Old 04-15-2013, 03:08 PM   #15
Hanakuso
I think many of you guys are forgetting that using ramps + 2 jack stands is not good when you want a flat and equal ground. It's important to have things leveled when doing trans/diff fluid swaps.
Hanakuso is offline   Reply With Quote
Old 04-15-2013, 04:25 PM   #16
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
get 2 more jack stands
Old 04-15-2013, 05:34 PM   #17
so26
Drives: Raven FR-S 6MT
update ... so I just went ahead and got another pair of jack stands. Changed the diff oil already now waiting on transmission oil to arrive. BTW, if you haven't done it already you will probably want to change the diff oil it's pretty nasty after 14k miles.
so26 is offline   Reply With Quote
Old 04-23-2013, 05:38 PM   #18
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by cnk View Post
For $5 more you can get these: http://www.sears.com/craftsman-3-ton...6&blockType=G6
I have them and they work great, plus there is a notch for the pinch weld to help you center it on the stand.
Me too. Also, hockey pucks fit perfectly to help spread the load and reduce chances of body damage. But, you need a hi-lift jack to take full advantage of the 21" max lift and some hi-lift jacks might be a squeeze getting far enough under the car. Which jack do you use?
torqdork is offline   Reply With Quote
Old 04-23-2013, 05:43 PM   #19
cnk
Drives: '13 DGM BRZ Limited
I was using a HF 3 ton aluminum racing jack, but I can hear the seals starting to give out so I just picked up an Arcan from Costco last week.
cnk is offline   Reply With Quote
$10 Jack Buddies blalor DIY (Do-It-Yourself) Guides 24 10-20-2017 08:16 PM
Recommended Car Ramps for the BRZ/FRS? mechaghost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 09-01-2017 01:41 AM
Free Shipping on ALL Race Ramps Products @ JWM JWMotoring Mechanical Maintenance and Tools 5 10-04-2012 06:22 PM
The S in September stands for Suspension! Lots of Sales! KronosPerformance Brakes, Suspension, Chassis 8 09-13-2012 03:08 PM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 02:53 AM
