#15 |
Drives: BRZ Limited DGM
just cut the belt off, you'll be fine. promise.
#16 |
Drives: 2012 Toyota 86
"The electric motor assisting the BRZ’s rack is mounted high up on the firewall, contributing to a slightly higher center of gravity but simultaneously shifting the front/rear weight balance a touch rearward."
http://www.caranddriver.com/reviews/...t-drive-review |
#17 |
Because compromise ®
Drives: Red Herring
The motor weighs how much? I am suggesting a lot of that article was written from marketing release sheets.
#18 |
from what ive read, electric power steering motors are somewhat heavy. my uneducated guess would be 5-10lbs. not worth removing to me, but for weight savings, every little bit adds up.
#19 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
If driving without it won't damage the steering system, you can consider mine already out.
It seems to me like turning at extremely slow speeds might put too much torque on the steering rack. But if that's the only potential problem, all you have to do is make sure you've always got at least a little bit of speed before you start turning. Not good for a daily driver, but mine is not a daily driver.
#20 |
Drives: FR-S 6MT
#21 |
Weight Nazi
Only 997lbs after you take out the power steering.
#22 | |
Drives: FR-S 6MT
I'm sure you can handle it though.. |
#23 |
Weight Nazi
So you think deleting the power steering in our cars would result in an ugly situation?
#24 |
I personally much prefer a car with a true manual steering rack, but simply deleting the power steering, while maintaing a power rack will result in less than optimal steering. I have driven in cars with both setups and there really is a HUGE difference.
#25 | |
Drives: FR-S 6MT
You can probably pull a fuse or a relay and check it out yourself without much fuss.. I have no interest in doing so.. |
#26 | |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
That's it. I'm taking out the motor. And transmission. I'm going full on BEDROCK BUILD, YO I don't want power anything. All I need to do is cut a hole in the floor board on both driver and passenger Yabba dabba doo! Meet the flint stones, bare foot powered 86, coming soon. ![]()
#27 |
Weight Nazi
I'll be home in about 2 months, so if no one has tried it by then, I'll give it a go. I expect it to feel ridiculously heavy without the assist though. We shall see...
#28 |
i took a look at the motor today out of curiosity. it looks huge and heavy, and a giant pain in the ass to remove, if even possible. i also drove my car down a hill with the engine off, it was pretty tough to turn under 30k.
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| scion frs steering wheel air bag and steering wheel | Jhon19lopez | Interior Parts (Incl. Lighting) | 7 | 01-04-2014 06:04 PM |
| What is your prediction on FT86 power and Subaru 086a power? | 86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 08-26-2013 11:49 PM |
| Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 10:11 AM |
