2003 |
#20 | |
#21 |
#22 | |
Drives: 2013 FRS
I also suggest not to buy a budget suspension. The problem with budget suspensions is that they don't do many things well. And those shortcomings (like poor high freq damping) is something that you feel every second that you drive the car. Add in other issues like longevity and noise and you are left with a car that, in some ways, is less functional that it was when it had a stock suspension. When you want to upgrade the suspension, make sure it is an upgrade. Unfortunately, this means stepping up to high quality (less affordable) products from Ohlins, JRZ, etc,. You won't regret it. Just my 2c, Shiv |
#23 |
Ground Control has the exact thing you're looking for, under your budget. Plus Koni and Eibach are known quantities on track/autox.
#24 | |
Myles |
#25 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
I've heard positive feedback from the following:
Feal 441 Fortune 500/510 BC BR Type Tarmac 0 As much as you'll hear people bash BC, most of the hate is directed at the fallacy that a cheap coilover is a bad coilover. Setup matters a ton. If it means anything to you, Feal has cars doing well in Drift, Autocross and Time attack, and along with Fortune are revalvable and rebuildable in the U.S. |
#26 |
blowhard
Drives: frs, project forester
Was pretty much set on the feal coils. which are low 14 range shipped iirc.
Then recently found a set of new kwv3 for $1760 shipped. Figured it was worth the few hundred extra. May or may not end up being a good move. Still haven't installed. to whoever said swifts on fortune auto coils, swifts are a $300ish upgrade on those. |
#27 | |
Care to share where you got those V3s for so cheap? |
#28 |
blowhard
pm sent, was a vet day coupon code
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| Is $1500 off MSRP on a 2013 reasonable? | gutbuster | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 09-09-2013 03:02 PM |
| Stock wheels and Tires in PA <1500 miles | FReSh | Wheels and Tires | 3 | 05-26-2013 05:08 PM |
| Extra 1500 Toyota 86 cars on the way | Cruiser | AUSTRALIA | 37 | 10-26-2012 12:01 AM |
