Old 08-09-2013, 10:01 PM   #15
dabocx
dabocx's Avatar
Drives: Scion FRS
Wouldn't go below at gtx28 if you want something smaller id just do a S/C
dabocx is offline   Reply With Quote
Old 08-09-2013, 10:22 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
AVO's 55 Trim is not bad at all
Old 08-09-2013, 10:50 PM   #17
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Yeah the AVO stage 1 looks really nice. Thats what I've been lookin at for a couple months now.
Old 08-10-2013, 12:54 AM   #18
coyote
coyote's Avatar
Drives: Slowly
12.5:1 compression helps a lot, but we are still testing a gtx2863r next week.
The numbers won't make for good internet bragging, but this one will be about driving.
Sent from my Nexus 4 using Tapatalk 2
coyote is offline   Reply With Quote
Old 08-10-2013, 05:26 AM   #19
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by icemang17 View Post
its not surprising that the early turbo kits employ large turbos.....which make the classic 45' increasing torque curve once the boost hits fairly high in the rpm.....just like classic Supras that made silly HP..... When torque and HP both spike quickly in upper midrange will make the car VERY lousy on the street......
Smaller turbos that spool quickly (or twin screw superchargers) offer near instant boost across the entire power band....BUT at the price of peak power.....but for a street car a smaller turbo that can achieve full boost from say 2000rpm up is much better than one that is worse than stock below 4k..... race cars are different of course.... My opinion as a racer.....I would rather have a 200hp-200ftlb engine that has a wide flat torque band (like our cars do stock) than a 250hp-150ftlb engine that has it all up high.....why? getting off the corners.....high torque engines always win the beginning of the drag race off the corner....then high RPM or high boost engines eventually might catch up if the straight is long enough, but have to take risks in the braking zone (easy to block) to make a pass..... plus mini straights inbetween corners always favor higher torque
Tend to agree with you but explain a Formula 1 car with 700 hp and 200ftlbs of torque?...yah there light,...but not 200ftlbs light. They seem to get off the corners quite briskly.
cf6mech is offline   Reply With Quote
Old 08-10-2013, 05:48 AM   #20
coyote
coyote's Avatar
Drives: Slowly
15,000rpm
Old 08-10-2013, 06:42 AM   #21
cf6mech
actually I thought higher than that,...but torque isn't the do all end all,....to me its corner speed.
Old 08-10-2013, 09:27 AM   #22
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
lol F1 cars idle @ 4-5k and are rarely under 10k on the track--they spin the crap outta them.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 08-12-2013, 11:48 AM   #23
SamS
Drives: '13 BRZ, '99 Forester,'06 Duc S2R1k
Originally Posted by sw20kosh View Post
Looks like the greddy kit's turbo is relatively small right?
With a redline of 7400 or more, you wouldn't want something too small. What is the redline on that miata?
I believe fuel cut was 7200, but I'd usually shift by 6500. It was just a street car.
These are the characteristics I'd be looking for. I'd rather have instant midrange torque for passing or leaving a corner without wringing the car out or downshifting, basically the feel of a larger engine but with better fuel economy.
Maybe the twin screw is more what I'm looking for, but I don't want to sacrifice cruising mpg since I commute mostly freeway. I think I did see something about de-clutching the SC during low loads though...
SamS is offline   Reply With Quote
Old 08-12-2013, 01:53 PM   #24
FRSRAVEN
The Innovate unit has an internal by-pass which cuts boost and reduces load on the supercharger when cruising.
The Greddy kit uses a turbo that is good for approximately 420hp. This puts it in line with the size of the AVO turbo, or the 50 trim offering from FA20Club. A GT2871R is also around the same size.
Because of the flow of this engine, all of the above turbos should offer good spool characteristics. Personally, I'm just about to pull the trigger on the FA20Club kit. The only thing stopping me is the Innovate kit, I like the look of it, the OEM fit and finish, etc. But I'm looking for around 270whp on pump, and that would be pushing the Innovate kit.
FRSRAVEN is offline   Reply With Quote
Old 11-17-2013, 06:19 PM   #25
diss7
Drives: AE86, 2x GT86, TE27
Any update on this??
diss7 is offline   Reply With Quote
Old 11-17-2013, 06:23 PM   #26
diss7
A t518z 10cm will not provide 420hp.
Unless you are talking about crank hp, ethanol/race gass, or both.
Those three turbos will be pushing to get to 350whp, on pump gas.
Have owned a t518z 8cm (which the AVo is a copy of) and a 2871R, ran both at limit. Feel somewhat confident in my statement.
However, run one of those turbos on motor with headwork, and on e50, and you start getting ALOT more power. Heres a mates sr20 that was recently dyno'd. 2871R, 20psi, E50. Pushed to its limit.
Old 11-17-2013, 07:29 PM   #27
mike the snake
A few years ago F1 engines were spinning to 23-24000 rpm! Now they are limited to 18000, and I thought I heard someone say they idled around 8000.
That's all out the window next year where they're changing to turbo V-6 engines that undoubtedly will rev much slower.
Old 11-17-2013, 08:37 PM   #28
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Rules limit idle speed to under 5k.
Sellout is offline   Reply With Quote
Vented hoods and turbos Nothing Forced Induction 176 07-18-2014 03:40 PM
snails and turbos carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 10 12-27-2012 04:44 PM
Turbos making less power down low? subatoy Forced Induction 40 10-03-2012 02:30 AM
Why does the aftermarket love turbos? Why not superchargers? ahausheer Other Vehicles & General Automotive Discussions 43 07-22-2012 10:27 AM
For those crying about turbos Mari0 Off-Topic Lounge [WARNING: NO POLITICS] 2 06-15-2012 09:57 PM
