Old 06-04-2015, 02:38 AM   #15
OmarYasin
OmarYasin's Avatar
These were good for about 2 days of dd 10miles a dayName:  uploadfromtaptalk1433396304848.jpg
Installed by a professional shop. When car was on the lift i did not see any tears.
OmarYasin is offline   Reply With Quote
Old 06-04-2015, 09:37 AM   #16
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Subbed
hmong337 is offline   Reply With Quote
Old 10-05-2016, 06:28 PM   #17
twag4
Drives: frs
If anyone is interested: I know whiteline discontinued these, but there are still some available. I had the same problem with my kit. After being installed for around 6 months, one of the ball joint boots was torn, and the other, as well as the two tie rod ends were about to tear. In Oder to get them replaced, or get my money back, I was going to have to pull them all off, send them back, wait for a determination, and then get a replacement set or a credit. Meanwhile, put stock stuff back on and pay for re-alignment. No thanks. I found this website http://dustboots.eu/catalogs/ball-jo...boots-size.htm. When I measured the stock boots from my Oem parts, then found the closest fit on that website, it took me to an eBay vendor. I ordered these two: http://www.ebay.com/itm/161717483491...%3AMEBIDX%3AIT, and http://www.ebay.com/itm/161802538801...%3AMEBIDX%3AIT. I have them on now, they are polyurethane, and much tougher than the whiteline dustboots. They are slightly larger, which is what I believe was the problem with whiteline ball joint boots- too small. There was zero contamination in the one with the torn boot, as I believe I caught it in time. Anyway, buys me some time to get some better roll center ball joints. BTW, I love the whole of all my suspension mods. These fixed the vagueness I felt in the steering when I lowered my car.
twag4 is offline   Reply With Quote
The Following 4 Users Say Thank You to twag4 For This Useful Post:
15limited (10-07-2016), FrostedFlakes (10-05-2016), lazyluka (06-13-2017), Tristor (02-25-2019)
Old 10-05-2016, 08:25 PM   #18
FrostedFlakes
Drives: 2013 Raven FRS
Just out of curiosity which one of the boots goes to which ball joint? I think the poly urethane boots should hold up for a long time. It wasn't the ball joints that were the issue but from your picture the boots tore easily. I assume everything should be OK now that the boots have been replaced?
Thanks.
FrostedFlakes is offline   Reply With Quote
The Following User Says Thank You to FrostedFlakes For This Useful Post:
Old 10-05-2016, 09:42 PM   #19
twag4
Drives: frs
The bigger one I used on the ball joint, smaller on the tie rod. I ordered several sizes, but these worked. They don't have the exact sizes that I measured. I even reused the metal retainers on the new boots. The top one on the ball joint I had to spread a little using needle nose pliers. I placed the metal ring on the outside of the pliers jaws, then spread it open. Once installed, I crushed it back on with channel locks.
The Following User Says Thank You to twag4 For This Useful Post:
Old 03-24-2017, 01:27 PM   #20
Astroboy
Astroboy's Avatar
Drives: None
Swapping my end rods tonight after my exam
Sent from my SM-T710 using Tapatalk
Astroboy is offline   Reply With Quote
Old 07-02-2017, 05:52 AM   #21
lazyluka
Drives: GT86
Thanks.
Just installed mine today, went straight for the polyboots you ordered.
Looking at the Whiteline ones I took off you could almost say they are identical on both the tie rod and the LCA. But decided to follow your advice.
For anyone else reading:
What I did with the big dust boot however is install the top retainer while the dust boot was off, then slid it on to the ball joint. Found it a lot easier this way and I could crush it closed a lot better.
lazyluka is offline   Reply With Quote
The Following User Says Thank You to lazyluka For This Useful Post:
twag4 (07-02-2017)
Old 02-12-2019, 10:30 PM   #22
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Have these other dust boots been holding up well? I have a set of these and I’m most likely going to change the boots before installing them in the first place.
TRAKRAVN is offline   Reply With Quote
Old 03-20-2019, 01:01 AM   #23
twag4
Drives: frs
Yes, still good
Old 03-26-2019, 03:47 PM   #24
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Whiteline recently released a revised version of this kit. I'm assuming the new ones don't have the tearing problem with the dust boots. Can anyone confirm?
smg1138 is offline   Reply With Quote
Old 05-27-2020, 01:02 AM   #25
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Originally Posted by Zach3794 View Post
What I wanna know is how much these raise the roll center by exactly. For those of us that may have coilovers and care, but don't want to shell out cash for completely custom arms, we can adjust our height to compliment these roll center adjusters perfectly
I'm wondering about this too...
Sent from my SM-G965U using Tapatalk
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 05-27-2020, 03:03 AM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It looks like it was around 4-6mm, I didn't measure. I am sure they would tell you if you contacted them and asked.
Old 05-27-2020, 06:08 AM   #27
Exrald
Exrald's Avatar
Thank you! I'm gonna lower the car a bit tomorrow. I'm going to have it professionally installed.
2013 Scion FRS
2022 Toyota GR86
Old 05-27-2020, 08:21 AM   #28
StraightOuttaCanadaEh
Wes
Also wondering as I’m quite interested in this
Instagram: @gt86ws
Roll centre adjustment - options & benefits? ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 08-17-2015 12:56 AM
Roll center location? :iono: BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 09-05-2014 10:20 AM
Whiteline Roll Center Kits now available at RallySport Direct! RallySport Direct Brakes, Suspension, Chassis 7 11-25-2013 06:01 PM
Whiteline releases their roll center/bump steer correction kit for the BRZ/FRS! RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 10-15-2013 06:57 PM
