Old 07-08-2014, 02:59 PM   #15
jvincent
jvincent's Avatar
Thanks for the update.
So, based on that data, when do you think you'll change it?
It's probably not good forever so at some point you're going to do a bleed/flush.
Old 07-08-2014, 04:37 PM   #16
It's time to do it now; we generally recommend that cars that are driven hard bleed their brakes once a year as a precautionary measure, even if the fluid doesn't seem to have degraded.
It's like doing regular oil changes; you want to keep the fluids in your car fresh.
wparsons (07-08-2014)
Old 07-08-2014, 07:57 PM   #17
jvincent
jvincent's Avatar
The fresh fluid makes sense.
You guys track your cars a lot more that we do up here because of winter. I put in Project Mu fluid in the spring before my first track session and I will probably end up with 4 sessions this season.
Doing a full flush next spring is probably a good idea.
Old 07-08-2014, 10:13 PM   #18
wparsons
wparsons's Avatar
Some time attack series or lapping groups up here require fresh fluid ever year just because of how fast some fluid degrades, that's the big reason I can't swallow SRF. I think the next fluid I order will be this stuff.
flickr
Old 07-09-2014, 12:56 PM   #19
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Fully ¼ of the words on the first page of my main DE club's tech sheet is devoted to the subject of the status of the driver's brake fluid:
ALL CARS will have the brake fluid tested at the track for moisture content. You will be required to provide access to the Master Cylinder when the vehicle is presented in tech. If you are not aware of the location of the master cylinder, consult your owner’s manual or ask the qualified individual performing the Pre-Event Safety Inspection to provide access to it.
__ 4. BRAKE FLUID: Must have adequate level and be in good condition. Brakes must be bled during safety inspection. We require that vehicles used for driver's schools have brake fluid NO OLDER than six months in the system. This includes all new vehicles regardless of date of manufacture. Any vehicle failing to pass the on-site moisture content test (>= 3%) or having discolored or obviously old brake fluid will not be allowed on the track.
DATE OFLAST FLUID CHANGE:________________
Failure to pass the test is not uncommon.
dradernh is offline   Reply With Quote
Old 07-10-2014, 12:23 AM   #20
dp1
driving smoother faster
Drives: Sold
Tried RBF600 with AP Racing Sprint BBK at Watkins Glen this Mo/Tu, almost got the best of me a couple of times, never again, purchased RT700
dp1 is offline   Reply With Quote
Old 07-13-2014, 09:31 PM   #21
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
RT700 is really excellent! I've done multiple track days and 5000 miles and it still looks like new at the front calipers!
Sleepless is offline   Reply With Quote
Old 07-14-2014, 01:59 PM   #22
CSG David
CSG David's Avatar
Even with the best fluid, always consider the 1 year flush interval that the Owner's Manual recommends. DOT3 soaks moisture slower than the DOT4 fluids, but annual changes are still recommended.
I've kept the fluid in my car longer than a year for the sake of 3rd party review.
Old 07-21-2014, 06:26 AM   #23
dp1
Drives: Sold
Just got back from 2 days of tracking on the NJMP Lightning course. AP Racing Sprint BBK, Torque RT700 and Carbotech XP12 performed flawlessly. There are only two hard braking zones but they require slowing down by over 40 mph. RT700 is the only brake fluid I'll use from now on.
Old 07-23-2014, 10:47 AM   #24
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Ordered this morning along with some CR pads for the rear to balance things out a little better.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
CSG David (07-23-2014)
Old 10-20-2014, 04:27 PM   #25
normancw
normancw's Avatar
Drives: 128i
I did 9 track days this year (48 30-minute sessions) on RT700. AP Racing Sprint Kit, Ferodo DS2500 pads. Worked great - will be using this again next year!
normancw is offline   Reply With Quote
The Following User Says Thank You to normancw For This Useful Post:
Anthonytpt (02-26-2015)
Old 10-20-2014, 10:16 PM   #26
48 sessions on the same fluid?
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Anthonytpt (02-26-2015), dradernh (10-21-2014), johan (12-16-2015), wparsons (10-21-2014)
Old 10-21-2014, 10:01 AM   #27
normancw
normancw's Avatar
Drives: 128i
Yep - braked just as well during the last session as the first one!
Old 10-21-2014, 11:14 AM   #28
dradernh
Did you bleed them during that stretch of 48 sessions?
CounterSpace Garage - Authorized Dealer - Torque RT700 Racing Brake Fluid CounterSpace Garage Announcements, Contests, Giveaways 0 09-26-2013 08:33 PM
Brake fluid question barabia Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-01-2013 12:08 AM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-14-2013 12:46 AM
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 04:20 PM
Racing brake fluid promo MillersOilsUS Brakes, Suspension, Chassis 0 12-31-2012 12:29 PM
