Old 06-01-2013, 06:44 PM   #15
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
Originally Posted by Mandy View Post
That's right, you need the handbrake for the poonani.
BadMoon is offline   Reply With Quote
Old 06-01-2013, 07:46 PM   #16
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Originally Posted by bdanisi View Post
Ok I've done this before I thought it was called launching tho. Is that something different? Like if ur going to drag race I've heard it called launching?
Deadspool is offline   Reply With Quote
The Following 3 Users Say Thank You to Deadspool For This Useful Post:
blue cat (04-29-2014), NyC Zn6 (06-01-2013), SC David (06-03-2013)
Old 06-01-2013, 08:17 PM   #17
Mikem53
Drives: FR-S 6MT
Originally Posted by #87 View Post
revs, drop clutch, engage brakes, keep pedal on right depressed
A tip for those that may not know.. its best not to just "dump" the clutch..
Bring the clutch pedal up to the point of engagement.. then let go of it..
This method will take up any slack in the driveline and keep you from snapping parts and bending things.. less abusive this way
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
ilpad (06-02-2013)
Old 04-29-2014, 12:55 AM   #18
poison1916
Drives: Scion FR-S Hot Lava
What's the combination for the AT?
Here is what I tried but it didn't work. Hold track off to get the double orange lights, put the car in snow to start in second, hold the break lightly and press the accelerator lightly then to the floor, release break. Got nothing. Another try I breaked too hard and the dumbass car killed the engine drive power *shakes fist*. I tried a few combinations like starting in first, throwing the engine up to 6k then quickly shifting to 3rd. None of it worked!
Please help me look cool ft86club
Sent from my HTC6525LVW using Tapatalk
poison1916 is offline   Reply With Quote
Old 04-29-2014, 12:57 AM   #19
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
Ha yeah how in the world do you do a burnout in an AT?
Autocon is offline   Reply With Quote
The Following User Says Thank You to Autocon For This Useful Post:
LXXXV1 (04-29-2014)
Old 04-29-2014, 01:23 AM   #20
iag48st
Drives: 10Series 0945
I do them all the time and I need to stop smh. Disable the nannies, press brake pedal slightly, then press the throttle 100%. When you feel the car over power the slight brake pressure, press the brake pedal harder.
iag48st is offline   Reply With Quote
Old 04-29-2014, 03:09 AM   #21
humfrz
How does one properly burn out in an mt? Yea I'm a noob.
I'd suggest you not ..... it's hard on the car ....
humfrz
Old 04-29-2014, 09:54 AM   #22
stevesnj
stevesnj's Avatar
You should turn off trac and vsc etc. before you do this or put it in inspection mode to turn off Auto LSD
Can't Launch AT? Do a burnout then Ericfrs Scion FR-S / Toyota 86 GT86 General Forum 30 10-07-2012 01:24 AM
Burnout Vid from Youtube. amilleri FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 06-03-2012 03:34 AM
monza (italy) speed day Tunnel Cars BURNOUT and LAUNCH !!! lancie Off-Topic Lounge [WARNING: NO POLITICS] 4 11-20-2011 01:30 PM
