Old 07-04-2013, 11:53 PM   #15
Frs300
Frs300's Avatar
Drives: Pile of junk
Originally Posted by Sportsguy83 View Post
Thanks. I'll check up with him tomorrow.
you can drop off the radiator if you want lol j/k
Frs300 is offline   Reply With Quote
The Following User Says Thank You to Frs300 For This Useful Post:
Sportsguy83 (07-04-2013)
Old 07-07-2013, 01:27 AM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Silverdub View Post
Yeah well it did not answer everything but so far it was the most usefull tread. I ll edit my original post here when done eith diy, perhaps install vid
Hey man, any updates? I ordered from Tactrix. I am wondering what size hoses are needed. I currently use 5/32" for my MBC. Want to know if I need to buy different size hose and hose adapters.
Thanks!
Old 07-07-2013, 10:16 PM   #17
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Hey man, any updates? I ordered from Tactrix. I am wondering what size hoses are needed. I currently use 5/32" for my MBC. Want to know if I need to buy different size hoes and hose adapters.
Thanks!
whats up! I just installed it with the hoses that were on the turbosmart mbc.. since I cancelled my windshield washer tank, this is the hose that I used lol
now I cant tune my car, for some reason, ecutek wont open it says something about dk2 drivers wtf!!!
Silverdub is offline   Reply With Quote
Old 07-07-2013, 10:20 PM   #18
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
nevermind the dk2, didn't think I needed to plug in the usb key to just open ecutek lol
Old 07-07-2013, 10:37 PM   #19
Sportsguy83
Drives: Limited BRZ
Awesome!! Just left the OEM purge valve in its place and connected and then left the intake port on the EBC disconnected?
I hate not being able to open Ecutek without dongle even for log study!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Silverdub (07-07-2013)
Old 07-07-2013, 10:47 PM   #20
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
yeah same here wish I could just open and read logs.... so I just got back from a drive, car is slow, just boosting 6psi as per normal wastegate operation, seems like the ebcs is just open all the time and not holding the pressure unless john did set up 6psi
I also let the intake port untouched... I found other guys that put a cap on it but im thinking it needs to bleed air from this port so I asked John about it... just sent a message on zendesk, we shall get an answer eventually.. man 6psi, car is piss as slow!
The Following User Says Thank You to Silverdub For This Useful Post:
Sportsguy83 (07-08-2013)
Old 07-07-2013, 10:48 PM   #21
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
man I wish I could of posted pics of my installed but iphone screen stoped working yesterday... I ll get it fixed soon and will post pics and vids
Old 07-07-2013, 11:14 PM   #22
nonicname
Drives: it has 4 wheels and a motor
WTF is EBC?
IFH acronyms.
nonicname is offline   Reply With Quote
Old 07-07-2013, 11:15 PM   #23
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by nonicname View Post
WTF is EBC?
IFH acronyms.
electronic boost controller
2013 FRS
Vortech V3 11psi
Old 07-08-2013, 01:47 PM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What they are really talking about is what the Subaru guys call an EBCS or an Electrontic Boost Control Solenoid. The Subaru ECU is setup to control boost through an OEM solenoid. John and some of the other tuners have found a way to send a signal through the fuel vent wiring to an EBCS to control boost through the EcuTek programming.
Most EBCs or Electronic Boost Controllers come with a solenoid as well that is instead controlled by a little box that you mount somewhere inside the car.
The Following User Says Thank You to King Tut For This Useful Post:
Old 07-08-2013, 02:33 PM   #25
Sportsguy83
Drives: Limited BRZ
What they are really talking about is what the Subaru guys call an EBCS or an Electrontic Boost Control Solenoid. The Subaru ECU is setup to control boost through an OEM solenoid. John and some of the other tuners have found a way to send a signal through the fuel vent line to an EBCS to control boost through the EcuTek programming.
I've decided to get it. Might need a bit of help installing it Thursday :happy0180:
Old 07-08-2013, 09:23 PM   #26
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
mine is working! I got a 6 psi map and a 7-8 psi map, working on it now with john but it works amazing and its so easy to switch maps... but I now have a cel for evap, maybe he forgot to turn off the solenoid or something
Old 07-08-2013, 09:26 PM   #27
Sportsguy83
Drives: Limited BRZ
Mine shipped and is on its way! I routed the WG lines to that area today. Mind sharing a pic of where you attached it? I saw the blue connector today. It can't get easier than that!
Silverdub (07-08-2013)
Old 07-08-2013, 10:21 PM   #28
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
sorry I cant post pics my iphone is still down, but I attached mine on the rad van support, and extended my witing instead, the shorter the vacuum and boost hoses the better imo
Visconti Ryan86 AFRICA 25 06-04-2013 01:39 PM
@Visconti Silverdub Forced Induction 4 04-27-2013 09:38 PM
Visconti Calum User/Vendor/Sponsor Reviews, Feedback, Comments 7 03-11-2013 06:02 PM
CEL with Visconti tune tjdiz92 Issues | Warranty | Recalls / TSB 44 09-16-2012 04:04 AM
Visconti stg 1 Hawaiian Great Lakes 18 08-23-2012 02:11 PM
