Old 08-21-2013, 02:25 PM   #15
xwd
Another lower priced coilover option is the one from Feal Suspension. Based in the US, can revalve to suit.
http://rallyracingsuspension.com/page26.html
Lance Keeley who won STX at the Blytheville Tour over some very good competition and came in 2nd at the Pro is using those with 7K F/R springs.
Fortune Auto is a good option since they are based in the US, dyno the shocks, and provide good support.
I would take the GC setup, Feal, or FA over the KW V1s/STs, etc. since they have better support in the US.
Old 08-21-2013, 02:48 PM   #16
qoncept
qoncept's Avatar
I had Tein Flex on my WRX for a while. Harsh ride and underdamped. Replaced with Konis and coilover sleeves and was much happier.
qoncept is offline   Reply With Quote
Old 08-21-2013, 03:42 PM   #17
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
ST coils and call it a day. $850 or less shipped.
hanabie is offline   Reply With Quote
Old 08-21-2013, 03:42 PM   #18
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by 86_FRS View Post
Can you confirm this?
I ride on RCE Yellows and Konis and typically I'm the only one on STX running that setup. Most others are running BCs, K-Sports, Stance, and other inexpensive coils. I typically outrun them all (running stock tires on STX too). Folks that are faster than me typically have KWs or some other $2k+ coil setup.
With that said, driver has a huge effect, tire pressures, rebound adjustments, etc. There are simply too many variables to back up a statement like that. I find my car extremely easy to drive and I never feel like it's the car's fault, only my need of improvement. Some of the cars I've gotten to drive with coilovers are not as easy to drive. You have to fight with them a little.
raul is offline   Reply With Quote
Old 08-21-2013, 04:05 PM   #19
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by KKaWing View Post
Oh right, there's the RCE Tarmac springs and you can match them with the fixed perch Bilsteins that are gonna be released in 6 months-ish. "Emphasis on the ISH" <<< qoute from RCE.
I'm not looking for track, just faster better highway car. Smooth ride much like stock car feel but Low by a little. Its too high for adding more power.
Six months? IS that a Real timeframe? Preorder possible? Don't want to wait so long!
Right now koni are best option but I want easy install. Budget coil over not option for my taste.
kiichiro is offline   Reply With Quote
Old 08-21-2013, 04:14 PM   #20
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Install of my Koni yellows weren't too bad, but you definitely need another set of front OEM struts to work on to minimize any risks. I like my Koni's but unsure I have really have them "dialed in" with my Eibach ProKits since I have them very close to the softest setting for DD duties.
mit_peid is offline   Reply With Quote
Old 08-21-2013, 04:17 PM   #21
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Koni's + Swift + HVT
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-21-2013, 08:05 PM   #22
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I want the car to handle better I don't care about ride height at least as far as lowering.
In fact I live in Idaho and it's a low mile daily with autoX ....was simply surprised by how much the koni inserts were considering you have to hack up stock parts and then buy springs.
I feel the car is stiff enough but it bounces and bobs too much and could be more "planted"
Sounds like I should save for the koni's and pair with yellows or tarmacs add crash bolts and be done.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 08-22-2013, 10:10 AM   #23
qoncept
qoncept's Avatar
Konis are as good as regular OE replacements so you really aren't losing anything. You just don't end up with anything you can sell (except the rears). If you haven't done anything else to your car, why not throw in some Konis, keep the stock springs and run in stock class?
Old 08-22-2013, 10:36 AM   #24
tonystewart
If this was my car and not my daughters I'd be buying this from Vorshlag
http://www.vorshlag.com/blog/?p=670
Old 08-22-2013, 11:25 AM   #25
Racecomp Engineering
I'm sure your daughter wouldn't mind.
- Andy
Old 08-22-2013, 10:09 PM   #26
StormTrooper
Well I have wheels, inlet tube, and light flywheel.
AutoX is just for fun...I mean I like to win but eventually I'm getting a aluminium drive shaft and that'll put me in some crazy class
GR86 MT premium
Old 08-22-2013, 10:39 PM   #27
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Originally Posted by mike the snake View Post
Even lower cost coilovers can be good IF they're properly valved and matched to the springs and the car.
KW is a known quality brand, and their V1 coilovers I think are accepted as good quality, and the ST coilovers are made by KW and are the same as the KW V1's and are VERY affordable.
These are what alot of the VW crowd uses. Great reviews
Old 08-23-2013, 10:49 AM   #28
qoncept
qoncept's Avatar
Ah.. well, the struts are a lot more important for autox than spring rates. Unless you want to lower your car I wouldn't necessarily compare the cost of coilovers to Konis+springs. Konis alone will give you a good bump.
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 05:48 PM
AutoX coil-overs what should i get? subaruferrucci Tracking / Autocross / HPDE / Drifting 4 02-19-2013 03:03 PM
Coil-overs \ Spring kit ????? v3rgil AFRICA 9 11-16-2012 08:27 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 09:12 PM
