Old 08-11-2013, 05:27 PM   #15
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
3" vendors aside from PTUNING & FBM?
I haven't looked into FBM.
While PTUNING offers a 3" catback, I haven't seen PTUNING offer a 3" overpipe and test pipe...
I know FA20Club has a 3" test & overpipe. I don't know if they have the accompanying midpipe to complete a full header back 3".
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 08-11-2013, 05:50 PM   #16
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Perrin has a 3" cat back for $999
Old 08-11-2013, 05:57 PM   #17
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
group buy for 859 shipped
The Following User Says Thank You to whitefrs For This Useful Post:
charged86 (08-12-2013)
Old 08-11-2013, 06:20 PM   #18
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
the tomei 80 would work for those running the set up that PTuning has to offer though right? It appears to be a cat back
MooKz is offline   Reply With Quote
Old 08-12-2013, 11:12 AM   #19
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
As promised. We will be releasing our optional 3" midpipe, 3" front pipe and 3" overpipe in a few weeks for those that already have our DS-325 Modular exhaust system and would like to upgrade to a 3" header-back exhaust system. In addition we will also be releasing the complete DS-330 3" header-back dual-muffler exhaust system.
If you already have our DS-325 modular exhaust and plan to run our PTUNING turbo system, you will only need to buy the optional 3" midpipe to complete your true 3" Turbo-back exhaust system.
MrC
Mrc@ptuning is offline   Reply With Quote
The Following User Says Thank You to Mrc@ptuning For This Useful Post:
dabocx (08-12-2013)
Old 08-12-2013, 11:33 AM   #20
dabocx
dabocx's Avatar
Drives: Scion FRS
Im sure we will see more over time, from what ive heard a 3inch overpipe is a very tight fit some are fixing it with sway bar spacers or engine mounts.
dabocx is offline   Reply With Quote
Old 08-12-2013, 11:55 AM   #21
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
MrC
3" overpipe? Yay! I was told by so many it couldnt be done. Thanks for stepping up!
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 08-12-2013, 12:03 PM   #22
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I've been running one since March
With that said, it is a TIGHT fit.
Old 08-12-2013, 12:05 PM   #23
Tansey86
Tansey86's Avatar
Someone from Perrin said there simply isn't enough room. Thanks for the info though.
Old 08-12-2013, 12:09 PM   #24
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FA20Club also has a 3" overpipe and front pipe
Old 08-12-2013, 12:13 PM   #25
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
MrC
Is it possible to buy the pieces seperately? For example would i be able to use your 3" mid pipe with another exhuast system or will it only work with your exhuast? Nobody seems to make a mid pipe and if im replacing every other section of the exhuast im replacing the mid pipe too.
WHITE is offline   Reply With Quote
Old 08-12-2013, 12:22 PM   #26
xxscaxx
Drives: 2013 SWP BRZ
3" all the way back for a turbocharger is fine and dandy, but I would not dare run that on a supercharger. Turbos quiet down exhausts - superchargers do not.
Even now with the JDL UEL header I have, and ARK DT-S exhaust thats 2.5" its up there in noise. I had to remove my front pipe because that setup was too loud.
I'm trying to decide if I should run the header/front pipe and put the stock catback on, but i'm not sure yet.. lol.
xxscaxx is offline   Reply With Quote
Old 08-12-2013, 12:27 PM   #27
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
If you're getting a 3" cat back that will include the midpipe. For a 3" header back you'd also need a 3" overpipe and front pipe.
Sent from my SCH-I545 using Tapatalk 2
Old 08-12-2013, 01:37 PM   #28
Mrc@ptuning
Drives: S1000RR
It's 3" but it steps down to 2.5" to mate up with the factory header flange and all the downpipe and header that's on the market. You simply cannot connect a 2.5" flange to a 3" flange and expect the gasket to seal properly. The 2.5" section on our 3" overpipe is only a few inches in length and should not create any restrictions. The only way we can build a 3" overpipe that has a 3" flange on the header side is if we built the downpipe as well with a 3" flange on it.
MrC
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Exhaust options for 13' FR-S? Gwest11 Engine, Exhaust, Transmission 8 05-31-2013 07:31 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
