Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-16-2013, 11:59 PM | #15 | |
Awesome thank you! Yeah i was very shock to have that rumble note like i had on my 11 STI, very happy with it, i saw videos of other exhaust and never heard the nice rumble unless it had UEL headers. Im in shock, good shock |
05-17-2013, 12:07 AM | #16 |
BTW my Perrin did a bit of drip after first install. Let it run for a while and it was fine. No water drip after. Give that a shot.
06-13-2015, 06:51 PM | #17 |
Drives: SWP BRZ
I have same problem but i get tiny air leak no matter what..
is it going to be an issue? i tried fix it right after installation but already tired. need time to fix it later |
06-13-2015, 08:33 PM | #18 |
Drives: 2013 SWP BRZ
I just installed a q300 on my brz and had the exact same problem with water coming out. We moved the clamp towards the edge of the top pipe and clamped it there. Still had some water but no air could be felt. No problems since them I don't hear any leak sounds
06-13-2015, 10:05 PM | #19 |
Drives: SWP BRZ
06-13-2015, 11:01 PM | #20 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
@zc06_kisstherain you put it over the slits, so the blue area. Edits: also make sure you slide the mid pipe all the to the back of the muffler pipe to help with the leaks.
I have the Q300 too and i have the slight leak and drips too. I don't hear any hissing so i dunno, it just doesn't bother me. If it really bothers you then I'd recommend having it welded together. That's really the only way to guarrentee no leaks or drips.
06-14-2015, 02:35 AM | #21 | |
And retighten after a couple runs |
06-14-2015, 03:48 AM | #22 |
Drives: UK GT86
I used some liquid copper gasket around all the slits and edges and then clamped over the top. No more leak at all.
.: Stealth 86 :.
06-14-2015, 09:36 AM | #23 | |
Drives: SWP BRZ
yeah i already tightened there but small air leak.
I am thinking to use 2 clamps instead one. one at the red arrow and one at blue. |
06-14-2015, 02:10 PM | #24 |
Thupercharged
Both my Q300 exhausts had that little water drip on a cold start, but no exhaust leak noises or air coming out.
After a year or so I think it got plugged up with carbon because now it doesn't/rarely leaks water. I wouldn't worry about it too much, double clamping might just tweak the pipes and make it worse if you try to really crank down. I would try exhaust putty or copper RTV before double clamping
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
06-14-2015, 08:40 PM | #25 |
Drives: SWP BRZ
I just fixed my leak using below 2 items i bought at local auto store
Tiger Patch & Exhaust Foil tape and hose clamp (aluminium??) I started Foil taped at joint section (where two pipe meets) through side openings. then i used tiger patched over at joint section as well as 2 side openings. it might be overkill but i foil taped again for extra layer again. I used my extra aluniminum hose clamp to clamp at joint section then i sleeved clamp end of tip that already covered with tiger patch & Exhaust foil. I started the car and immediately checked for leak and there is none. after idle, i double checked again and no leak again. I drove normally around city and some WOT on 2-3rd gear then checked for leak again. there is none! I hope this helps others with small leak on Q300 or other slip joint exhaust system. I will keep update for longevity and reliability. BTW, took video after [ame="https://www.youtube.com/watch?v=f-3lB89w7Pg"]BRZ invidia Q300 - YouTube[/ame] Last edited by zc06_kisstherain; 06-14-2015 at 09:17 PM. |
06-14-2015, 09:33 PM | #26 |
Bilge monkey
Drives: '13 BRZ, 82 starlet
crazy that a $700 exhaust would use such crappy connection methods.
glad you fixed the problem |
06-15-2015, 08:21 AM | #27 |
Drives: 2015 Scion FR-S
I just installed the Q300 a couple of weeks ago on my FRS. I think you should put the clamp closer to the end of the pipe (be sure the pipes are pushed fully together fist). Also, a little muffler sealer (grey paste) applied to the pipes before inserting the pipes together adds some grit & grip and makes the clamp more secure. The main problem I had was 1 exhaust (right side) sticks out 1/2 to 3/4 inch further than the other side no matter how I try to adjust it.
06-15-2015, 10:17 AM | #28 | |
Drives: SWP BRZ
For mine, i already fully pushed pipes into muffler side and did clamp to the end of the pipe. i didnt use sealer though but thought about it. your suggestion is correct though, it didnt work for me. maybe my end of slip joint pipe had little dent causing small air leak. i am just happy that i solved problem |
Similar Threads | ||||
Owners of Invidia Q300 | lxsedan | Engine, Exhaust, Transmission | 59 | 08-24-2020 11:49 AM |
Invidia Q300 vs. Perrin Catback (Non-resonated) | Taylor13 | Engine, Exhaust, Transmission | 26 | 02-06-2014 07:26 PM |
Installing the q300 myself | hunter3232792 | Engine, Exhaust, Transmission | 16 | 12-08-2013 09:24 AM |
Invidia Q300 with Ti Tips | seven | Engine, Exhaust, Bolt-Ons | 23 | 03-09-2013 01:39 AM |
FS: Invidia Q300 Burnt TI Version | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 0 | 01-16-2013 01:46 AM |
