Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
04-11-2012, 05:28 PM | #15 | |
Kuruma Otaku
Because titanium. |
04-11-2012, 07:12 PM | #16 | |
Drives: '06 AM V8V Coupe
The Following User Says Thank You to serialk11r For This Useful Post: | JohnnyR (04-12-2012) |
04-11-2012, 08:20 PM | #17 |
Drives: Evo 9
Fuel Additives are good when used correctly. There is always and will always be debate about it so here is my 2 cents on the matter.
I really consider there only 3 types of additives; Cleaners, Stabilizers and Boosters. Cleaners are just as they sound for cleaning dirt and built up carbon deposits that reduce performance. Personally I would use cleaners for cars with higher miles so unless you drove your FT86 around the country 10 times your probably not going to need those anytime soon. Stabilizers are for cars that are being stored or sitting for a some time. Gasoline breaks down and oxidizes which can lead to clogged injectors and sludge. Rust is also a big factor. My 2 cents, im a firm believer of stabilizers. I personally use it in my race car for storage over the winter. For you guys that will have this as your garage queen, i might look into using it. Octane boosters is the last additive and probably the most controversial of them all. (Putting My Fire Jacket On) These are designed up obviously increase the octane of your fuel. Purpose being to reduces engine knock, improves ignition and engine response, helps fuel burn cleaner and inhibits corrosion. Now to each his own on if it works or not. My 2 cents I like to use it when im forced to get gas in lower grade stations that i know has crap gas. So im not going to be pro or con against it.. you guys can figure out what you like or not. Heres a link to all our fuel additives http://www.amsoil.com/a/Fuel-Additiv...ver?zo=5001506 Last edited by Joe@Amsoil; 04-12-2012 at 07:14 AM. |
The Following User Says Thank You to Joe@Amsoil For This Useful Post: | suprachica79 (04-12-2012) |
04-11-2012, 09:18 PM | #18 | |
Attack By Demons
Drives: 2022 BRZ (pre ordered)
case closed!!
#attackbydemons #imcomingbackbish
04-12-2012, 12:15 AM | #19 | |
Ninja Cat Mod
Education is Important, but Race Cars are more Importanter |
04-12-2012, 01:27 PM | #20 |
Drives: 04 Evo 8
I came in here to post about the great AMSOIL stuff. Saw I was beaten like a rented mule. "Cleaners" are not too bad a choice for those who have to deal with that crap winter blend fuel. I always run two tanks of cleaner after it's been confirmed the "winter blend" is done. Had great luck with that.
BTW - I'd also recommend AMSOIL for oil changes. You pay more, but you get more all around out of it. Others will argue that cheapo mobile-1 and stuff is just as good, but I've ran nothing through my Evo but that, and at 50k miles, it doesn't burn a drop, and the engine is still smooth running and starting, like new. So I'm sticking to it, and recommend it. PS - Thankfully they shot down 15-20% Eth blend gases for now basically. I'd steer clear of that once it does come into the field if possible. |
04-12-2012, 01:29 PM | #21 | |
Techmology.
Drives: Scrapped project EH2
Joe, if you don't mind me asking, how is Amsoil's octane booster any different than all the other ones you see on the market? I'll tell you right now that I believe all octane booster fuel additives are a complete waste of money due to my own testing. Also, upon reading the fine print on the back of the bottle I usually notice something to the effect of "octane points increase based on treatment of one gallon". The only way to effectively boost the octane in your fuel with these products is to be adding 10+ bottles of it, which is ridiculously expensive. An octance increase of 7 points with up to 15 gallons with only one 12oz bottle..? I don't think so. Don't get me wrong, I've used other Amsoil products in the past and I think they've been a good value, but I don't see this particular fuel additive as being one of them. |
The Following User Says Thank You to mrtodd For This Useful Post: | Evil86 (06-11-2012) |
04-12-2012, 01:53 PM | #22 | |
Drives: Evo 9
Thanks Johnny for the recommendation! Nice to see a fellow Evo owner as well! |
The Following User Says Thank You to Joe@Amsoil For This Useful Post: | JohnnyR (04-12-2012) |
04-15-2012, 01:02 PM | #23 |
Techmology.
Joe, please respond to my comment above.
04-16-2012, 05:28 PM | #24 | |
Drives: Evo 9
On to your question. Our Amsoil octane boost is a more user friendly product then a lot of the others. Some of these other octane boosters require exact measurements or 20 bottles for a tank. Our Octane Booster is straight forward. 12oz bottle for 15 gallons of gas. We also do not have any solvents in our booster so its not going to destroy your fuel system. Im not sure where you got the 7 points for single bottle but were about 3-4 points. Perfect for the 93 octane car that gets caught in a 91 octane only state. Remember this isnt designed to turn 93 pump into 100 octane race gas. Its designed for race applications to bump up the octane levels a few points to help reduce pre-ignition. |
04-17-2012, 12:18 AM | #25 | ||
Techmology.
NOW - this seems to be the question of the day: what does Amsoil mean by "points", exactly? From my experience, in regards to octane boosters, points means a tenth of a point in the AKI (Anti-Knock Index, aka [RON+MON]/2 method). So for example, the 12-oz bottle *could* increase a full tank of 91 pump octane to 91.7, according to their claims...this sounds a little more reasonable. I'm not trying to start an argument, nor am I questioning your credibility; but, I just don't think octane boosters are worth it from ANY company. IMHO, Xylene is the best bang for your buck, easiest to get a hold of, plus it doesn't absorb water like alcohols (ie hydroxy functional group attaching to H20 molecules, whereas Xylene, which is simply a benzene with two methyl groups, is all hydrocarbons just like regular gasoline, just substantially more stable due to the benzene ring) - add in about 10% and there's your 2-3 full octane points. Last edited by mrtodd; 04-17-2012 at 12:52 AM. |
04-17-2012, 12:31 AM | #26 |
Re-member
Drives: Toyota camry
The thing with additives is that people don't understand the difference between correlation and causation. Just cause you put additives in you EVO and it is still running like a champ doesn't mean the additives did anything.
Nothing decays like progress, and nothing preserves like neglect.
04-17-2012, 12:50 AM | #27 |
Techmology.
04-17-2012, 01:24 PM | #28 | |
Drives: Evo 9
Oh no worries Mr Todd. Im not taking it as an argument. Im not here to try and convince anyone that Fuel Additives are must haves and everyone needs to have them or else their cars will implode. Im just here to provide information so that you the consumer can make an educated decision as to if you want to use them or not. You stated from the very beginning that you think they don't work and that is 100% ok with me. Everyone will have their own opinions about products. Some will swear by it, some will hate it. Thats the beauty of a forum, its a place to ask questions, state your opinions and find facts to make educated decisions. As for your question its a great one. Im not sure why on the site it says up to 7 points when we see 3-4 points for 12oz to 15 gallons. Let me give a call over to our tech guys and drill down deeper into your questions. And I 100% agree with you as will everyone else. The right thing to do is buy quality gas from the very beginning. As I had stated before, the octane booster is designed for race applications to prevent preignition. |
The Following User Says Thank You to Joe@Amsoil For This Useful Post: | mrtodd (04-20-2012) |
Similar Threads | ||||
Fuel Filler is on the Right!! | Guaruja | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 04-01-2012 05:55 PM |
Premium Fuel | riceracer8888 | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 12-16-2011 10:27 AM |
Wrong Fuel | Hawx | AUSTRALIA | 22 | 12-11-2011 06:08 PM |
E85 Fuel? | Siriusly.Andrew | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 02-11-2010 05:00 PM |
Flex Fuel? | VenomRush | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 01-15-2010 02:55 AM |
