Old 10-06-2013, 06:13 PM   #15
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I'm quite keen now that the beta get out into the wild, so I can trawl around other areas of the rom that will require user feedback. For example, I think these tables are the fuel pump duty cycle low tables, but would require testing:
Code:
ROM:000CEF2C Table_Fuel_Pump_Duty_Cycle_Low_A:.data.w 2 ; DATA XREF: sub_72C9C+Ao
ROM:000CEF2C                                         ; sub_72CDC:off_72E94o ...
ROM:000CEF2E                 .data.w 2
ROM:000CEF30                 .data.l flt_118E30      ; Battery Volts
ROM:000CEF34                 .data.l flt_118E38      ; MRP
ROM:000CEF38                 .data.l flt_118E40
ROM:000CEF3C                 .data.l 0
ROM:000CEF40 Table_Fuel_Pump_Duty_Cycle_Low_B:.data.w 2 ; DATA XREF: sub_73174:loc_7325Eo
ROM:000CEF40                                         ; sub_73378:off_733DCo
ROM:000CEF42                 .data.w 2
ROM:000CEF44                 .data.l flt_118E50
ROM:000CEF48                 .data.l flt_118E58
ROM:000CEF4C                 .data.l flt_118E60
ROM:000CEF50                 .data.l 0
Td-d is offline   Reply With Quote
Old 10-06-2013, 06:21 PM   #16
jamesm
Code:
if you need anything specific once it's out let me know.. i'll be taking a couple days off work to play once it releases i'd love to help any way i can.
Old 10-07-2013, 08:37 AM   #17
ft_sjo
Drives: GT86
I am particularly interested in the discovery of any tables which may reference the MAP sensor, beyond the described MAP vs Port Injection table.
Old 10-07-2013, 09:52 AM   #18
Td-d
You're referring to the Port Injection MRP compensation table?
Old 10-07-2013, 03:16 PM   #19
ft_sjo
Drives: GT86
Yes.
Old 10-08-2013, 01:01 AM   #20
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by dwx View Post
Does RomRaider support the OpenFlash formatted files or vice versa? Would be nice to be able to use RR for people familiar with it for tuning and then use the OF device for actual flashing so you aren't carrying around a laptop all the time. I know BRZEdit quickly added support for the OF file format.
once inside the ecu the OF tuned file is the same as any other stock rom it can be edited by romraider. this pretty much negates the need for OFT in my opinion might as well use a true open source platform when its said and done
FA20Club.com is offline   Reply With Quote
Old 10-08-2013, 01:10 AM   #21
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Perhaps you missed the part where he said he wanted to use the OFT for flashing so he didn't have to "carry around a laptop around all the time."
dwx-- Yes of course you can use Rom Raider for map editing. The OFT is just a storage, digital multi-gauge (and soon datalogging) device. How you edit the ROMs you want to load into it is up to you. We use Tuner Pro simply because we work closely with the developer. But the Rom Raider team is doing great work themselves with their map editor and we look forward to using/supporting it as well.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Cross (12-02-2013)
Old 10-08-2013, 10:06 AM   #22
s2d4
s2d4's Avatar
Can we see your open tunes?
Old 10-08-2013, 10:26 AM   #23
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
To use RomRaider right now you need an OFT as RomRaider is just a map editor and logger. Ecuflash is not compatible with our cars yet (but this is coming very soon from what I understand) so you still need an OFT to actually push and pull your ROM.
I'd also love to look over the fa20club maps with RomRaider so I can compare with the other OTS maps that are available online. For science of course.
- AdrianG
AdrianG is offline   Reply With Quote
Old 10-08-2013, 10:41 AM   #24
ft_sjo
Drives: GT86
Don't let this turn into a shit fight.
http://www.ft86club.com/forums/showthread.php?t=48210
The Following 2 Users Say Thank You to ft_sjo For This Useful Post:
Sportsguy83 (10-08-2013), xjohnx (10-08-2013)
Old 10-08-2013, 11:37 AM   #25
s2d4
s2d4's Avatar
Sounds good, so one of them needs to be terminated.
Originally Posted by Hachiroku View Post
Failure to do so will lead to infractions and sponsorship termination.
Old 10-08-2013, 11:39 AM   #26
ft_sjo
Drives: GT86
Originally Posted by s2d4 View Post
What's the penalty in doing so?
I'll sing you a song.
Old 10-08-2013, 12:44 PM   #27
Td-d
I've added low pulse width IPW compensation and hot restart tables to the definition. If you don't know what the low pulse comps are, read this, very interesting:
Yes, please - let this thread remain constructive.
The Following 6 Users Say Thank You to Td-d For This Useful Post:
AdrianG (10-08-2013), FrX (10-08-2013), jamesm (10-08-2013), Shiv@Openflash (10-08-2013), SkullWorks (10-08-2013), Sportsguy83 (10-08-2013)
Old 10-08-2013, 01:19 PM   #28
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
If you don't know what the low pulse comps are, read this, very interesting: .
The entire set of tech articles on this site are good reading.
FrX is offline   Reply With Quote
