#15 |
Drives: FR-S 2013
Has anyone located the drain tube yet? Please post a pic.
#16 |
Toyota Freak
Drives: Whiteout FRS
ok, i posted this issue a while, and cant find the post.
same issue with the camry. the camry was plaged with this stuff. I have that smell, too, its from mold accumulating in the condenser.
#17 |
I posted the other thread this morning. Watching this one in case someone can help with the issue.
Sent from a Motorola DynaTAC 8000X |
#18 | |
) But I will do my best to search the service manual for anything pertaining to the drain tube if I can, it shouldn't be hard to find with the a/c on maybe someone else on here can help locate it with there a/c on and take a picture of the location referencing other locations, it has to be where there is a hold in the under body aero panels.
#19 |
Toyota Freak
you know 2 years ago i got the BG frigi clean kit for the camry.
looked like this ![]() not available any more.... ill do this eventually..
#20 |
Just checked and my plugs are installed under the car.
#21 |
Drives: 13 FR-S Whiteout 6MT
I'm gonna go with it being mold somewhere in the system.
My Pontiac G8 GT had a serious mold problem and it smelled like that whenever I turned the AC on. It always had a musky odor about it, but it would get much worse with the AC on. |
#22 | ||
Well after some research I found that the drain tube is on the passenger side in front of the footwell. You will need a lift or remove the underpanels to see the little rubber tube. This post highlights the a past drain issue:http://www.ft86club.com/forums/showt...ditioner+drain According to the post the drain tube drains off into another drainage point for rain water, which during heavy rain driving can sometimes back up into the condenser drain tube itself and even kink the tube up. If that and the other tricks I tried to recommend don't work its time for some professional toyota techs to help you out. sorry.
#23 |
Yeah just found mine
#24 |
@Minhtyfresh
Did you do a sound tube delete? If so did you cap the hole coming through the firewall? When looking for the drain tube I noticed how close the hole is to the blower inlet. I plugged the hole temporarily. First time getting back into the car seems muchh better. I need to have more stop and go tests. But if this is the issue im curious if the smell is the drainage line from outside the car and the fumes coming in or perhaps oil dripping issues that other people have had and its coming in the same hole. Sent from a Motorola DynaTAC 8000X |
#25 |
Drives: Da-Big Banana
Don't know how long you've had your car but did you change the cabin filter yet..??
#26 |
13k on this one and 23 k on my first one. Neither have had the filters changed. I took thisbone out and smelled fine.
#27 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
http://www.ft86club.com/forums/showthread.php?t=30878 |
#28 | ||
Drives: Whiteout fR-S
No success... ): I guess I will have to live with this for a couple weeks until i can make time for the dealership! Quote:
You can try blowing out the drain tube though. It didn't work for me... but it was easy to find and probably worth a shot for you. (see my response above to FRSBRZGT86FAN |
| strong odor @ higher rpm's | mRdeMs83 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 91 | 05-31-2021 08:07 PM |
| Damn odor wont go away | Yruyur | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 05-05-2015 10:41 PM |
| Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright | ill roller | Exterior Parts (Aero, Lighting, Etc.) | 6 | 09-22-2013 10:49 PM |
| Anyone getting an intermittent isopropyl odor? | FRiSson | Issues | Warranty | Recalls / TSB | 10 | 04-29-2013 11:07 AM |
| how do you remove odor from fabric? | prest1ge | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 07-03-2012 08:45 AM |
