Old 04-29-2013, 02:14 PM   #15
euroshowoff
euroshowoff's Avatar
Drives: 2015 Tacoma
Originally Posted by coastertrav View Post
Just properly adjust your mirrors. Just picked up the car Saturday and one of the things I noticed immediately is that this car has amazing mirrors and no blind spot when they are adjusted properly. I'd say that most people have their mirrors adjusted to all look directly down the side of their car, but that is WRONG. If you can see any part of your car in your side mirrors they need to be adjusted much further out to see into your blind spot.
I'll try this approach. Thanks.
euroshowoff is offline   Reply With Quote
Old 04-29-2013, 02:33 PM   #16
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Originally Posted by euroshowoff View Post
So I've been driving my new FRS for two days now, how do you deal with the terrible blind spot on the drivers side?
Drive a celica before you drive the FRS and you'll get use to it
CamryDS is offline   Reply With Quote
Old 04-29-2013, 02:52 PM   #17
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Just for reference on the convex mirrors.
[ame="http://www.youtube.com/watch?v=VCvpMuuY3JQ"]Rexpeed Blue Wide Mirrors for the Scion FR-S and Subaru BRZ - YouTube[/ame]
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
subwaynm (12-25-2013)
Old 04-29-2013, 03:45 PM   #18
whaap
whaap's Avatar
Originally Posted by Ben_G View Post
I've been able to do this for all my previous cars, but I still haven't found the sweet spot for the BRZ/FRS.... no matter where I set my mirrors, there's always this one spot that I can't quite get rid of....I may have to resort to one of those stick on convex mini mirror dealies..... =(
Ben, I don't know if we're different in physical size or not. I'm 5'10", 155 lbs. and I don't have a problem spot. I do drive with my seat pretty far to the rear. I'm hoping all you need to do is spend a little more fine tuning the adjustments. Make sure your rear view mirror is centered so it doesn't favor one side over the other.
whaap is offline   Reply With Quote
Old 04-29-2013, 04:05 PM   #19
mackdaddytran
mackdaddytran's Avatar
Drives: Toyota Skyline Type-R
I just point out the mirrors to the point where I can't see the side of my car anymore. It doesn't completely eliminate the blind spot but it helps alot. Learned that trick when I had my s2k.
Or you can just drive faster than everybody else so you don't have to worry about a blind spot
mackdaddytran is offline   Reply With Quote
Old 04-29-2013, 04:11 PM   #20
636
636's Avatar
Drives: '23 CWP BRZ
I used to run my mirrors so I could see the rear of my car in them, until my friend actually told me how to set them up. Haven't had a blind spot since.
She told me to basically lean my head into the window, then adjust the driver's mirror from there to where you can see the edge of the rear of your car, and the same for the passenger, just lean as far as you can.
You shouldn't see the same car in your rear view mirror, as you do in your side views, that's just counter productive.
636 is offline   Reply With Quote
The Following User Says Thank You to 636 For This Useful Post:
racecat (12-27-2013)
Old 04-29-2013, 04:22 PM   #21
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Originally Posted by CBR600RR View Post
if your mirrors are properly adjusted you will not have a blind spot
Not true in the dark, before I started using convex mirrors, I almost hit a motorcyclist trying to merge on the right lane because I couldnt see his headlight and he was definitely in my blind spot. Dont ask me how he got there, I have a habit of always checking my side mirrors in case some idiot tries to cut me off forcing me to swerve.
LeeMaster is offline   Reply With Quote
Old 04-29-2013, 04:43 PM   #22
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
Thanks...thought about the replacement mirror options, but then I would lose my heated mirrors (first world problems, right).... I'm still testing different mirror locations and if for some reason I can't figure it out, I'll look at those again...
Sent from my Galaxy Nexus using Tapatalk 2
i've tried but because not everybody is the same (height, size and what not) I think simply buying those small blind spot mirror should be good enough and would not eliminate your heated mirrors functionality. And they're cheap too.
just my two cents
j2digit is offline   Reply With Quote
Old 04-29-2013, 06:45 PM   #23
Ben_G
Drives: Blue BRZ
I've sort of settled on just leaning forward a bit to look in the mirror when I change lanes but it's never quite as natural as less sport cars... oh well, nothing more driving won't fix! =)
Ben_G is offline   Reply With Quote
Old 04-29-2013, 07:50 PM   #24
FRyeS
Drives: 2013 FR-S Asphalt 6MT
This simple.
FRyeS is offline   Reply With Quote
Old 04-29-2013, 08:21 PM   #25
Sacs
Drives: GT86
After a near miss 15 years ago (with properly adjusted mirrors!) I've learned never to rely totally on the mirrors. It is now habit to physically turn my head and visually check/clear any potential blind spots.
Sacs is offline   Reply With Quote
Old 04-29-2013, 08:38 PM   #26
mackdaddytran
Today is my third day with this car. I just realized how horrible the blind spot is when you're trying to do a uturn.
I was under a bridge doing a uturn and i seriously could not see shit. I had to be sure that oncoming traffic was at a red light before i could go
Old 04-29-2013, 08:57 PM   #27
Ocala FR-S
Ocala FR-S's Avatar
Drives: 2013 FR-S AT Argento
First couple of days with the car I had two incidents were I began to change lanes into an overtaking vehicle. I set the outside mirrors way wider. It has never happened again.
I have adjusted both outside mirrors so that the line on the far side of the next lane appears in the lower outside corner of the mirror. Almost as far out as they adjust.
Glance in the rearview mirror, sideview mirror, over your shoulder; if you don't see it, it's not there.
Ocala FR-S is offline   Reply With Quote
The Following User Says Thank You to Ocala FR-S For This Useful Post:
Demandred7 (04-30-2013)
Old 04-29-2013, 09:14 PM   #28
jmaryt
Drives: 2012 honda civic ex
this is "dead nuts" accurate!. IF properly adjusted,then "TRUST'' what you see in your mirrors.
jmaryt is offline   Reply With Quote
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 01:42 AM
Blind spot mirrors? enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-11-2012 03:29 AM
spot cleaning jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-26-2012 07:12 PM
People having a hard time with the FR-S blind spot driver01 Scion FR-S / Toyota 86 GT86 General Forum 28 06-16-2012 04:27 PM
Blind Spots? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 35 10-04-2011 04:17 PM
