Old 06-27-2013, 12:34 AM   #15
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
Originally Posted by M1K3 View Post
Currently SPC has two models available for the FRS/BRZ/GT86:
67645:
and 67660:
Looking at the two I prefer the 67660, since it looks similar to the OE set up and the camber adjustment is on the outside mount (similar to the FIGS LCA), which does not change the angle of the shock and swaybar endlink mount when you adjust camber. Oh, and its also cheaper. Anyone have any info, opinions or recommendations on the two different LCAs?
Yeah, what he said............ interested too.......
"Power is nothing without Control"
j2digit is offline   Reply With Quote
Old 06-27-2013, 07:53 AM   #16
M1K3
M1K3's Avatar
Drives: vrooom...
I ended up getting the 67660...If you have not seen this Thread by FT-86 SpeedFactory: http://www.ft86club.com/forums/showthread.php?t=38527 you should check it out.
M1K3 is offline   Reply With Quote
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Cusco Zero 3s on the car Spaztastik Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-02-2012 02:12 AM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
