Old 05-19-2011, 11:05 PM   #15
Franisco
Franisco's Avatar
Drives: D31a
Is there any difficulty with them using el, or are you just saying they never do it?
Originally Posted by White Comet View Post
No one's buying a Yaris to wind the piss out of it and possibly slam into a mountainside pretending they're the ultimate Tofu delivery person.
Franisco is offline   Reply With Quote
Old 05-19-2011, 11:12 PM   #16
xantonin
Mr. Detail
xantonin's Avatar
Drives: 2003 Celica GT-S
Not sure I like the turn signals near the center.
Might help other drivers see if they can move them to the corner more...
rar
xantonin is offline   Reply With Quote
Old 05-19-2011, 11:24 PM   #17
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
uel header have tendency of bring CEL. It sure is one of nightmare NA Impreza owner have... but that doesn't stop Toyota/Subaru from using the. Also kinda waste of material.
Here's my uel
When you install it, it looks like this (pic isn't mine)
see how it's near oil filter & oil pan? while el looks like this
Here's OEM header vs OBX header
and it doesn't rap around oil filter or oil pan
Old 05-20-2011, 12:03 AM   #18
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I don't know Subaru as well as you, but if you want high hp don't you want to use a equal length header instead of the UEL header? So basically UEL is a poor choice for high horsepower? I remember reading that in an article. Also something about UEL screwing up cylinder 2 and 4 and causing a failure? So is the only reason for UEL for that deep rumble? Any other benefit?
tranzformer is offline   Reply With Quote
Old 05-20-2011, 12:13 AM   #19
NikostC
JDM Enthusiast
NikostC's Avatar
Drives: Scion tC
UEL gives better mid range power while EL gives better high range power / peak power IIRC.
NikostC is offline   Reply With Quote
Old 05-20-2011, 12:17 AM   #20
xantonin
Mr. Detail
xantonin's Avatar
Can someone add these abbreviations to the terminology thread? Or are they there already? *goes to look*
rar
Old 05-20-2011, 12:19 AM   #21
ichitaka05
Site Moderator
ichitaka05's Avatar
Hm... that's not fully true. Look at turbo ver headers. they're uel. I highly doubt they gonna use uel just to break the engine.
yes, el header can get more hp than uel... but that's in high rpm. While low rpm uel have more hp.
My opinion, it's all up to personal. Some ppl claim uel get more hp w their setup. While some ppl claim el get more hp w their setup.
Old 05-20-2011, 12:23 AM   #22
tranzformer
Drives: Zoom Zoom
As I said I don't know much about this so will defer to you. I found the article that I remember reading several weeks back.
When modifying WRX/STIs, it is important to plan for the type of the aftermarket Subaru exhaust manifold (header) your will be getting. Unequal length header will allow you to keep the Subaru Boxer rumble sound, yet unequal length header is a poor choice for high horsepower applications where you want to maintain equal Exhaust Gas Temperatures among all cylinders and safe turbo inlet temperatures.
Since header runner for cylinder 4 is the longest on unequal length headers (on WRX/STI), you have the highest EGT in that runner and on cylinder 4. This is because hot exhaust gases travel longer in the longer runner. Cylinder 2 runner is the second longest. Since you are continuously subjecting cylinders 2 and 4 to higher heat than other cylinders it is very common to see various cylinder 4 and cylinder 2 failures in Subarus.
Shorter runners of cylinders 1 and 3 provide for lower EGT on those cylinders. However, since the temperature drop is less than in cylinder 2 and 4 runners, higher-temperature exhaust gases get transferred to the turbo, subjecting the turbo to additional heat stress.
Equal length manifold (header) smoothes exhaust pulses of the Boxer engine, thus changing the exhaust note to smooth vs. burpy. Some refer to it as a “ricer sound”, however it is really not that bad. Equal-length header is optimal for maintaining equal EGT between all cylinders and delivering a constant, lower-temperature exhaust gas to the turbo. Equal length header is a must have for any higher horsepower Subaru WRX STI.
http://rusubaru.com/equal-length-vs-...ength-headers/
That article could be all wrong?
Old 05-20-2011, 12:33 AM   #23
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
It's nice to hear the boxer roar a little bit.
iff2mastamatt is offline   Reply With Quote
Old 05-20-2011, 12:48 AM   #24
ichitaka05
Site Moderator
ichitaka05's Avatar
Nice find & I totally agree w the article. Specially if you wanna push over 400hp. BUT I'm only talking bout stock/OEM.
Subaru knows this... but why they still use uel on S series STI (S202, S203, S204, S402)? If they really want, they can make el headers for them.
Answer to this, IDK. Only Subaru knows. But thing I know is boxer engine have more stuff to worry than putting more stress on #2 & 4 cylinder. btw, #3 cylinder have higher chance of comp ratio failure than #2 & 4. Why? IDK
Number 1 thing they need to worry is crank bearing. higher the rpm goes, boxer engine have more chance of having crank bearing failure. I want to know how Toyota gonna solve this problem, cuz I'm expecting this car to at least beat GC series Impreza redline.
Old 05-20-2011, 01:23 AM   #25
tranzformer
Drives: Zoom Zoom
Thanks for clearing that up for me. Well kinda since the issue seems a bit more complex.
Old 05-20-2011, 01:41 AM   #26
Franisco
Franisco's Avatar
Drives: D31a
Wow..seems like something simple but its definitely not. Thanks ich
Old 05-20-2011, 02:29 AM   #27
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
Thank you hachi!!!!
Man, I must've watched that vid like 6 times.....
Imagine having that job guys...just imagine what its like to be those people, testing it....I want that job!
OldSkoolToys is offline   Reply With Quote
Old 05-20-2011, 02:40 AM   #28
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
adprokid is offline   Reply With Quote
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
Subaru BRZ and Toyota 86 appreciation video thread Nostalgia1987 AUSTRALIA 2 01-11-2012 05:25 PM
First Video of Scion FR-S / Toyota FT-86 / Subaru BRZ Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 11-15-2011 09:21 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-25-2011 11:53 PM
