Old 08-25-2013, 06:36 PM   #15
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Well one of those is the vent line and the other two have factory fuel connections that definitely should not be leaking. Are you sure they are leaking? Are you on a factory clutch? It sounds to me like you have destroyed your factory clutch.
Thats what I was thinking. It smells like clutch to me. But yeah im on stock clutch
Sent from my SGH-I337M using Tapatalk 2
Scalzo is offline   Reply With Quote
Old 08-25-2013, 06:39 PM   #16
whataboutbob
AutoX-10/10ths every run
Originally Posted by FA20Club.com View Post
your stock fuel lines should NOT be leaking. please look into that immediately
fixed that for you.
Build thread:Here
Old 08-25-2013, 06:41 PM   #17
Scalzo
Scalzo's Avatar
Originally Posted by whataboutbob View Post
fixed that for you.
They arent leaking just when I put my finger wround it .. its oily
Gonna post a video
Old 08-25-2013, 06:55 PM   #18
mike the snake
Sounds like a slipping clutch from your description. You may have also found another issue with the fuel lines, but even if the fuel lines were having problems, it wouldn't make the car do what you describe. Slipping clutch will do just as you describe.
With FI power the stock clutch just won't last as long I think.
Old 08-25-2013, 07:03 PM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
/THREAD
Old 08-25-2013, 07:03 PM   #20
Scalzo
Scalzo's Avatar
Wouldn't I get a check engine if there was a problem with the fuel lines? Video is on its way
Old 08-25-2013, 07:09 PM   #21
FirestormFRS
Given that the rpm is shooting up and the cars not moving i'm betting your clutch is gone.
FirestormFRS is offline   Reply With Quote
Old 08-25-2013, 07:13 PM   #22
Scalzo
Scalzo's Avatar
[ame="https://www.youtube.com/watch?v=Lp0A9q_niEI&feature=youtube_gdata_player"]Scion frs - YouTube[/ame]
Old 08-25-2013, 07:17 PM   #23
mike the snake
Yes sir, that is a badly slipping clutch. Time for a new clutch for sure.
Old 08-25-2013, 07:19 PM   #24
Scalzo
Scalzo's Avatar
I think ill get the clutch master fx300 with flywheel
Old 08-25-2013, 07:35 PM   #25
Quincy
Quincy's Avatar
Drives: Ultramarine FR-S
I had same thought. Poss the clutch is slipping. How many torque does your engine put down.
Quincy is offline   Reply With Quote
Old 08-25-2013, 07:40 PM   #26
Scalzo
Scalzo's Avatar
220tq to the wheels about
Old 08-25-2013, 07:43 PM   #27
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
If the car is drivable shift into a higher gear such as 4th or 5th and floor it. Revs increase and the car doesn't move? Your clutch is fried
Old 08-25-2013, 08:03 PM   #28
Scalzo
Scalzo's Avatar
Yup thats it lol
Thanks everyone for the help!
