Old 06-20-2013, 12:36 AM   #15
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Shift knob...
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 06-20-2013, 12:43 AM   #16
dsgerbc
Drives: BRZ(sold), STI
Meh, I have no interest in arguing.
Here's my position and I'll just leave it at that:
1) You warranty can't be voided. A claim can be denied.
2) If you're substituting non OEM-spec parts your claim CAN be denied. If you're running 20" rims with XXX/10/20-profile tires, your car is getting a crapload more viabration to the taillight housing. So your claim CAN be denied. It probably won't be when there are numerous other cases of leaky taillights with cars running normal wheels. If your rear window falls out (or some other vibration-caused failure that doesn't occur to other cars) - your claim CAN and is LIKELY to be denied because of the 20" rims.
What constitutes "oem-spec" sometimes is clearly defined (in case of replacement service parts) sometimes is vague and manufacturers' warranty departments take stands on what they might be prepared to defend in court, should there be a need to. If your intake screws up airflow sensor reading and dupes the engine into running leaner - it's non-OEM spec and manufacturers won't have to prove that your engine went kaboom because of the intake, they just have to prove that the said intake CAN make the car run lean to prove reasonably that it's not done to OEM spec. After proving the latter there's no need to prove causality.
3) Bringing up M-M (because a lot of people out there mistakenly believe that whatever crap they install on their cars the dealer/manufacturer have to prove something) when you have an uncooperative dealer due to your mods -- is an almost surefire way to get them to cooperate less even if your problem is widespread among non-modified cars.
4) So my best advice - forget M-M completely, it doesn't apply to anything enthusiasts do to their cars. If you have a common problem - argue that the problem is occurring to non-modified cars. If you bought a new just-released car, modify knowing that you run the risk of being screwed simply because there won't be enough data to claim that the problem is common on non-modified cars.
dsgerbc is offline   Reply With Quote
Old 06-20-2013, 12:47 AM   #17
Lonewolf
Lonewolf's Avatar
Drives: Moped
Holy shit, I can't stop laughing
Old 06-20-2013, 07:10 AM   #18
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Originally Posted by sho220 View Post
Shift knob...
Not if the dealer can prove that because of the non-OEM spec knob you can shift faster, thus damaging the transmission. Of course, that is if your window hasn't fallen out first from the faster-than-normal shifting!!
Actually, there's a lot of logic in dsgerbc's posts. Just not sure how much logic really matters in most warranty cases. Some dealers will try to deny every claim while others will go the extra mile to keep a customer satisfied. And I find that a lot of what they will and won't do for you depends on how you approach them with a problem in the first place.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
The Following User Says Thank You to Clembo For This Useful Post:
Lonewolf (06-20-2013)
Old 06-20-2013, 08:03 AM   #19
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Thanks for all of the replies guys. Got quote heated as it is a very debatable topic.
I'm thinking about getting a nameless axelback, which I could swap the stock back on before any servicing. Definitely staying away from an intake as I've had a seized engine denied due to an intake alone.
Thoughts on the axelback?
Brahsbrah is offline   Reply With Quote
Old 06-20-2013, 08:34 AM   #20
Asphalt~86
Drives: Asphalt AT
I can't either. Like, that dudes not serious is he? If he is, I seriously just might be done with this forum.
Asphalt~86 is offline   Reply With Quote
Old 06-20-2013, 08:45 AM   #21
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
I don't understand why the dealerships are such assholes sometimes... Don't warranty-related fixes cost them nothing?
Perihelion is offline   Reply With Quote
Old 06-20-2013, 09:07 AM   #22
Mikem53
Drives: FR-S 6MT
Shift knob...
Non OEM shift knob is too heavy causing excessive pressure on shifter fork which led to transmission failure...
Possibly after market license plate frame..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Old 06-20-2013, 09:17 AM   #23
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
Some of the dealerships around where I live actually have shops that do modifications to some of their cars and will throw on whatever you bring to them. I've been told some dealers throw superchargers on to tundras and there are usually a hand full of FJs, Tacomas, and Tundras with full lift, winch, and light bar treatment all covered under warranty. If they can install the part it's covered by them. Some of the larger dealerships sponsor some race/show cars but I have yet to see one lol
Ryuu0u is offline   Reply With Quote
Old 06-20-2013, 09:42 AM   #24
dsgerbc
This. If you behave like you own the place, citing M-M, demanding the dealer prove things etc - you'll get less accomplished.
In dealing with the manufacturer the dealer should be your friend/first line of defense. A lot will depend on how the dealer reports your case to the manufacturer. If you piss-off your dealer to begin with you might have to spend waaay more time on the phone with the manufacturer, even if your case is fairly strong.
Old 06-20-2013, 09:51 AM   #25
Perihelion
Perihelion's Avatar
Yeah these kind of dealerships are few and far between. But a place like that is heaven for car owners like us.
Old 06-20-2013, 12:41 PM   #26
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
***DISCLAIMER: The subsequent material does not constitute legal advice or legal representation in any way, shape, or form. The material is provided for ENTERTAINMENT PURPOSES ONLY, and was originally posted on an Internet community forum. The views expressed herein do not necessarily reflect the views of the owners, moderators, or administrators of the Internet forum. No portion of the subsequent material may be reproduced, retransmitted, copied, posted, printed, downloaded, or linked without express written consent from a site administrator.
There is a great deal of confusion regarding vehicle modifications and manufacturer warranties on the Internet. What follows are some simplistic clarifications to help consumers navigate the murky waters of vehicle modifications and warranties.
Magnusson-Moss Warranty Act: This act provides a host of benefits for common consumers, and some protections for automotive enthusiasts as well. The Magnusson-Moss Warranty Act may be viewed as a federal "lemon law" (California's state lemon law is the Song-Beverly Consumer Warranty Act). Lemon laws serve the basic function of protecting the consumer from vehicle defects and improper warranty denial or abuse.
Magnusson-Moss provides that before a manufacturer can deny warranty coverage as a result of a vehicle modification (e.g., aftermarket exhaust or wheels), the manufacturer must provide proof or evidence that the aftermarket part caused or contributed to a warranty concern or issue. [*Please check your owner's manual for the extent and duration of all vehicle warranties before attempting to assert protections provided by Magnusson-Moss.]
For example, if you have an aftermarket exhaust, and you take your car to the dealership to service a transmission issue, the manufacturer must demonstrate a causal link between your aftermarket exhaust and the transmission issue in order to deny warranty coverage that would have addressed the transmission issue.
In the event that an aftermarket part or component is found to have caused or contributed to a warranty issue, then the warranty for that specific manufacturer part is no longer valid; the warranty for the rest of the vehicle still remains in effect. For example, a manufacturer cannot void your powertrain (engine/transmission) warranty because you installed an aftermarket stereo head unit and amplifier in your car, and your factory speakers are now blown and no longer functional. Only the portion of the manufacturer's warranty for the vehicle's factory (original) sound system is affected. Your powertrain warranty remains intact despite the fact you modified the interior of your car, damaged the factory speakers, and no longer have warranty coverage for your factory/original sound system.
Real World Implications: Despite the protections provided by Magnusson-Moss, many automotive dealerships (which are independently owned and operated) will attempt to void vehicle warranties (or refuse service under warranty) because of aftermarket parts or modifications because they know that many people are not aware of their rights, will not go through the trouble of fighting the dealership and/or manufacturer, or do not want to wait to have vehicle service performed at a later date. *Remember that your vehicle warranties are through the manufacturer, and that the dealership is compensated by the manufacturer for warranty service when the service is approved by the manufacturer or its service divisions.
Preventative Solutions/Tips:
1) Try to have your vehicle serviced at a dealership that is fair and reasonable with respect to vehicle modifications. Inquire as to the dealership's stance regarding modifications before going in for service with aftermarket parts installed. Some dealerships are owned by enthusiasts and they appreciate the modifications performed by owners, and other dealerships don't want to deal with the potential liability or headaches that come with servicing modified vehicles under warranty. There are many dealerships that take no issue with modifications such as air intakes, cat-back exhausts, lowering springs, and aftermarket wheels, but draw the line at more involved modifications such as forced induction or aftermarket tunes. Conversely, there are dealerships that will take issue with minor modifications such as an aftermarket air filter or an axle-back exhaust.
2) Certain manufacturers provide branded performance parts such as intakes and lowering springs from in-house racing developers or third party affiliates such as TRD or STi. Performance upgrades from these sources are often backed with factory warranties so long as they are installed by a dealer. This is one potential way to avoid warranty hassles, but the trade-off is that these upgrade parts are limited in application and can be rather expensive.
3) Some dealerships will even install aftermarket (not from TRD or STi) parts for you, but be aware that if something goes wrong, and a warranty issue arises, all bets are off regarding your treatment by the dealership. If possible, get a written representation from the dealership that installed the aftermarket parts that you will be covered in the event of a subsequent warranty issue.
Editor's note: Organizations such as SEMA can provide you with more in-depth information and additional resources regarding the aftermarket industry and aftermarket parts.
I always tell my customers about this. You just worded it way better than i do. lol
Lakers86 is offline   Reply With Quote
Old 06-20-2013, 12:58 PM   #27
leon78
leon78's Avatar
Drives: 13 Whiteout
Will a blown strut/shock be coverd if the owner is over weight?
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 06-20-2013, 01:00 PM   #28
Mikem53
Drives: FR-S 6MT
I would think so... As long as his weight didn't exceed the GVWR determined by the O E M.
Will A Tune Void My Warranty? Apex Chase Engine, Exhaust, Transmission 12 07-13-2015 01:19 PM
Will TRD parts void brz warranty? lavisxice BRZ First-Gen (2012+) — General Topics 16 06-26-2014 11:24 AM
Will e15 void the warranty? dawnst3ar Scion FR-S / Toyota 86 GT86 General Forum 5 12-05-2012 01:59 PM
What Will Void My Warranty ? ScionFR-S Issues | Warranty | Recalls / TSB 6 11-09-2012 11:36 PM
Will This Mod Void My Warranty? Apex Chase Engine, Exhaust, Transmission 7 07-17-2012 11:38 AM
