#15 | |
Drives: 2013 DGM BRZ Limited
It just takes practice. It's like driving a manual for the first time. You stumble and stall, but once you get the hang of it, it becomes second nature.
#16 | |
As far as choosing which gear, it's entirely up to you and what RPM you want. At the track you may rarely be below 4k RPM, whereas on the street you may rarely be above 6k. There's too many variables to say "do this" or "do that" for any situation. If you're trying to keep the car "in the powerband", you typically want to keep it somewhere above 4k where the power and torque pick up. So as you are braking, if the current gear drops below 4k, you can downshift to keep the engine in the sweet spot. If you need to continue braking (and again the engine drops below 4k), downshift again. This may all happen over the course of two or three seconds. Watch as many videos as you can to see how it all works together: apply brake clutch in shift into lower gear and rev match to proper rpm (using your heel) clutch out KKaWing's video above describes it well, and trippinbillies40's video shows it in practice (watch his tach when he downshifts). Personally I was mesmerized by the pile of dirt rolling around the passenger footwell, it was hypnotic, lol Lower gears do provide more torque, but it's relative to engine RPM. For instance, 2nd gear at 2000 RPM might feel sluggish compared to 3rd gear at 6000 RPM. But, both gears at 6000 RPM, 2nd will feel a bit stronger, but 3rd will carry the car to a higher speed. Ideally for performance driving or racing, you want to be at the beginning of the powerband as you exit a turn. This isn't always perfect for every turn, but you also don't want to exit a turn at really high rpm, where you'll instantly bounce off the rev limiter. |
#17 |
Drives: Nevermorange FRS
It's often hard to know what's right for a few reasons:
1: while there's some basic principles, there's more than one way to skin a cat (aka: there's more than 1 "right" way) 2: It's very difficult to teach someone via a message board 3: It's almost impossible, on an internet message board, to really know who you should be getting advice from. So take all this advice cum-grano-salis. Here's how I heal-toe rev match on track: (I overlayed a foot cam in the video so you can see my feet) [ame="http://vimeo.com/70389681"]Spokane 2013, ITA Race on Saturday on Vimeo[/ame]
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | CSG Mike (07-24-2013) |
#18 |
And you'll notice... I skip gears (always at this track but not always at others). Your brakes do the braking, not your clutch/tranny. Also, every time you're having to blip the throttle under threshold braking you risk a misplaced revmatch throttle blip that will upset your braking causing you to lock up or opposite; unnecessarily elongate your braking zone. Both are very bad if following a competitor closely into a corner.
There's one track locally where I go into turn 2 and shift from 5th to 3rd but then we go down a steep hill in 4th (90mph) into a 2nd gear corner. In that down hill brake zone, for some unknown reason (I've examined the data), the car just feels better when not skipping gears. However, even then (like in last weekend's race there) I will occasionally over rev the engine during the "blip" and as a consequence have to either push on the pedal harder to compensate or alter my braking line. Ok, that's about all the info I can get across on a message board. Good luck, have fun at the track and be safe. Remember, enter the corner in the gear that you're going to leave the corner.
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | GTB/ZR-1 (07-24-2013) |
#19 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I wish I could see these videos at work. SUBSCRIBED.
My FR-S should be arriving mid-August or so, and I should be arriving home late November to meet it. I'm very excited to start learning to heel-toe. I miss the experience of learning to drive a manual, so it's kind of like getting a second chance. Like when you've seen a really good movie, one that you would/have watched multiple times, and are jealous of the people who haven't seen it because they still get to see it for the first time.
#20 | |
Can you elaborate on this because it's been my experience that the opposite is true. I've rebuilt several transmissions (albeit FWD and just recently in the paddock at the race track) but at looking at the operation of the various forks, collars and rods; I cannot see how skipping gears increases synchro wear. If you're skipping from 5th to 3rd then your not putting wear on the 4 gear synchro on that corner, lap after lap after lap. To me, that reduces wear. It looks like what you're advocating is trading 4th gear synchro wear in exchange for 3rd gear synchro wear. Now where I would recommend what you suggest is in the instance where the 3rd gear in your transmission is going bad, it "crunches" on the downshift and you don't know how to double clutch while heel-toeing. With a bad 3rd gear synchro, you can down shift from 5th to 3rd and row through 4th with the clutch still depressed which will aid in slowing the main/counter shafts allowing for the collar to slide over 3rd gear more easily without a "crunch". But doing this is trading 3rd gear synchro wear for 4th gear synchro wear. It's kind of a moot point anyway though because the revmatch downshift to the 3rd gear synchro isn't anywhere near as stressful as the upshift from 2nd to 3rd is when you're doing so at redline. At this point, it's all just 6 of one and half a dozen of the other I suppose.
PRO86 | WTCC | STL
#21 | |
Engine <-> Clutch <-> Midshaft <-> Transmission <-> wheels Effectively, it is the clutch's job to connect the engine to the midshaft, and the transmission's job to connect the midshaft to the wheels. The clutch is engaged/disengaged via clutch pedal, and the transmission engaged/disengaged to connect the midshaft to the wheels at different ratios. The clutch can "slip" to make up for differences between the engine and midshaft rotation speeds during the engagement process. Likewise, the synchros on the transmission will "slip" (technically incorrect, but same purpose) to bring the midshaft rotation speeds in line with the wheels at the ratio of the gear selected. Now, for example's sake, lets say you're going 70 mph, in 5th gear, and this is roughly 4000 RPM. In 4th gear, this would be roughly 4800 RPM, and in 3rd gear, roughly 6200 RPM. When the transmission and clutch are both disengaged, the midshaft, momentarily, is spinning at the same RPM as the engine. Friction will slowly bring this speed down, but for the purposes of our example, lets assume there is no friction. If you're downshifting from 5th to 4th at 70 MPH, then the 4th gear synchro is bringing the midshaft up to 4800 RPM so that the gear can engage as you go into the gate, a load of 800 RPM. If you go from 5th to 3rd, then the 3rd gear synchro needs to bring the midshaft from 4000 RPM to 6200 RPM, a load of 2200 RPM. However, if you go into the gates sequentially, then going from 4th to third at 70MPH reduces the load to 1400 RPM. Not only are you splitting the RPM load between the synchros over two gears, when you factor in the speed of gear engagement, you're also effectively doubling the amount of time being allowed for the RPM changes to happen. The amount of time being allowed for a synchro to do its work also affects wear. If you gently hold the shifter against the gate of a gear, it'll eventually "slip in" effortlessly when the synchro has brought the midshaft up or down to the appropriate speed of the gear. Conversely, if you shift very quickly, you'll need a lot of effort to get into the gear. This is why it's very difficult to get into 1st gear when you're doing 60MPH. Can you do it? Yes, but the load on the synchro is so large that it takes a while for the midshaft to speed up to the appropriate RPM, even if you push HARD. Please let me know if I need to clarify anything here; I'm typing this train of thought while constantly getting inturrupted at work. *note* the total amount of work being done by the synchros is the same. The key here is splitting the load, and allowing the work to be done over a larger period of time. |
#22 | ||
Edit: Things in this post by myself are factually inaccurate because transmissions are little more than black magic and created by elves in dark places from far away lands. I have corrected the oversights in the later post.
For sake of argument, lets assume a 5 gear is a 1:1 ratio. This way we know that the input shaft and output shaft at 4000rpms are both spinning at 4000 rpms and we will use 70mph for this. Now if I want to change down to 3rd gear while maintaining 70mph our output shaft will remain at 4000rpms (70mph) and in our "frictionless vacuum", with the clutch depressed the input shaft (shaft that goes into clutch) remains free spinning at 4000rpms. When we shift from 5th to 4th we are matching the gear to that shaft speed not the other way around so now we have engaged 4th to the shaft via the synchro and since all we did was change the speed of the gear (and not the shaft) that means the shaft is still spinning at 4000rpms when we select 3rd and the synchro will have to do the same work regardless of whether or not we went from 5th to 3rd or 5th-4th-3rd in the same clutch depression. So all we have achieved by using the 4th gear gate in between 5th and 3rd is a slowing of our shift which gives the gearset time to slow down (by a fraction of a second) in the oil which negligibly reduces any wear on the 3rd gear synchro but yet puts unecessary wear on the 4th gear synchro and to absolutely no benefit in lap time. So I guess I stand by my argument that using the 4th gear "gate" while the clutch is still depressed while going from 5th to 3rd does little to nothing to reduce the wear on 3rd and only adds wear to 4th unnecessarily. Thank you for the polite discussion as always. Your turn.
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | Howardwei (07-26-2013) |
#23 |
Non-related to the debate Mike and I are having..
Heel-Toe-Double-Clutch This is my 72 year old dad in my race car: [ame="http://vimeo.com/70975448"]heeltoedoubleclutch on Vimeo[/ame]
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | phastafrican (07-28-2013) |
#24 |
We'll agree to disagree... because I know we can go on forever.
Strong anecdotal evidence the skip shifting causes premature failure, based on my S2k experience, however. |
#25 | |
Woodwork from S2ki. This post is 12 years old!
| The Following User Says Thank You to CSG Mike For This Useful Post: | Anthonytpt (07-25-2013) |
#26 | |
![]() .....and it's me (sort of). So I will eat crow. Yup, the gears on the mainshaft (input) spin with it. You were right about that. The gears do ride on the shaft with needle bearings but because of the counter shaft they spin in relation to the mainshaft so slowing the gear, is slowing the shaft. Thank you for the correction. Now, woodwork. Let's address that. Woodwork is specifically talking about upshift and even skipping gears during the upshift. Why? Because downshifting isn't done when the engine is at redline, the engine speed is always lower when downshifting under braking, the synchro is doing exponentially less work. The upshifts are the primary wear feature on the synchros. However, I do concede that a row through 4th (with clutch still depressed) before snagging 3rd will transfer some wear away from 3rd and onto 4th and that you are right. I still maintain that the wear savings is negligible in this regard though. I still won't do it. A) Well because I have triple cone synchros on my 3rd gear and not on my 4th! B) I want my right hand spending the least amount of time off the steering wheel as possible when threshold braking at 130mph. Doing the extra "row" just isn't worth it. C) The more time you spend whipping your shifter about puts more wear on aluminum runners on shift forks.. once these wear out, it's a lot more expensive than some brass synchros. (also see: don't rest your hand on the shifter) D) All of this is moot if you can heel-toe-double-clutch, then you have no wear on downshifts, skipping or not. Heck, you'd be able to downshift with no synchros at all. E) It's too slow and for God's sake, I'm racing over here! Oh yeah, and I just like to argue with you Mike.
PRO86 | WTCC | STL
#27 |
I need to practice my heel-toe-double-clutching...
On a side note, I thought I broke my trans on the s2k. Turns out my clutch disk failed. Not wore out, but failed. Waiting on pics to see how much clutch disk I have left after 115k miles of mostly track, canyon, and bumper to bumper traffic. |
#28 | |
Drives: '13 Argento 6MT FR-S
Does that mean you'll be up and running sooner?
!Quote:
| DIY - Drivers Mat Heel pad for only $15 | nzer | DIY (Do-It-Yourself) Guides | 40 | 09-25-2020 03:00 PM |
| Heel Toe Question | trackmagic | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 02-24-2014 12:29 PM |
| Heel Toe Around Town? | strat61caster | Scion FR-S / Toyota 86 GT86 General Forum | 154 | 06-12-2013 05:30 PM |
| Heel toe | #87 | Other Vehicles & General Automotive Discussions | 21 | 08-25-2012 05:39 AM |
| Heel and Toe | ichitaka05 | Other Vehicles & General Automotive Discussions | 13 | 04-02-2010 02:28 AM |
