Old 09-06-2013, 10:54 PM   #15
ATSAaron
Drives: 2013 Raven FR-S
Originally Posted by Sportsguy83 View Post
Yeah, I don't think it specifically needs to be three of them, but it needs to be bolted in place if not the car will not start.
The ECU/CPU to the bracket over the passenger side port injectors. Is that the EDU? Or is the EDU the other electrical box that (I think) drives the direct inejctors?
Aaron
ATSAaron is offline   Reply With Quote
Old 09-06-2013, 10:57 PM   #16
ATSAaron
Also whitefrs, what size injectors are you using at the time of this log?
Aaron
Old 09-06-2013, 10:59 PM   #17
ATSAaron
Originally Posted by whitefrs View Post
lol
i dropped mine
You guys are funny. It would probably work fine with just one. We added a short jumper wire with alligator clips to test our solution first.
Aaron
Old 09-06-2013, 11:00 PM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
1000cc but i forgot to mention im on e85 which has 30% more tfuel than 93
Old 09-06-2013, 11:06 PM   #19
ATSAaron
Me too. Thanks 1000 times. I won't get to upload a new tune until Monday but you have given me hope!
Aaron
Old 09-06-2013, 11:16 PM   #20
xjohnx
Grip>Slip
xjohnx's Avatar
@mad_sb is who i would bug.
Old 09-06-2013, 11:24 PM   #21
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Here is a video of my issue
[ame]http://youtu.be/ov1nWch6-QM[/ame]
Sent from my iPhone using Tapatalk - now Free
Old 09-06-2013, 11:25 PM   #22
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
U are not the only one lololol
Old 09-06-2013, 11:31 PM   #23
ATSAaron
Who tuned yours? If you get a chance over the weekend I'd like to see a log of that problem.
Are you using the speed density racerom feature? Or still using the air flow meter?
Is the issue new? Or has it been there since the tune?
Aaron
Old 09-06-2013, 11:34 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Your tuner needs to figure out the proper injector scaling for the injectors and E85. E85 is a bitch on cold starts.
Old 09-06-2013, 11:34 PM   #25
Sportsguy83
Drives: Limited BRZ
Aaron
The one on the passenger side with the bottom bolt almost impossible to reach.
Old 09-06-2013, 11:37 PM   #26
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I had it
Then i dropped it lol
Old 09-06-2013, 11:37 PM   #27
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Aaron
Full Speed Density and @JuniorAWD
Old 09-07-2013, 01:33 AM   #28
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I did the same thing a few days ago. Left the injector ecu hanging there so I could check my new port injectors for leaks. 4 fouled plugs from a flooded engine/stalling later I was able to get it dyno tuned today. Always make sure that thing is grounded. FYI it started and idled fine after I grounded it. It misfired in boost over 6psi though. New oem plugs and we had no issues up to 10.5 psi. Lesson learned
I can't send and receive PMs Hanakuso Site Announcements / Questions / Issues 1 06-14-2012 03:08 PM
Quebec Fr-S Test Drive ! Send me a message to reserve !!! SCIONMONTREAL CANADA 11 04-27-2012 04:11 PM
I send a msg on Tetsuya Tada facebook page 4agze Scion FR-S / Toyota 86 GT86 General Forum 63 06-28-2011 05:51 AM
