#15 |
Drives: Attitude
Even if you're not interested in the kit, I highly recommend reading the technical posts. Some of it's marketing for sure, but there's a lot of great brake information that you will find useful even if only retained in your repository of knowledge.
#16 | |
We're on track to average around 8-15 days per set of pads (depends on the track... Laguna Seca and Auto Club Speedway are murderous on brakes), which is roughly 2.5x longer than pads on the stock calipers. However, the pads themselves, on average, cost about 5-25% more. OEM size pads typically last 2-4 days, depending on the track. OEM rotors or replacements average about $200/pair (ballpark) for the fronts, and typically last 1 set of pads (for us) when they're on the verge of fully cracking. The increased life is a function of a larger pad(50% thicker, ~85% more pad material), larger (thicker) rotor, increased cooling area (more vanes, more surface area), and increased heat sinking with larger components. Keep in mind that less experienced drivers will probably have reduced wear rates, but the increase in brake life will still be consistent. The numbers: 2-4x pad life for 1.2x the cost. 3-4x rotor life for 1.5x the cost. Additionally, if you do decide to sell the BBK at a later point, you'll recoup a lot of the initial investment in purchasing the BBK to begin with. While absolute braking performance isn't increased, the BBK will allow for much finer control when you're modulating the brakes, whether its threshold braking, trail braking, or left foot braking, and give you massively increased heat capacity. There is a minor performance gain from having less unsprung and less rotational mass. Anyone who is tracking more than a few times a year will save money with a BBK. @ImperiousRex is at about 15 track days on his current set of pads, and has around 2/3 of the pad remaining. @D1cker is at about 5 track days on his current pads, and has over 75% remaining. |
#17 | |
Drives: 2013 SWP BRZ
15 days is incredible on a set of pads. I'm getting about 4-6 days out of mine, depending on what pad combo, but mostly at Sebring, which is very hard on brakes. Hey @Dave-ROR, what are you seeing at Sebring with your AP kit? |
#18 | |
Drives: Attitude
Not the rotor I'd go with...but I see it is possible to get cheapo blanks. |
#19 | |
![]() I stick to Brembo blanks on my own car, with Centric Premium as a backup when I can't get Brembos (I usually buy a stack at a time...) |
#20 |
Drives: Attitude
Agreed. Brembo blanks are fucking pricey though.
#21 |
#22 |
Drives: Attitude
Good thing we have no such design limitation! The Brembo blanks in STI size were hideously expensive if I recall...but I had no qualms about running a DBA rotor in that application.
#23 | |
My wheels need a 20mm spacer to clear the Sprint kit on the S2k... which would mean I need a widebody or at least wide fenders. My fenders are already rolled and pulled... This is a CSG customer's car... you can see how tight the clearance is. He's running track camber (the car is tracked regularly).
#24 |
Thanks
Showing all the little things considered when this car was designed.
#25 |
Drives: Attitude
#26 |
#27 | |
I went with the Centric "premiums": http://www.knsbrakes.com/c/car-serie...-+Single+Rotor They're fairing better than the OEM rotors did on my first 2 days out with them on track, even with a more aggressive pad setup than I had with the OEM rotors (more front bias on my XR2/XR4 combo now than my DTC-60 square setup that I ran on the original rotors). |
#28 |
Drives: Attitude
Premiums are decent rotors, but no directional vanes or any fancy stuff like that...which ultimately is going to help your braking performance at the track.
| This is how much we like our AP Racing/Essex "Sprint" BBK... | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-06-2013 11:30 AM |
| Question about Long-Term "Garaging" | arleewa | BRZ First-Gen (2012+) — General Topics | 25 | 01-12-2013 09:13 PM |
| Some FR-S "news" (pricing update) | Sport-Tech | CANADA | 19 | 03-24-2012 10:31 PM |
| Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-19-2010 02:53 PM |
