Old 08-02-2013, 07:58 PM   #15
mla163
Overthinking it
Drives: BRZ in CS
Seriously. No way your 225s on a 7.5" wheel are rolling over. Stock class autocross guys are running wider tires on 7" wheels with no issues. Not just this car. All cars.
mla163 is offline   Reply With Quote
Old 08-02-2013, 08:26 PM   #16
255 on a 8.5"
Check out that deflection... you can see rim against background.
Old 08-02-2013, 08:55 PM   #17
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Nice, a Lakeland guy! I've got a SWP BRZ, stock except for the 5Axis spoiler, and am in the County Line Rd / Shepherd Rd area on the south side.
smbstyle is offline   Reply With Quote
Old 08-02-2013, 10:51 PM   #18
Big-B
Drives: 2013 Scion FR-S Ultramarine
I've seen you a couple times, I live off Shepherd Rd. There's also a black one in the area I've seen once.
Big-B is offline   Reply With Quote
Old 08-02-2013, 10:58 PM   #19
Big-B
Sorry, please let me know if I need to clarify... I was up till like 2AM last night studying datalogs, and was at my day job by 7AM this morning.
No need to clarify, understand you perfectly. Tire too wide for wheel / wheel too narrow for tire. I'm still going to switch that tire out because I'm not getting it on the other side. But it is definitely rolling over, I know what it feels like and I know what it looks like.
Old 08-02-2013, 11:34 PM   #20
mike the snake
It could possibly be your alignment. If that wheel has positive camber it would help make the tire roll under.
The Following User Says Thank You to mike the snake For This Useful Post:
CSG Mike (08-03-2013)
Old 08-03-2013, 10:24 AM   #21
mla163
Overthinking it
Drives: BRZ in CS
Edit...
Mike, I respect your opinion. But, that picture shows a race car with race tires on a 18" or 19" rim. I see it as a different condition for the OP with a square setup on daily driven passenger tires and 17" wheels.
Maybe you're right. But I've seen plenty of autocross cars run much wider tires in much narrower wheels and I've never seen any scratched rims from rubbing on pavement.
Old 08-03-2013, 10:39 AM   #22
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
@CSG Mike, what do you think would be the optimal tire width on a 7.5" wheel to put the most rubber on the ground with no (or almost no) chance of something like this happening? And while we're on the subject, an 8" wheel, since that's what I have. Thanks!
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-03-2013, 11:03 AM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
I would lay the blame more on the tire sidewall being too compliant than "tire too wide for wheel". 225/45-17 on 7.5" width is a perfectly cromulent fitment. Running a narrower tire width isn't necessarily the greatest solution. A 205/50-17 might not roll over as much, but you would likely lose ultimate cornering grip. And of course wheels will be more susceptible to damage from curbs/potholes/etc.
I wouldn't bother going above 36psi cold, that's a bit much, really. I wouldn't worry too much about it, just get stiffer-sidewall tires next time (check tire tests, customer survey results, and customer reviews on Tire Rack's website).
The Following 2 Users Say Thank You to ZDan For This Useful Post:
GTB/ZR-1 (08-05-2013), Racecomp Engineering (08-04-2013)
Old 08-03-2013, 01:32 PM   #24
smbstyle
smbstyle's Avatar
Yeah theres a black one with green wheels and lowered I've seen around. Too funny! Do you have any plans on bringing it down to Sebring or another track in the area? I'll be down there in August with Chin.
Old 08-03-2013, 08:21 PM   #25
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Typically in those scenarios, people are not running street tires with floppy sidewalls. The Hoosier A6/R6 Kumho V710 and Hankook Z212 all have VERY stiff sidewalls and will tolerate a much narrower rim.
neurokinetik is offline   Reply With Quote
Old 08-03-2013, 09:42 PM   #26
It's really the tire more than the size. High performance tires tend to have stiffer sidewalls that can handle more load, so that the rollover doesn't happen.
Edit...
That's actually my personal s2k, on 17" rims with street tires that I daily drive on The rims look bigger because they fill up the wheel well due to compression from lateral load from cornering (look at the body roll... front bumper vs ground is the easiest way to tell). Here's another angle: Oh, yeah, the surface was a bit damp too
Anthony (08-04-2013)
Old 08-04-2013, 12:19 AM   #27
Anthony
Weight Nazi
Anthony's Avatar
That does make sense. I guess I'll have to research it next time I need to buy tires. I've been thinking about going with Yokohama AO48's or Toyo R888's next. No clue about sidewall strength on those tires though. Thanks!
Old 08-04-2013, 01:05 AM   #28
kster1
kster1's Avatar
I ran one set of R888s on my old RX-8 just to try them out. They have stiff sidewalls and are fast when new; the problem with these tires is they get heat cycled to death pretty quick. For the BRZ, I am back to the old reliable RA-1 which seem to last forever (I need a set of tires to last a good number of HPDEs).
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
Post your rolling shots! jeffsides FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 118 10-17-2014 04:57 PM
Lightning Red BRZ Rolling Shots ChandlerSwyng FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 05-07-2013 09:56 PM
fender rolling Andybui82 Northwest 0 03-30-2013 11:44 PM
Streaks down windows after rolling them down FRS TT Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-13-2012 10:09 PM
A Rolling Tour of DC...aka...my Commute sho220 Off-Topic Lounge [WARNING: NO POLITICS] 10 08-17-2012 07:20 PM
