Old 05-18-2019, 09:20 PM   #15
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
apologies in advance for resurrecting a dead thread
but that power tap location (to the left of fuse 7 [ 30A] ) is not switched accessory power ( or Ignition-on power) in my 2013 BRZ.... it is constant +12V even when car is switched off. Posting this in case someone does not want that wire energized at all times due to possible battery drain. For those who care, you can check your own car with a test light , 12V bulb, or volt meter.
canyons is offline   Reply With Quote
Old 05-18-2019, 09:30 PM   #16
invaliduser
Drives: 2017 86
Hmm. Was 100% accessory power in my old frs.
Brz box wired differently? Seems unlikely
Sent from my SM-G973U1 using Tapatalk
invaliduser is offline   Reply With Quote
Old 05-20-2019, 04:19 AM   #17
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
but that power tap location (to the left of fuse 7 [ 30A] ) is not switched accessory power ( or Ignition-on power) in my 2013 BRZ.... it is constant +12V even when car is switched off. Posting this in case someone does not want that wire energized at all times. For those who care, you can check your own car with a test light , 12V bulb, or volt meter.
Can confirm with invalid user, that fuse position provided power to my dashcam and radar detector and in the condition when accessory power was energized.
Old 05-20-2019, 02:43 PM   #18
canyons
canyons's Avatar
^^ Maybe different due to brand (unlikely)? or year (probably more likely)?
Best advice seems to be to test one's own car with ignition off, then with accessory switch on, to know for sure how a particular car responds.
Zeta Performance - High-power LED Strip DRL Kit - Foglight Bezel Replacement ZetaPerformance Exterior Parts - Lighting 16 06-30-2016 05:40 AM
Zeta Performance - High-power LED Strip DRL Kit - Foglight Bezel Replacement ZetaPerformance Cosmetic Modification (Interior/Exterior/Lighting) 0 03-13-2013 01:26 PM
Carbon Fiber Foglight Bezel JonMotoring Exterior Parts - The Rest 0 02-10-2013 05:51 PM
Removing the HU Bezel Xdragonxb0i DIY (Do-It-Yourself) Guides 1 02-05-2013 08:20 PM
