#15 | |
Drives: 2013 SWP BRZ
#16 |
Just an update, did a 1 day event, logged about 110 miles on track with 4 - 30 min sessions, noticed it was just barely 1/8 qt low from where I filled it, so at least it is consistent!
#17 |
Drives: Subaru BRZ
Not to start a new thread, wanna update this.
After 250 miles of track days (in a month) and 1500 miles of daily drive, found out that car consumed like 3/4 qt of my Motul 0w30 (econrgy). Is it normal for agressive track ride in warm temperature (+10-15 C)? P.S. Car odo 4600 miles, used on track at her maximum.
bot hard go pro
#18 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Some oil consumption especially under hard use is normal, the problem is when to draw the line at excessive.
My car consumed no oil on my first lapping day which happened with 7000km on the odometer and was around 170km of on track driving. I am at 9000km now about to change my oil for the second time and have had no oil consumption, so either I am driving it too easy or I am lucky. |
#19 | |
Drives: Subaru BRZ
With factory oil on intake I cant check if PCV is oiled with motor one. Even so, 1 qt is a lot, I think. Especially, when it get into intake system.
bot hard go pro
#20 |
Catch cans, oil cooler a must for track days like that. Run a catch can on PCV, if you are collecting a ton of oil in it you know its mostly blowby. Also you should send out a UOA and see if you have any wear materials in that oil that could point to consumption.
I would run an oil with a high Moly content,namely early in in engine life as it helps to continue curing metals. Not a big deal for purely street cars but track cars why not.
#21 | |
Drives: Subaru BRZ
bot hard go pro
#22 | |
Drives: 2022 BRZ Limited
Did you check your cam plate to see if there is any leak? what kind of oil were you running? I wouldn't run anything besides 0w-40 or 5w-40 in Florida heat (I used to live in Tampa bay with turbo cars so I know how the heat soak might be an issue) .. FYI, I've checked my oil between sessions and couldn't notice any oil consumption (at least anything noticeable) .. I have a friend who tracks his BRZ at Sebring (his name is LD) I am not sure if he ran into the same issue but I can ask.. another question: are you sure you checked the oil level between 5-20 mins after you turn off the engine? anything before and after might be misleading..
#23 | |
Drives: Subaru BRZ
Only 2 of us having this issue?
bot hard go pro
#24 | |
![]() the difference between the 0w-30 and 0w-40 is the hot thickness or viscosity, it's more resistant to excessive heat which is the main reason I have been using on everything I owned/tracked for years.. I know a guy who used the same Shell Rotella T6 on everything he owned and tracked without a single problem ...cars, trucks, bikes even lawn movers
#25 | |
Haha yeah I'm friends with LD.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
| The Following User Says Thank You to smbstyle For This Useful Post: | glamcem (05-26-2014) |
#26 | |
I've known him since he had his old Wrx, and I've used to own an 07Sti ![]() I wonder why you don't want to run something thicker/higher flash point than 0w-20 especially in FL heat and Sebring? Since you mentioned that you saw oil temps around 300F
#27 | |
Drives: FR-S Whiteout
#28 |
I noticed the thicker oil will also increase temps, so I am trying to find a happy median. Probably going to go with Motul 300V next.
| Fuel consumption figures too | PuGZoR | AUSTRALIA | 25 | 02-16-2014 06:36 PM |
| 86 / BRZ Oil Consumption | ZZT86 | AUSTRALIA | 1 | 04-29-2013 09:53 PM |
| Tyre Pressures/Fuel Consumption | Vic_RSA | AFRICA | 11 | 12-11-2012 02:20 PM |
| Weight, fuel consumption and 0-100. | Loki556 | AUSTRALIA | 15 | 07-16-2012 10:06 PM |
