Old 08-06-2013, 06:52 PM   #15
FirestormFRS
I'm confused. The lightweight pulleys are somehow changing the speed at which my auxillary equipment is spinning? I don't see how losing weight will "underdrive" the A/C or altenator.
Please explain this to me?
FirestormFRS is offline   Reply With Quote
Old 08-06-2013, 06:59 PM   #16
OrbitalEllipses
Drives: Attitude
It won't. An underdriven pulley has a different diameter, THAT is changing the speed of your auxiliary equipment is spinning.
Old 08-06-2013, 07:02 PM   #17
FirestormFRS
I was just confused as to how "underdriven" got into the conversation. Thanks for clearing up that these are not underdrive pulleys.
Old 08-06-2013, 07:03 PM   #18
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Not all aftermarket pulleys will "under drive" your accessories. Only pulleys that are specifically labeled under drive will do this. They do this by making the crank pulley a slightly smaller diameter than the stock pulley. This causes the accessory belt to run at a slower rate given the same rpm, this "under" driving the accessories connected to it.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 08-06-2013, 07:07 PM   #19
OrbitalEllipses
Drives: Attitude
We got here through reading comprehension, see my emphasis below:
Originally Posted by diss7 View Post
My toda units will be here in a week. Will get you the missing weights.
Remember its not just weights. The toda units are under-drive, which puts even less strain on the motor.
diss7 (08-06-2013)
Old 08-06-2013, 07:22 PM   #20
Hawk77FT
Drives: GTS 86
For total weight column I would instead replace it with "-x.xx" for the aftermarket pulley sets. So, minus how much weight the aftermarket pulleys are compared to the stock set.
Underdriven pulleys: never getting cold a/c again.
That needs to be done for each one of them rather than just the whole thing. The weight saved can be easily calculated with having the two rows there.
Hawk77FT is offline   Reply With Quote
Old 08-06-2013, 09:27 PM   #21
FirestormFRS
I was trying to be nice but since you're an ass.....
Show me where you defined you were talking about the Toda products....reading comprehension indeed.
Old 08-06-2013, 09:53 PM   #22
OrbitalEllipses
Drives: Attitude
I'm addressing Diss7, what's confusing you friendo? His post was the source of discussion for the bulk of the posts in this thread (following his post, imagine that!) when I posted my post. If you need more context clues...well, pal, try public school.
TitoFR-S (08-09-2013)
Old 08-06-2013, 10:09 PM   #23
FirestormFRS
I didn't read diss7's post obviously.....and you didn't quote it. My bad for jumping to conclusions. You're still a **** though.
Old 08-06-2013, 10:10 PM   #24
OrbitalEllipses
Drives: Attitude
All's well and good, but let's read all the posts before we decide to post. To your final point: yes, I am.
FnFast (08-08-2013)
Old 08-06-2013, 10:11 PM   #25
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Everyone take a chill pill ;-)
Carlitoz3 is offline   Reply With Quote
Old 08-07-2013, 10:08 PM   #26
Hawk77FT
Drives: GTS 86
WTF is going on? I have asked for suggestions, etc, not "who's got bigger ****" over the net? Geez!
Old 08-07-2013, 11:26 PM   #27
OrbitalEllipses
Drives: Attitude
Mine.
I still think there should be a "total difference from stock" column for each pulley set.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
diss7 (08-08-2013), Hawk77FT (08-08-2013)
Old 08-08-2013, 12:36 AM   #28
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Stock idler pulley - 0.683 lbs http://www.raceseng.com/revo-pulley-...r-s-subaru-brz
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Hawk77FT (08-15-2013)
Wheel Balancing Weights Black Tire Tracking / Autocross / HPDE / Drifting 4 06-13-2013 05:51 PM
Corner weights - Toyota 86 diss7 Scion FR-S / Toyota 86 GT86 General Forum 15 04-07-2013 07:30 PM
Wheel weights BAE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-09-2012 09:16 AM
does anyone know why GT86 weights so much? wu_dot_com Scion FR-S / Toyota 86 GT86 General Forum 85 03-19-2012 04:24 PM
