Old 09-23-2013, 12:47 PM   #15
Skyllz
Drives: Something fun.
I'm sitting back and enjoying the show for now, users are going to be the winners here with more solutions out there
Skyllz is offline   Reply With Quote
Old 09-23-2013, 12:48 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Saw it as well. I am very interested in ECUFlash working on the BRZ, and I am willing to do anything to help.
anything.... ANYTHING???
The Following User Says Thank You to Sportsguy83 For This Useful Post:
SkullWorks (09-23-2013)
Old 09-23-2013, 12:50 PM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I knew that was coming.
The Following User Says Thank You to King Tut For This Useful Post:
Sportsguy83 (09-23-2013)
Old 09-23-2013, 01:26 PM   #18
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Yeah, Meatloaf.
Old 09-23-2013, 01:43 PM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by jsimon7777 View Post
Yeah, Meatloaf.
But I won't do that.
The Following 5 Users Say Thank You to King Tut For This Useful Post:
akuhei (09-30-2013), amram (03-24-2014), ML (09-27-2013), SkAsphalt (10-31-2013), Sportsguy83 (09-23-2013)
Old 09-23-2013, 01:54 PM   #20
EAGLE5
Dismember
EAGLE5's Avatar
Except for in a public restroom?
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 09-23-2013, 01:59 PM   #21
wparsons
wparsons's Avatar
Is there any options for people already tuned by EcuTek to use ECUFlash (short of getting a new ECU)? From what I know, EcuTek locks it so nothing else can flash to it?
flickr
Old 09-23-2013, 02:03 PM   #22
xjohnx
Grip>Slip
xjohnx's Avatar
Pretty sure there are ecutek users with the OFT, no? And i'm almost positive i've seen ECUtek and BRZEdit users. If so, i don't see why this wouldn't work. @mad_sb may be able to chime in.
Old 09-23-2013, 02:10 PM   #23
mad_sb
I believe the Ecutek'd ecu is write locked. You could read out the file then follow whatever the process is to go back to stock with ecutek. If you have an ecutek cable i assume they can give you directions, if not I assume your tuner should be able to do it. After that you should be able to flash the ecu.
If not, there are going to a shit load of people pissed off at EcuTek.
The Following User Says Thank You to mad_sb For This Useful Post:
Old 09-23-2013, 02:16 PM   #24
xjohnx
Grip>Slip
xjohnx's Avatar
just found this post from delicious that states it's not locked:
Originally Posted by DeliciousTuning View Post
When the BRZ/FRS ECU is reflashed it is NOT locked as you have shown us with OpenFlash Tablet. In fact you can pull the map right off and review it, with no problem. The ONLY systems that are truly locked with EcuTeK are the 02-05 Subaru WRX.
When the BRZ/FRS ECU is reflashed back to stock. It is as stock as it is going to be with the EcuTeK License built into the ECU ROM. You can even reflash it with other systems and this goes for all makes and models EcuTeK offers their tuning system for.
Old 09-23-2013, 02:56 PM   #25
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I wrote my ecu with an ecutek rom I pulled off a customer car. After writing it to my ecu, I could not write over it using the OFT. I couldn't even write over it using some of Rombinhood's development tools I had access to. This is due to their write protection. The only way to recover my ecu was to borrow the ecutek cable that belonged to the customer who orginally had that ecutek flash license and flash it back to stock using ecutek's stock rom file. After that I was able to do restore my flash back to stock or OFT tune status.
This is why we recommend that all ecutek users flash their ecu back to stock (with ecutek cable) before installing the OFT. Not doing so can introduce an ecutek-induced nightmare. I ended up purchasing another ecu mistakenly as I thought that the ecutek cable wouldn't work in my car due to VIN mismatch. Luckily this was not the case and I now have an extra ecu
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
mad_sb (09-28-2013), SkullWorks (09-23-2013)
Old 09-23-2013, 03:55 PM   #26
vgi
Drives: frs
Originally Posted by shiv@vishnu View Post
I wrote my ecu with an ecutek rom I pulled off a customer car. After writing it to my ecu, I could not write over it using the OFT. I couldn't even write over it using some of Rombinhood's development tools I had access to. This is due to their write protection. The only way to recover my ecu was to borrow the ecutek cable that belonged to the customer who orginally had that ecutek flash license and flash it back to stock using ecutek's stock rom file. After what I was able to do restore my flash back to stock or OFT tune status.
interesting. so EcuTech users can make a full image of their ECU using OFT and then clone it to other cars. I recon they would need to watch out for any ECU hardware differences though. Curious if we may see soon EcuTech license key generators
vgi is offline   Reply With Quote
Old 09-23-2013, 04:17 PM   #27
Shiv@Openflash
Drives: 2013 FRS
I don't know how much value there is in ecutek licenses at this point but I suppose anything is possible. That said, I was only able to read out a few ecutek roms with the OFT. Some of them were locked from being read. Or perhaps it required different reading protocol. I did not care enough to look any further.
Old 09-23-2013, 04:41 PM   #28
vgi
Drives: frs
I don't know. Why do people crack photoshop when there is a gimp
The Following User Says Thank You to vgi For This Useful Post:
WillRacer1jz (09-23-2013)
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
