Old 05-19-2013, 01:52 AM   #15
polarstorm
polarstorm's Avatar
Drives: Scion FR-S
Originally Posted by xanth123 View Post
Also this is my first manual so don't know if that factors in.
I would say yes. I have been driving manual for over 15y and was very ineficient (and in a way still am getting used to this new car), also listening to loud music messes up my mpg because I'm not tuned-in to the engine revs. I find that being able to listen to the engine helps you gauge shifting timing better.
I found out that my range goes from 300km to 400km (25% increase in mpg) just by doing a long distance trip (hwy driving in 6th at around 3k)..
I have come to terms with the fact that, a) I do a lot more city driving than I want to, and b) Im really enjoying this car so I'm holding back or trying to be ultraconservative, but I am efficient in using the manual transmission tho. Can't comment on how automatic fares. One thing I am dissapointed with this car is the range, wish the tank was large enough to accommodate 500 clicks. Curious what median and avg ranges other people are getting.
polarstorm is offline   Reply With Quote
Old 05-19-2013, 03:13 AM   #16
Freeze2196
Freeze2196's Avatar
Drives: 2013 Scion FRS
I have only 2600 miles on my car and my MPG is also 24.2
"REALLY HEAVY FOOT"
Freeze2196 is offline   Reply With Quote
Old 05-19-2013, 03:46 AM   #17
Jakeedaman21
Drives: Ultramarine FR-S M/T
Ive seen it do 25 MPG doing a consistent 125mph for about two hours.
Jakeedaman21 is offline   Reply With Quote
Old 05-19-2013, 09:30 AM   #18
FRiSson
Drives: FR-S MT
Originally Posted by radroach View Post
Should we go into a D4S discussion? I find that between 1000-3500 rpm I'll get around 20mpg, and then it will go up to ~40-50mpg when D4S port injection starts coasting in the 3500-4000 range. Anybody else want to chime in on this?
My understanding is that the two systems work in complex synergy. There is no strict cut-off when one is working and the other isn't, except at the lowest speeds. I agree though that their is something about the system that causes the engine to have a huge differential between highway-only driving and ordinary 45-50mph back road cruising.
FRiSson is offline   Reply With Quote
Old 05-19-2013, 10:20 AM   #19
husker741
Try turning your efficiency indicator on which has an arrow flash on the LCD screen when you should shift for the best efficiency.
husker741 is offline   Reply With Quote
The Following User Says Thank You to husker741 For This Useful Post:
ntron1 (05-19-2013)
Old 05-19-2013, 10:24 AM   #20
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
What Husker741 said. You will see the arrow around 2K. Takes away some of the fun factor but in daily commuting you can only get there as fast as the traffic will allow anyway so alot of the fun factor is gone anyway.
ntron1 is offline   Reply With Quote
Old 05-19-2013, 10:30 AM   #21
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
i'm averaging about 22 mpg - 4 miles each way, spirited drive to and from work in traffic. i do no freeway/highway driving.
shiumai is offline   Reply With Quote
Old 05-19-2013, 12:43 PM   #22
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I don't speed that much and I shift at around 3-4k. I just use brake to slow down and don't use cruise control at all.
If you want to see improvement you have to completely change how you drive. Here are some beginner tips:
(1) Don't be in a rush.
(2) Ease away from stop lights. Who cares if you're not the first car across the intersection?
(3) Shifting at 3-4K and you think that's good for F/E?? Try shifting at 2K.
(4) Fuel economy goes down w/ speed *over simplified* so try doing the speed limit or "just" above it if you have to. (PROTIP: police will go after the chumps going by you in the passing lane)
(5) Learn to coast to your advantage. Try and minimize the loss of speed. If you see a slow down ahead, don't fly up to it and slam on the brakes, instead COAST (or use the brakes minimally). Instead of hitting the bottle-neck and coming to a complete stop you may only lose half your speed, etc.
(6) Find a friend who is a F/E whore and ride with them. I'm sure you think you know how to "drive for F/E", but the fact you're doing so poorly tells me that you don't (not to say that you "drive" poorly).
Best of luck! F/E driving can be addicting in its own way.
C'MON BABY GIMME ANOTHER TENTH A GALLON!
Chimpo is offline   Reply With Quote
The Following User Says Thank You to Chimpo For This Useful Post:
ntr0py (05-20-2013)
Old 05-19-2013, 01:25 PM   #23
Gen
Drives: Scion FR-S
Averaging right around 20 MPG I'd say. I like it that way. A few extra bucks a week doesn't matter.
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
mit_peid (05-20-2013)
Old 05-19-2013, 01:50 PM   #24
radroach
Drives: car
Originally Posted by mit_peid View Post
It is not that simple. Depends on a whole lot of other things, but D4S kicks in and generally uses more gas (not less) to generate even more HP with higher compression. I can get very good highway mileage too at 65-70mph while in 6th on flat highway (35+mpg). The best mpg I got was during my break-in period when I was trying to stay under 4000k.
I can understand that it uses more gas but it also has a variable timing difference at the point D4S kicks in, it seems like an efficient driving style to also let the engine breathe in some cases, as the engine and drivetrain seems to get smoother in a higher rpm range (at the cost of being really freakin loud sometimes.
Old 05-19-2013, 01:54 PM   #25
radroach
Drives: car
Shifting below 2500 rpm usually sucks for me because I get a lot of syncro-feel and clicking in the transmission.
Old 05-19-2013, 02:07 PM   #26
xanth123
Drives: white out frs
Thanks for all the input! And yes, I use the indicator on the car.
xanth123 is offline   Reply With Quote
Old 05-19-2013, 03:01 PM   #27
civdaddy
Drives: Slow
I got 26mpg doin 126mph for 2 hours. Got you beat.
civdaddy is offline   Reply With Quote
Old 05-19-2013, 06:01 PM   #28
tennisfreak
Drives: 2018 BMW M240i
I dont even try to drive "light footed" and still get 30 mpg. (all premium gas in my area is 93 octane 10% ethanol)
