Old 07-10-2013, 09:01 AM   #15
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Looking great!
Small simple question. Your center plastics around your shifter and your TC buttons etc all black, is that a stock thing for the AUS GT86 or did you source those out? Asking I want to ditch all silver crap this winter when I'm parked and doing more minor mods, thanks!
Old 07-10-2013, 11:18 AM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by JD86 View Post
I have a couple of plans as far as the oil cooler ducting goes. One will be using the APR brake duct on that side, but I have something more extreme in mind down the line.
I mounted up my Full Blown oil cooler last weekend, and my APR brake ducts arrive today. I was thinking about fabbing a custom duct to connect to the brake duct and direct air directly at the oil cooler as well.
Old 07-10-2013, 11:21 AM   #17
JD86
Drives: 2013 Toyota 86 GT
Originally Posted by OICU812 View Post
Looking great!
Thanks mate.
That's the stock trim on the Aus 86 GT, not the GTS, my dash trim/radio surrounds are also all matte black as well. A lot of people prefer the GTS with silver trim, but I'm a big fan of the all black look. Although I've added a couple of silver highlights like the centre plaque and the reverse lockout ring.
JD86 is offline   Reply With Quote
Old 07-10-2013, 11:25 AM   #18
OICU812
Just a dude
OICU812's Avatar
Well good god man tell those people that want silver ill trade em, I much prefer the matte black!!!
Inner door handle trim and AC vent surrounds black to??
Old 07-10-2013, 12:53 PM   #19
JD86
I'd have to check the door handles but the aircon vents are definitely black. I think the only silver trim I have is the bottom of the steering wheel which I am thinking of swapping out to CF or dipping black.
Old 07-10-2013, 11:00 PM   #20
JD86
Credit where it is due to Ravspec, he's offered to replace the lug nuts and centre caps. Thanks Mark!
Old 07-11-2013, 09:12 AM   #21
JD86
That's not a bad idea and would be pretty easy to split the duct in two. I was also considering removing the light and replacing the whole grill except the indicator with a mesh.
Old 07-11-2013, 09:20 AM   #22
JD86
One of the two little things I've gotten done today. Gauge isn't wired in yet but I promised that I'd get the pod installed and photos up for the guy that made it for me...
Thanks Redline.
Yes I am aware I have a giant phone... I love it all the same and the HKS apps look amazing on it.
The other mod wasn't quite as successful. Little bit of colourful language was used in large amounts today. I'll explain more when/if I've fixed it.
Old 07-11-2013, 10:11 AM   #23
swift996
swift996's Avatar
Thanks Redline.
What app is that?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-11-2013, 10:19 AM   #24
JD86
Originally Posted by swift996 View Post
What app is that?
That would be HKS Carscope... For that you'll need the HKS OBII connector. Little more expensive than your average OBII blue tooth connector, but you get the LFA styled digital dash.
Old 07-11-2013, 10:27 AM   #25
swift996
swift996's Avatar
Yeah, that's unfortunate but it looks awesome!
Old 07-12-2013, 05:20 AM   #26
JD86
Ok colourful language has stopped... For now. This issue was with the stupid trd door stabilizers. Whoever loctited those bolts in originally should be shot. Although the issue was really my fault and I'll own up to that freely.
Words of advice, if you buy a brand new rattle gun to remove the bolts in your door, give it a try on something not related to your car first.
I bought an awesome little dewalt rattle screw driver for another job I'm doing for work at the moment, as it happened you need one to break the loctite on the bolts in the body of the door. Bang two birds, one stone, perfect I can used it to install these trd brackets and move on with my life.
As it so happens the one that I bought packs a serious punch. First bolt pops out no problem, rattle gun breaks the seal with the loctite and I unscrew it the rest of the way with a ratchet. There's where I made my first mistake kids. Leave the first bolt in whilst you rattle out the second bolt. Or else you'll do what I did and torque the nut section inside the door out of alignment and lose it in the frame of the door so you can't see it at all and there's no where to thread the new bolts in. My bad. I had to go fishing and twist it back into alignment and all sorts, but I got it back and the new latch installed. Crisis over.
I learnt from this and didn't pull the bolts out all the way from the second door until I had broken the seal on the other one. However I was now in a bit of a hurry and didn't clean out the loctite very well before inserting the New bolts. One of the bolts binds up half way in, isn't going anywhere so I reach for the torque gun which is still at my feet and put it into the jammed bolt. Mistake number two. The bolt turns a little at then the torque gun strips the head of the new bolt in about two seconds flat! Ba bow. At this point it is almost in, but too far to get a grip on it with a pair of pliers and too far out to get the door to close on it. There is definitely an "oh f@#k I'm screwed up my car thought or two going through my head. It's 8pm at this point and I'm not happy so I decide to walk away and come back fresh in the morning. 2am and I'm not sleeping and trying to figure out how to fix it... a solution pops into my brain... I won't tell you how but I got it fixed using a special form of gentle persuasion and several every day household items and the door closes and the stabilizers work. But it's not a pretty solution.
Moral of the story. Well morals.
Don't use brand new power tools on brand new car without testing them first.
Don't use a rattle gun to extract the bolts all the way in the door of the car.
Break the loctite on all of the bolts with the rattle gun before removing any of them all the way.
Clean the loctite out of the bolt holes before inserting new ones.
Old 07-12-2013, 08:48 AM   #27
nix
nix's Avatar
Drives: AVO BRZ
Don't worry we all have these moments with our cars.
Mine has a nice big scratch from what looks like me closing it on a spanner or something, I have no idea how or when I did it.
I'm doing the door stabiliser install on my car in the near future & will be careful.
nix is offline   Reply With Quote
Old 07-12-2013, 10:55 AM   #28
JD86
Good to know I'm not alone in the world.
To be honest they're a really simple mod to do. I just made a balls up of it because I was in a hurry and wasn't thinking. If I'd left it to this morning I'm sure I wouldn't have had a problem, but I had a new shiny power tool that looks like a gun and goes vrrrrooom when you pull the trigger... What could possibly go wrong?!? Haha.
I now have to find a replacement for the screwed up bolt and figure out how I'm going to extract it given that it has a torque head on it that I've stripped and not a Phillips I suspect that will be an interesting task. But it is in and the bolt is hidden out of the way so the latch works so I might just leave as is.
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
How reliable is a boosted FRS/BRZ? wootwoot Forced Induction 123 07-22-2016 03:18 PM
GT86 with aero kit and high wing spoiler from Australian drive event Nafe FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 43 08-26-2013 11:15 AM
Australian GT86 Commercial (have you seen this) slidethis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 42 12-29-2012 10:21 PM
Australian GT86 WATER666 Scion FR-S / Toyota 86 GT86 General Forum 3 06-15-2012 04:25 AM
