Old 09-18-2013, 06:26 PM   #15
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Originally Posted by Argento_FR-S View Post
He didn't have a half assed setup... his clutch gave out and created valve float. That has nothing to do with the nitrous setup. You can recreate the same thing by loading your drivetrain heavily and then stomping on the clutch releasing the load from the motor. Something will most likely give...
He didn't have a window switch though or any safety to cut nitrous if he hit redline. When his clutch slipped his motor spiked to redline and cut throttle while still spraying nitrous I think that's what frs300 meant by half assed
Nolan
pheoxs is offline   Reply With Quote
The Following 2 Users Say Thank You to pheoxs For This Useful Post:
brznoob (11-24-2014), Frs300 (09-18-2013)
Old 10-21-2014, 04:39 AM   #16
brznoob
brznoob's Avatar
Drives: 2014 subaru brz Limited 6mt
Originally Posted by ender2664 View Post
Anyone running nitrous on their car? Anyone been running nitrous long term? Anyone know what the best kit and largest shot the car can take on the stock fuel system is? Anyone know a shop in or near southern california that could tune a nitrous frs well?
50 is the largest you should run without upgrading your fuel pump and plugs.
brznoob is offline   Reply With Quote
Old 10-21-2014, 04:45 AM   #17
brznoob
brznoob's Avatar
Originally Posted by rusty959 View Post
I didn't read the thread again, but I am pretty sure you are right that it was on a dyno, but the root cause was he redlined it while spraying, which is bad news.
It's bad news if you don't have an rpm window switch. This device prevents from spraying after the rpm limit you set.(NX recommends 200rpm before rev limiter)
He didn't upgrade his fuel pump which is required for 75 and up and he was trying 100.
On 75 NX recommends to change the plugs to 1 degree colder and for 100 is a must.
He never mentioned retarding the timing.
Nitrous didn't blow his engine, the kit didn't blow his engine, HE DID
The Following 2 Users Say Thank You to brznoob For This Useful Post:
DriftinFRS (10-21-2014), mrk1 (10-21-2014)
Old 02-28-2015, 08:10 PM   #18
brznoob
brznoob's Avatar
NX Stage 2 EFI kit 50 shot E85
Kit is finally running. Still needs some adjustments (having issues finding the tach signal in the brz limited.) rpm window switch is all wired except for the tach signal. Using TPS for the time being, and feels great. TrueStreet Performance, the shop where I fill my bottle says a 10lb bottle running a 50 shot should be good for up to 22 passes in the drag strip. Not interested in the drag racing stuff but based on these calculations bottle might be good for the whole month depending on driving habits.
2014 BRZ Limited 6MT World Rally Blue.
Mods: Tomei UEL header, Tomei overpipe, HKS Dual Resonated Front Pipe, Stock Catback, JR C30 kit with HBP, DW700cc injectors, DW 65C pump, Delicious Tuning FF kit, Forrester XT oilcooler, ACT HD Street clutch, ecutek #mototuned.
The Following User Says Thank You to brznoob For This Useful Post:
GT86_PRAGUE (06-14-2015)
Old 04-08-2015, 05:43 PM   #19
Zex_Frs
Just another bottled FRS
Zex_Frs's Avatar
Drives: 2014 Scion Frs on Bottle
hey you finally found the problem with the tach signal will be putting my window switch soon so incase the same thing happens to me i can have an idea of whats going on. how the car feels on a 50 shot i try a 75 before and was pretty fun!!!
Just a regular FRS powered by a purple Zex bottle!!!
Zex_Frs is offline   Reply With Quote
The Following User Says Thank You to Zex_Frs For This Useful Post:
brznoob (04-10-2015)
Old 04-08-2015, 05:46 PM   #20
Zex_Frs
Zex_Frs's Avatar
hey is my set up not finish yet since i removed everything and im redoing it nicely this time but ran a wet 75 shot for about 7 passes or so one night and had a blast this time hopefully my ecutek tuner can tune on a 100 safely if not i guess is back to the 75.
Old 04-09-2015, 09:18 PM   #21
stevo585
Drives: White 2014 BRZ
Cool your like the only person that runs nitrous lol. What was your e.t. and trap speeds?
stevo585 is offline   Reply With Quote
Old 04-10-2015, 01:08 AM   #22
brznoob
brznoob's Avatar
Still haven't hooked up the tach signal. It's been a pain. Well regarding the 50 shot is not really a 50 shot for me as I'm running E85 is more like a 35 shot. Though I'm not running lean I want to get the right jets to produce a 50 shot
Old 04-10-2015, 03:10 PM   #23
chaoscentral
Drives: 2013 Scion FR-S Series 10
Ditto, I'd like to know this as well, planning on picking up a kit soon so I'm curious
chaoscentral is offline   Reply With Quote
Old 04-13-2015, 06:00 PM   #24
Zex_Frs
Zex_Frs's Avatar
yea i been searching info on the jet size to run e85 pll had tols me it should be the stander fuel jet multiply by 1.5 so it ends up been .5 bigger than the fuel jet used for pump gas so i guess i will take a couple of jet when ever i go tune and hopefully gt it right.
As for track i never took mine but can tell you completely stock just borla uel headers and a 75 shoot no tune no bottle heater the car stay of a trans am ls1 by a car that same trans am beat me by around 7 cars or more with out the bottle.
Old 04-13-2015, 06:22 PM   #25
brznoob
brznoob's Avatar
I do have the jetting info for E85 for NX. 50 shot in gasoline feels great and the car sounds bad ass when you spray it lol.
Old 04-14-2015, 12:25 PM   #26
Zex_Frs
Zex_Frs's Avatar
Mind sharing what jet size you will b e using and who you got them from i know the zex kit might be different but at least to compared i dont wanna be to off when i chose my jets
Old 04-18-2015, 01:03 PM   #27
savaged
Drives: 2013 FRS/86
I also use nitrous, the Nitrous Express plate kit to be exact. I jet for 75 or 100 depending on the trouble I plan on being in. It's been bithing but a pleasurable experience. When done correctly, desirable gains and sure to turn heads.
savaged is offline   Reply With Quote
Old 04-18-2015, 10:07 PM   #28
mrk1
Drives: Sterling BRZ Ltd
Awesome to hear.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Any nitrous apps yet? 86pro Forced Induction 20 02-07-2014 12:00 PM
Nitrous System for FR-S/BRZ Titanmotorsports Engine, Exhaust, Bolt-Ons 18 04-26-2013 07:30 PM
Anyone running with Nitrous? JDMenrique Forced Induction 29 10-21-2012 11:02 PM
nitrous eindio Forced Induction 17 09-22-2012 02:09 AM
Supercharged HKS car on nitrous? Lawnik Forced Induction 3 09-04-2012 12:47 AM
