#15 |
Because compromise ®
Drives: Red Herring
I am a huge proponent of function>form but occasionally an item will appear that is both functional and aesthetically pleasing. I am suggesting these are one such item.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | whataboutbob (11-01-2013) |
#16 |
Drives: 13 BRZ
Very nice!
#17 |
Damn, I am almost inclined to buy these to replace my Vorshlags, just because of how good they look. Now if you could anodize them orange I think I would be completely sold!
#18 |
Drives: red frs
These are awesome...
integrated tower brace coming????? |
#19 |
Drives: 2024 GR86/ 2015 FRS
They are even better looking in person.
I will be testing them at the AutoX soon. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#20 |
Drives: Asphalt Scion FR-S
Do these raise the height when installed, or do they allow more shock travel? Parts look good!
#21 |
Raceseng can answer definitely but the way the upper portion seems to fit within the opening of the strut tower would mean the perch wouldn't sit quite as low as a perch which fits completely flat under the shock tower.
#22 |
Drives: 2013 MT FRS, 2002 MR2
I rarely see something that makes me scream "I need this" like these do.
#23 |
We plan on making them work with all the dampers on the market. We can custom machine the upper and lower spherical bearing bushing to fit the strut shaft. We plan on making a simple form that the customer can fill out that will detail the dimensions of their strut shaft and spring. There will be some modularity between the strut shafts but its going to take us some time to cover all the coil overs on the market.
#24 | |
#25 |
#26 |
Glad you asked, the upper is a spherical bearing with a stainless steel race/ball and a teflon liner. There are a large number of private labeled spherical bearings carried by every "bearing manufacturer" under the sun. Sifting through the mess of private labeled bearings is the difficult part.
The spring perch bearing is a double row angular contact bearing. This is a more expensive bearing but truly intended for the axial/thrust load that it will see. |
| The Following User Says Thank You to Raceseng For This Useful Post: | Eric@ptuning (01-28-2014) |
#27 |
Hearing something like this makes me proud because we pour hours upon hours into truly designing our products. All things begin and end with design at Raceseng, it is one of our core foundations.
| The Following User Says Thank You to Raceseng For This Useful Post: | Hawk77FT (08-10-2013) |
#28 |
The caster/camber plate will be black anodized and the bearing housing and spring perch will be anodized orange.
| The Following User Says Thank You to Raceseng For This Useful Post: | Supermassive (04-30-2013) |
| Tags |
| billet, billet aluminum, caster adjustment, caster camber plate, raceseng |
| Tein Flex Z Coilovers | Evasive Motorsports | Brakes, Suspension, Chassis | 54 | 07-16-2017 01:21 AM |
| Raceseng | Billet Aluminum Engine Pulleys | Raceseng | Engine, Exhaust, Transmission | 174 | 07-24-2014 12:24 AM |
| Raceseng | Lightweight Billet Aluminum Tow Hook | Raceseng | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-27-2013 01:48 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
| SRP Billet Aluminum Door Sills | pedalpusher | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-20-2012 06:44 PM |
