Old 09-24-2013, 08:52 PM   #15
Turbowned
Turbowned's Avatar
Interdasting... can't wait to see the outcome!
Old 09-24-2013, 10:06 PM   #16
utekineir
blowhard
Drives: frs, project forester
Not bolted yet, my drill bit stash is basically spent. The sagging left bolster is because the airbag is removed.
Impressions so far.
Massive pain in the ass shaving the rails
headroom gain exists, but is less than I was hoping for. There definitely would be probably no headroom gain with the standard rx8 cloth cushions. They are far less dished than the recaro base.
spacing on the frs mounting points does not line up with rx8 rails. so extra material will be necessary, right now i'm torn between the pictured iron or picking up a planted base. Problem being the rx8 rails are spaced wider than the frs rails, looking at the holes on the planted base pictures it may not work without drilling, and that may be a bit close to the edge of the material.
Frs mounting hole width 15.75" rear (center to center)
Rx8 rail hole width roughly 17"
about $250 in at this point.
utekineir is offline   Reply With Quote
Old 09-25-2013, 12:20 AM   #17
van_fc3s
Drives: GT86
i lnow ive asked this on another post but what if you use frs base and sloders, would that be easier?
van_fc3s is offline   Reply With Quote
Old 09-25-2013, 12:28 AM   #18
utekineir
blowhard
entirely different seat design, but, where theres a will (time and money) theres a way,
but at this point the only thing left to do is drill and bolt, or buy a base
Old 09-25-2013, 12:45 AM   #19
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Installed pics?
448hpsti is offline   Reply With Quote
Old 09-25-2013, 06:59 AM   #20
utekineir
blowhard
Originally Posted by 448hpsti View Post
Installed pics?
http://www.ft86club.com/forums/showp...0&postcount=16
Old 09-25-2013, 05:44 PM   #21
utekineir
blowhard
Planted base wasn't available locally. Got some good drill bits and got it mounted to the iron.
Rear right corner uses the factory seat bolt through the rx8 slider and iron. the other 3 corners use grade 8 bolts, washers, lock washer.
Seatbelt bolted over perfectly. Airbag resistor in place. Going to give this a couple days to see how it is then pull, trim the front of the rails, paint and maybe rig the frs airbag into the bolster pocket.
Harness slots fit me as well as a sportster cs ( <1" below shoulders) Headroom improved from stock with stretched springs. Bolsters are more snug than the sportster but I am 6'3" 250, snug happens.
Old 09-26-2013, 12:19 PM   #22
utekineir
blowhard
Swapped in side airbag.
Majority of time was spent pulling the frs bag.
Both use 2 bolts facing inward. Lined up one hole drilled one for other.
Foam could use some trimming now to eliminate lump on outside of bolster from length difference. The frs bag is longer.
Old 09-27-2013, 03:46 PM   #23
utekineir
blowhard
Used some leather cleaner, trimmed and painted the iron
Old 09-27-2013, 03:58 PM   #24
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
LOOKS GREAT
DuMa is offline   Reply With Quote
Old 09-27-2013, 09:30 PM   #25
utekineir
blowhard
thanks,
this is the plain cloth base for comparison, much less dished, not sure it would work for extra headroom.
Old 12-29-2013, 06:16 PM   #26
Mahhn
Guest
Posts: n/a
utekineir, would you please post a few pics of the bottom of the original seat? I am trying to figure out if I can replace the adjustment bracket with a plate or two, to lower the seat 2 inches. I don't mind making it immobile.
Thanks,
Old 12-29-2013, 07:17 PM   #27
Cooper911
Drives: scion frs asphalt 2013
no air bag light on ??
Cooper911 is offline   Reply With Quote
Old 12-29-2013, 07:20 PM   #28
utekineir
blowhard
http://www.ft86club.com/forums/showp...3&postcount=22
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Passenger seat belt warning when I put phone on seat!??? Kayzer Soze BRZ First-Gen (2012+) — General Topics 20 09-13-2013 11:29 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
Seat and seat belt torque specs TheSt|G Scion FR-S / Toyota 86 GT86 General Forum 2 11-01-2012 09:52 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
