Old 02-03-2014, 07:29 PM   #15
ramiram1984
Drives: 2016 STi DGM
http://www.ft86club.com/forums/showthread.php?t=57369 lol
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 02-03-2014, 07:39 PM   #16
Eau Rouge
Eau Rouge's Avatar
Drives: 2013 BRZ, Limited, C7P, 6AT
Nice exchange on info and perspectives everyone, thank you! It seems to bear out what I've heard that the OEM exhaust manifold is deficient from a performance perspective mainly due to the less than optimum merging of the exhaust gases before they're routed into the cat, hence the torque dip that gets reduced/eliminated once a header with a better collector is in place.
For my purposes, I'll likely eventually end up with one of the CARB certified centrifugal superchargers and will be swapping back in the OEM manifold/cat every 2nd year. That may also mean I'll need to reflash between two different tunes once ever 730 days if I want to fully maximize the non-CARB setup (or not if there isn't enough difference to warrant the cost of a 2nd tune). The good news is that here new vehicles no longer require a smog inspection/certification until they reach six years old.
Eau Rouge is offline   Reply With Quote
Old 02-03-2014, 11:11 PM   #17
FR-S Matt
Originally Posted by thehapaone View Post
the ft86speedfactory catted header showed elimination of the torque dip and a few horsepower gain on the stock tune
The advanced multiplier also wasn't set to 1, hence a fresh ECU reset for the pull. Don't let that chart fool you. There isn't a single header that eliminates the dip by itself on a stock tune. Someone even made the dip look like it went away on a stock header because of ECU resets.
Old 02-04-2014, 12:49 AM   #18
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Which is why i'm still waiting for independent dyno charts for both the OFH and FT86SF header before I commit to buying.
Fizz is offline   Reply With Quote
Old 02-04-2014, 09:08 AM   #19
Wepeel
Drives: '13 BRZ Ltd
Do you happen to have a link to that post? How would an ECU reset make the dip look like it went away?
Wepeel is offline   Reply With Quote
Old 02-04-2014, 07:43 PM   #20
Eau Rouge
Eau Rouge's Avatar
I'd like to see the background behind this, too.
Old 02-04-2014, 10:39 PM   #21
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Currently running the FA20club catted EL header, awaiting the replacement pipe from FA20club to make it cat free. It is a reasonably priced header with good gains, I wonder if the primary cat removal will be a noticeable change.
OFT Stage 2 EL Header Gas Tune 1.55b runs very well with this header.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Bang for the buck - upgrades BAE Engine, Exhaust, Transmission 101 03-09-2015 08:23 AM
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
Most bang for the buck? GIMMICK Scion FR-S / Toyota 86 GT86 General Forum 24 05-07-2013 07:10 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
