Old 10-10-2013, 04:01 PM   #15
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by Anthony View Post
TLDR: So the moral of the story is, by double clutching, I made my clutch last more than twice as long as most people with the same car, even though I beat the hell out of it otherwise.
Double clutching won't do a thing to make the clutch last longer. Proper rev matching on downshifts and relatively gentle starts are what make a clutch last (and the vast majority of clutch wear is in the starts). Double clutching saves wear on synchros, but it is really not necessary on any modern car.
(And that quote wasn't being serious - it was making fun of a quote from F&F 1)
chrisl is offline   Reply With Quote
Old 10-10-2013, 07:24 PM   #16
strat61caster
strat61caster's Avatar
Check out the rear tires, that will tell you more about how it was driven than anything else, mainly how many of those 10,000 kms were done sideways.
Doubt you'll have issues though, sounds like it was bought as a toy and just wasn't as interesting as the owner thought it would be.
ineedyourdiddly
jd666 (12-24-2013)
Old 10-10-2013, 11:17 PM   #17
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by chrisl View Post
Double clutching won't do a thing to make the clutch last longer. Proper rev matching on downshifts and relatively gentle starts are what make a clutch last...
Isn't rev matching part of double clutching?
Whatever you want to call it, this is what I do when I down shift, say 4th to 3rd:
Release gas and push in clutch pedal
Shift to neutral
Release clutch pedal
Blip throttle to rev match
Quickly push in clutch pedal and shift to 3rd gear
So whatever you call all that nonsense, that's what I've been doing, and my clutch lasted way long than everyone else's that I know of.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-11-2013, 02:21 PM   #18
chrisl
Shift to neutral
You can't double clutch without rev matching, but you can rev match without double clutching. Doing so would go something like this:
Shift lever from 4th to 3rd
Apply throttle to bring engine RPM up to correct engine speed for 3rd gear
Release clutch
Doing it this way won't cause any more clutch wear than the way you described. It will wear the synchros faster, but that's usually not a problem on modern transmissions.
Old 10-12-2013, 01:01 AM   #19
Anthony
Weight Nazi
Anthony's Avatar
Doesn't blipping the throttle in neutral with the clutch engaged get the clutch and flywheel spinning the same speed?
JDM Hand Brake? Mongo Cosmetic Modification (Interior/Exterior/Lighting) 3 02-28-2015 12:46 AM
FRS Hand Brake zootramp Cosmetic Modification (Interior/Exterior/Lighting) 9 11-19-2012 11:26 PM
Hand signals Fugazi BRZ First-Gen (2012+) — General Topics 7 07-27-2012 11:13 PM
First hand on the 5 axis kit CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 2 07-01-2012 06:07 PM
I'm going to try my hand on a flat 4 4agze Other Vehicles & General Automotive Discussions 2 04-08-2011 07:46 PM
