Old 07-10-2013, 04:19 PM   #15
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Dezoris View Post
Yes. Also crimp tool and some zip ties and the new connector wont fit in the clip properly.
got a part # or link to the crimp tool? i'm assuming it's a specialized one?
Old 08-01-2013, 06:57 PM   #16
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Digikey
Here are the part numbers:
WM6653-ND QTY 2
WM3343-ND QTY 2
QTY 20 WM3324CT-ND (ONLY 7 PINS REQUIRED)
You will also need the crimp tool.
In terms of DIY take a picture of factory connector and pins, start cutting one by one and crimp one wire at a time and insert into new connect. When done insert wire holder clip and test.
2 items are not in stock fuckkkk i was goona overnight them
Old 08-01-2013, 07:05 PM   #17
xjohnx
Grip>Slip
xjohnx's Avatar
you might be able to find what you need here: http://www.bmotorsports.com/shop/ind.../cPath/109_151
Old 08-01-2013, 07:07 PM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
did u order from here?
Old 08-01-2013, 07:10 PM   #19
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
@Dezoris
do you know what i need from here to get my obd2 port to work?
Old 08-01-2013, 07:18 PM   #20
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
does anyone know if this is all i need http://www.bmotorsports.com/shop/pro...oducts_id/1927
Old 08-02-2013, 12:22 AM   #21
xjohnx
Grip>Slip
xjohnx's Avatar
I'm not positive, but i think this is what you need. it's the same as the other one you linked to, but includes the female terminals
http://www.bmotorsports.com/shop/pro...oducts_id/1380
Old 08-02-2013, 08:06 AM   #22
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Have you tried asking the dealer how much the connector costs? Have you tried getting it under warranty?
Maybe the connector itself is not that expensive and it is a plug and play replacement?
Also, non-motor related stuff still has warranty and I have gotten work done from my dealer for non power train related stuff.
Old 08-02-2013, 08:53 AM   #23
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
They dont sell just the port, they sell the whole harness which is almost 1000 bucks.
I can get it under warranty cuz my car wont start as the flash stopped midway and brick the ecu
The Following User Says Thank You to whitefrs For This Useful Post:
Sportsguy83 (08-02-2013)
Old 08-02-2013, 08:59 AM   #24
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
This is the one i purchase
http://www.bmotorsports.com/shop/pro...k9j6vmohvi2c43
Old 08-02-2013, 09:00 AM   #25
Sportsguy83
Drives: Limited BRZ
Damn... thats effed up!
You can also try junkers and cars being parted out. I know there is one here in Miami for example.
Old 08-02-2013, 09:30 AM   #26
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Try that and no totaled or parting out going on around here
Old 08-02-2013, 09:45 AM   #27
xjohnx
Grip>Slip
xjohnx's Avatar
this happened to me. i just had to slightly bend the pins on the ECUtek cable so that they made better contact with the pins on the car side. been working right ever since. just finished flashing the Moto-East tune for my Innovate SC about 5 minutes ago. Now Pure Automotive is working on installing the SC itself. I wanted to get the flash out of the way just incase I ran into any issues with the flash, i didn't want it to be after they had installed everything.
Old 08-02-2013, 09:53 AM   #28
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
We tried every possible way with it and it still stops halfway.
We know for sure is not the map as he load this same map to another turbo frs
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 07:17 PM
DIY: OBDII plug relocation solma DIY (Do-It-Yourself) Guides 6 05-30-2013 12:11 AM
OBDII Connector nzer AUSTRALIA 64 05-09-2013 02:44 PM
OBDII (OBD2) Connector nzer Electronics | Audio | NAV | Infotainment 35 04-21-2013 12:36 AM
OBDII iPhone app/adapter phanguy Electronics | Audio | NAV | Infotainment 2 03-12-2013 12:34 PM
