Old 05-27-2013, 08:37 PM   #15
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by FRSFirestorm View Post
I was surprised when I couldn't get the toe in. Everything I'd read said no problem with an inch drop and the factory adjustment. Off center rear subframe makes sense.
Had the same problem, after putting my H Techs on my right rear camber was over a degree more negative than the left rear so I got the SPC arms. It took a while but we eventually got the camber and toe to a decent spec without using the toe bushings.
JoeBoxer is offline   Reply With Quote
Old 05-27-2013, 09:05 PM   #16
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I've ordered the SPC arms. Looks like another day poking around under the car in the future. Hopefully I'll get it dialed in this time.
FRSFirestorm is offline   Reply With Quote
Old 05-27-2013, 09:29 PM   #17
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I'm running the SPC LCAs with the stock toe arms (I have the SPC arms, just didn't need to install them). I have zero noise from anything shifting around. Those arms are pretty sturdy for what they are.
I would just go back through the install and make sure everything it tight and torqued.
And when it comes to finding a competent alignment shop - I just went to Firestone and bought the lifetime alignment, and then told the alignment tech how I wanted camber, caster, and toe. Worked out great for me.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
