Old 09-19-2013, 02:45 AM   #15
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
It sounds like people would be happy with a header and a tune if not FI. I don't think there's any options for us in California is there?
I'm happy with my FR-S, but some hypothetical builds... If you start going forged wheels and LSD upgrades.. well, that will just blow the price out of the water
Drool
Code:
$40,245 Total
$25,495 Suburu BRZ
$3,500  Supercharger
$3,000+ Big Brakes
$1,500  Coilovers
$1,000  Wheels
$1,000  Tires
$1,000  Exhaust
$1,000  Bushings & Braces
$1,000  Lip Kit (looks, not $$ track)
  $850  Header
  $400  Sway Bars
  $500  Clutch
OEM+
Code:
$32,545 Total
$25,495 Suburu BRZ
$500    Upgraded Brakes
$1,000  Coilovers [fixed height]
$1,000  Wheels
$1,000  Tires [could go lower, but PSS!]
$800    Exhaust
$500    Bushings & Braces
$1,000  Lip Kit
$850    Header
$400    Sway Bars
Remember, this this is just for S&G
Mike
mike_ekim1024 is offline   Reply With Quote
Old 09-19-2013, 02:49 AM   #16
mike_ekim1024
Originally Posted by m.wood0213 View Post
This would be my plan:
Buy all legit STi body parts from japanparts.com.(minus the big wing)
Get upgraded catted headers (FA20Club, or Nameless)
ECUTek tune
Get the STi muffler and use the JDM tips.
STi springs
STi strut tower bar.
Wilwood bbk and put STI stickers on them.
BOOM homemade USDM BRZ STi/tS!
Nice! But aren't STi parts expensive? Well, that would be more of a true STi anyway
Old 09-19-2013, 02:59 AM   #17
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
$1,000 is not OEM+ coilovers, its junk. Why would you spend $3k on stopping an already light car, but only $1.5k on the cars main highlight, its ride.
chulooz is offline   Reply With Quote
Old 09-19-2013, 03:16 AM   #18
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by wlwarfield View Post
STi = Subaru Technica International
ts = Tuned by STi
I'm pretty sure he know, that's why I was in upper case...like op's first sentence.
Old 09-19-2013, 04:03 AM   #19
ZionsWrath
Thanks
ZionsWrath's Avatar
The reason people won't take the "why wait, just build your own" is because there is a BIG difference between financing a car and putting out 10k cash on a car that is financed and being up the creek when parts start failing.
Sure on paper you might say hey you can do it all for 5k or something but modifying cars becomes a rabbit hole...
As for my "STi"
Keep OEM suspension, add camber bolt, maybe less than 1 inch lower springs. ~$500
Innovate supercharger when IC comes out ~$5,000
Robispec cooling if it will fit, or some other oil cooler and radiator ~$1,000
Exedy stage 1 clutch ~$500
Cheap 17" wheels and 245 Pilot Super Sports ~$1,500
Front BBK ~$2,000
Gauge + Install ~$500
Dyno Tuning ~$1,500
So there is a BASIC build and it totals $12,000 already and that is installing most of the parts yourself. If you are only on the street you can probably stay OEM suspension and skip the BBK and cooling, but that is still closing in on $10,000
Old 09-19-2013, 09:35 AM   #20
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Exterior:
Upgraded Aero
Small Rear Wing
Interior:
New Bucket Seats (JDM STI Seats)
Different Interior Trim (Gloss black maybe)
Altered Gauge Cluster and Steering Wheel (STI Badges)
STI Push Button Start
Wheels/Brakes/Tires:
17" BBS Wheels
Better/Wider Tires (Maybe 235/45)
STI 4pot/2pot Brakes
Suspension/Chassis:
Stiffer spring rates/struts (1-1.5" overall drop is fine)
Upgraded Bushings
Upgraded Control Arms
Thicker Sway Bars
200lb+ Weight Reduction
Engine/Drivetrain:
Improved Intake Design
Improved Header and Exhuast Design
ECU Changes
Valvetrain/Headwork (rev to 8,000rpm from the get go)
Upgraded clutch and flywheel
Lightweight Driveshaft
Approx. 230-240bhp
Honestly, if you think about it, all Subaru really needs to do is make this:
Throw on all the optional STI aftermarket parts on a BRZ limited, take off some weight, improve the handling a bit, add some power and call it a day. We're probably never gonna get some sort of F/I standard with the car so instead of pouting over it, focus on something else: weight.
Go from a 200hp, 2800lb car to a 240hp, 2500lb car. Honda S2000 power in a Miata
TylerLieberman is offline   Reply With Quote
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
mike_ekim1024 (09-19-2013), Turkish (09-21-2013)
Old 09-19-2013, 01:19 PM   #21
mike_ekim1024
There are coilovers under $1000.. I didn't go there. Are you sure there's nothing good in the $1500 range? Buddy Club? Cusco? We're not talking adjustable top of the line, just better than stock.
Mike
Old 09-19-2013, 01:29 PM   #22
infinite012
Drives: 13 DGM BRZ Ltd
Mike
Have you seen the price of the STI coilovers for the Impreza (2.5RS/i, WRX, and STI)?
infinite012 is offline   Reply With Quote
Old 09-19-2013, 01:48 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Already own my version of an STi, and it wasn't cheap to build:
http://brz.ridedomain.com
The Following 3 Users Say Thank You to King Tut For This Useful Post:
lavisxice (09-21-2013), Sportsguy83 (09-19-2013), Stierzy34 (09-21-2013)
Old 09-19-2013, 01:58 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Here's my STI:
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
ftc~brz (09-19-2013), mike_ekim1024 (09-19-2013)
Old 09-19-2013, 04:03 PM   #25
chulooz
Registered you sir
chulooz's Avatar
Mike
Sorry, those are all essentially junk on a dyno.
Old 09-19-2013, 04:09 PM   #26
ftc~brz
Done
Drives: WRB BRZ
Originally Posted by Sportsguy83 View Post
Here's my STI:
what he said…
David, your car is my Sti as well sir
ftc~brz is offline   Reply With Quote
The Following User Says Thank You to ftc~brz For This Useful Post:
Old 09-19-2013, 04:10 PM   #27
Sportsguy83
Drives: Limited BRZ
Tarmac Zero's are $1300 and are REALLY good, not junk at all.
OEM+
Old 09-19-2013, 04:29 PM   #28
chulooz
Registered you sir
chulooz's Avatar
OEM+
How do you know they are really good? The only read way to prove that would be a shock dyno, have you ever seen taramc zeros perform on a shock dyno?
