#15 |
Klaatu barada nikto
Drives: Raven FR-S MT
+1 on the brake measurements. Front and rear please, and if possible, the weight of the whole system(rotors and calipers). I've been talking with Miguel at Wilwood, he said they are working on a BBK for the FR-S which is six piston front and four piston rear. I think this is a bit of overkill. My only concern with going with a BBK is unsprung weight.
Thanks in advance.
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) |
#16 |
'it's the yeti of Texas'
Drives: 2013 Whiteout 6MT FR-S
BRZerhood & FR-Society
#17 |
Drives: 2011 528
I know that this following request has nothing to do with measuring but I would love to know what electrical modifications have to be made to swap the headlights to the JDM GT86 headlights(fuses, wiring,etc.). I'm crossing my fingers and hoping that it is zero.
#18 |
popular among the JDM
Drives: 2014 BRZ Limited
If you could please determine if Impreza camber plates will fit the BRZ, I would be thrilled. The dimensions look the same from photos.
#19 |
Resident HoneyBadger
Drives: Toyota Tacoma TRD Off-Road
Ground clearance please? I wanna know if i'm gonna curb my front bumper,etc on these shitty San Frisko roads.
#20 |
Drives: Monkey-butt red FR-S
wheel width, diameter and offset. Swaybar diameter. Spring rates. Overall vehicle weight and % front and rear. Engine torque curve. Center of gravity and roll center heights for front and rear.
#21 |
Drives: N/A
If you could get the differential size,(I'm forgetting the measurement ATM, but I'm thinking of the axle(in MM) for durability purposes and not the diff housing), the rear axle diameter, and would you please confirm the transmission model(w/ pics if you can). I would very much appreciate it.
#22 |
rookie drifter
Drives: 1987 ae86, 1985 celica gts
every specs for brakes, caliper mounting bracket on the Hub, wheel bearing mounting bolt pattern to the Hub, ABS speed sensor position
remove the inner tie-rod ends to see if we can fit some spacers on inner tie-rod ends like many companies sell for Nissan S models and AE86, that gives us more steering angle for drift purpose, for really cheap, you only have to remove one inner tie-rod end and move the steering rack for it to enter inside the steering rack, it should give an idea if a spacer can be fitted thank you very much |
#23 |
Drives: 2013 BRZ DGM
Overall size of the engine bay.
#24 |
Ok, will do guys. We will keep a list of these and anymore that get posted up. We will try to get to as many of them as possible.
Justin |
#25 |
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
+1 on wheel gap (tires to fender)
SPECIAL EDITION VIN LISTS: |
#26 |
Pavement Grey
Another one for Ground clearance.
Hate getting my ass kicked by speedbumps. Plus to compare with my current ground clearance (which any lower and i wuld probably hate it) |
#27 |
Site Moderator
Drives: Stuff
5.9" for ground clearance I thought?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#28 |
Drives: SWP BRZ
Would like the measurements of the inside of the front tire to the front spring/perch/strut (whatever is closest to the tire) and the measurement from the outside of the tire to the inside of the fender lip. Obviously i would like to calculate tire width and offset limits. Also could this be done for the rear?
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| BRZ Photos Showing Interior Measurements, Stereo UI, Trunk, Etc. | Deslock | BRZ First-Gen (2012+) — General Topics | 85 | 03-21-2012 10:17 PM |
| Photos Of Interior Measurements, Trunk, etc | Deslock | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 03-20-2012 08:32 PM |
